sicxnull Posted September 2, 2024 Posted September 2, 2024 (edited) Got Armbian to run on those $20 TV Boxes sold at Wal-Mart. This is for the Dopinder variant, i have not tested on the newest version (YOC) but I will likely pick one up just to see. -removed- Requires a few changes outside of the norm for armbian builds, so it's on my own fork. Likely will not be doing a PR. That said, it pulls the latest armbian source when building. https://github.com/sicXnull/Onn4K-TV-Box-Armbian Needed: OTG Cable (required) USB Hub (recommended) USB to Ethernet adapter (recommended) Working HDMI Audio Bluetooth Wi-Fi Building: git clone https://github.com/sicXnull/Onn4K-TV-Box-Armbian.git cd Onn4K-TV-Box-Armbian git clone --depth=1 https://github.com/armbian/build armbian-build cp -R armbian-patch/* armbian-build/ cd armbian-build ./compile.sh build BOARD=onn4k BRANCH=current BUILD_DESKTOP=yes BUILD_MINIMAL=no DESKTOP_APPGROUPS_SELECTED= DESKTOP_ENVIRONMENT=mate DESKTOP_ENVIRONMENT_CONFIG_NAME=config_base EXPERT=yes KERNEL_CONFIGURE=no KERNEL_GIT=shallow RELEASE=bookworm cd .. sudo ./postscript.sh write the image to USB. cd armbian-build/output/images sudo dd if=Armbian-unofficial_24.11.0-trunk_Onn4k_bookworm_current_6.6.48_mate_desktop.img of=/dev/sdb bs=4M status=progress Booting from USB Plug it into your onn 4K UHD using an OTG cable, and hold the reset button while plugging in power. For future boots, you just need the USB drive plugged in during poweron. There is no more need to hold the reset button. EMMC Boot I'm assuming flashing to EMMC will break it, i have not tested this yet, although i plan to in the future. Edited September 13, 2024 by Werner edit on user request 1 Quote
mona Posted September 24, 2024 Posted September 24, 2024 (edited) If there is still interest, I can try testing the newer variant of the Onn box with the S905Y4. It seems to me this could be super useful (especially if we can flash to the EMMC in the future). It could be a relatively cheap RPI alternative for things like pihole. Edited September 24, 2024 by mona added thoughts 0 Quote
sicxnull Posted September 24, 2024 Author Posted September 24, 2024 (edited) 9 hours ago, mona said: If there is still interest, I can try testing the newer variant of the Onn box with the S905Y4. It seems to me this could be super useful (especially if we can flash to the EMMC in the future). It could be a relatively cheap RPI alternative for things like pihole. From what i understand the bootloaders are locked and cannot be unlocked on the new ones, but there's always the possibility that there's a workaround. I need to run to walmart and grab one to play with, but if you make any progress by all means, let us know! For $20 these things would be great for pihole/light work like you mentioned. Edited September 24, 2024 by sicxnull 0 Quote
