Tanat Posted June 13, 2017 Share Posted June 13, 2017 Hi all. I install Ubuntu_xenial_default with kernel 3.4.113 and want record video from CAM500B with ov5640 image sensor. I had edited camera section in fex file with next options: [csi0] vip_used = 1 vip_mode = 0 vip_dev_qty = 1 vip_define_sensor_list = 0 vip_csi_pck = port:PE00<2><default><default><default> vip_csi_mck = port:PE01<2><default><default><default> vip_csi_hsync = port:PE02<2><default><default><default> vip_csi_vsync = port:PE03<2><default><default><default> vip_csi_d0 = port:PE04<2><default><default><default> vip_csi_d1 = port:PE05<2><default><default><default> vip_csi_d2 = port:PE06<2><default><default><default> vip_csi_d3 = port:PE07<2><default><default><default> vip_csi_d4 = port:PE08<2><default><default><default> vip_csi_d5 = port:PE09<2><default><default><default> vip_csi_d6 = port:PE10<2><default><default><default> vip_csi_d7 = port:PE11<2><default><default><default> vip_csi_sck = port:PE12<2><default><default><default> vip_csi_sda = port:PE13<2><default><default><default> vip_dev0_mname = "ov5640" vip_dev0_pos = "rear" vip_dev0_lane = 4 vip_dev0_twi_id = 2 vip_dev0_twi_addr = 0x78 vip_dev0_isp_used = 1 vip_dev0_fmt = 0 vip_dev0_stby_mode = 1 vip_dev0_vflip = 1 vip_dev0_hflip = 0 vip_dev0_iovdd = "" vip_dev0_iovdd_vol = 2800000 vip_dev0_avdd = "" vip_dev0_avdd_vol = 2800000 vip_dev0_dvdd = "" vip_dev0_dvdd_vol = 1500000 vip_dev0_afvdd = "" vip_dev0_afvdd_vol = 2800000 vip_dev0_power_en = vip_dev0_reset = port:PE14<1><default><default><default> vip_dev0_pwdn = port:PE15<1><default><default><default> vip_dev0_flash_en = vip_dev0_flash_mode = vip_dev0_af_pwdn = vip_dev0_act_used = 0 vip_dev0_act_name = "ad5820_act" vip_dev0_act_slave = 0x18 vip_dev1_pos = "rear" vip_dev1_lane = 1 vip_dev1_twi_id = 0 vip_dev1_twi_addr = vip_dev1_isp_used = 0 vip_dev1_fmt = 1 vip_dev1_stby_mode = 0 vip_dev1_vflip = 0 vip_dev1_hflip = 0 vip_dev1_iovdd = "" vip_dev1_iovdd_vol = 2800000 vip_dev1_avdd = "" vip_dev1_avdd_vol = 2800000 vip_dev1_dvdd = "" vip_dev1_dvdd_vol = 1500000 vip_dev1_afvdd = "" vip_dev1_afvdd_vol = 2800000 vip_dev1_power_en = vip_dev1_reset = vip_dev1_pwdn = vip_dev1_flash_en = vip_dev1_flash_mode = vip_dev1_af_pwdn = And had added to file /etc/modules ov5640 vfe_v4l2 After reboot I can list video0 device in /dev but dmesg | grep ov5640 and dmesg | grep VFE returns nothing. And dmesg | grep OV5640 show [ 7.860317] [OV5640@lex]init_sensor - frame_rate: 0, max_win_size: 11 [ 7.952205] [OV5640@lex]CSI_SUBDEV_PWR_ON! [ 8.020823] [OV5640@lex]sensor_init 0x0 [ 8.065071] [OV5640@lex]CSI_SUBDEV_PWR_OFF! Then ffmpeg -f v4l2 -s 640x480 -i /dev/video0 -r 30 -c:v mpeg4 ./test/test.avi returns error: ioctl(VIDIOCENUMINPUT): invalid argument /dev/video0: Invalid argument. Please help me with this problem. Link to comment Share on other sites More sharing options...
Tanat Posted June 14, 2017 Author Share Posted June 14, 2017 I had tried to boot without camera and dmesg | grep OV5640 displayed: init_sensor - frame_rate: 0, max_win_size: 11 CSI_SUBDEV_PWR_ON! sensor read rety=2 error at sensor_detect chip found is not an target chip CSI_SUBDEV_PWR_OFF! And tried to boot with had connected camera then dmasg | grep OV5640 displayed next: init_sensor - frame_rate: 0, max_win_size: 11 CSI_SUBDEV_PWR_ON! sensor_init 0x0 CSI_SUBDEV_PWR_OFF! Then agian I may list /dev/video0 but no access to this device Link to comment Share on other sites More sharing options...
Tanat Posted June 20, 2017 Author Share Posted June 20, 2017 I tried to recompile ov5640 and vfe modules with DEV_DBG_EN 1 and now after commands modprobe ov5640 vfe_v4l2 I can see next: dmesg | grep VFE [ 1621.705770] [VFE]Welcome to Video Front End driver [ 1621.706258] [VFE]pdev->id = 0 [ 1621.706270] [VFE]dev->mipi_sel = 0 [ 1621.706278] [VFE]dev->vip_sel = 0 [ 1621.706285] [VFE]dev->isp_sel = 0 [ 1621.712469] [VFE_WARN]vfe vpu clock is null [ 1621.720171] [VFE]..........................vfe clk open!....................... [ 1621.720442] [VFE]vfe_init end [ 1621.730275] [VFE]probe_work_handle start! [ 1621.730308] [VFE]v4l2 subdev register input_num = 0 [ 1621.730320] [VFE]vfe sensor detect start! input_num = 0 [ 1621.730337] [VFE]Find sensor name is "ov5640", i2c address is 78, type is "YUV" ! [ 1621.730350] [VFE]Sub device register "ov5640" i2c_addr = 0x78 start! [ 1621.730366] [VFE]v4l2_device_register_subdev return 0 [ 1621.730377] [VFE]registered sensor subdev is OK! [ 1621.730385] [VFE]Check sensor! [ 1621.743731] [VFE]mclk on [ 1621.860358] [VFE]mclk off [ 1621.872420] [VFE]Sub device register "ov5640" is OK! [ 1621.872804] [VFE]V4L2 device registered as video0 [ 1621.872843] [VFE]..........................vfe clk close!....................... [ 1621.872866] [VFE]probe_work_handle end! [ 1621.881727] [VFE]vfe_open [ 1621.881754] [VFE]..........................vfe clk open!....................... [ 1621.881798] [VFE]vfe_open ok [ 1621.882233] [VFE]vfe_close [ 1621.882247] [VFE]vfe select input flag = 0, s_input have not be used . [ 1621.882269] [VFE]..........................vfe clk close!....................... [ 1621.882304] [VFE]vfe_close end and grep | ov5640 [ 1613.793181] [OV5640@lex]init_sensor - frame_rate: 0, max_win_size: 11 [ 1621.742431] [OV5640@lex]CSI_SUBDEV_PWR_ON! [ 1621.810043] [OV5640@lex]sensor_init 0x0 [ 1621.848152] [OV5640@lex]write sensor in function sensor_init=OK [ 1621.849336] [OV5640@lex]sensor_init DONE - exit [ 1621.849347] [OV5640@lex]CSI_SUBDEV_STBY_ON! [ 1621.849355] [OV5640@lex]sensor_s_release_af [ 1621.860033] [OV5640@lex]disalbe oe! [ 1621.730337] [VFE]Find sensor name is "ov5640", i2c address is 78, type is "YUV" ! [ 1621.730350] [VFE]Sub device register "ov5640" i2c_addr = 0x78 start! [ 1621.872420] [VFE]Sub device register "ov5640" is OK! Then I try to streaming video with mjpg-streamer but unsuccessful dmesg | grep VFE and grep OV5640 shows [ 1737.333490] [VFE]vfe_open [ 1737.333514] [VFE]..........................vfe clk open!....................... [ 1737.333571] [VFE]vfe_open ok [ 1737.512792] [VFE_ERR]bsp_csi_set_fmt error at vidioc_s_fmt_vid_cap! [ 1737.519970] [VFE]vfe_close [ 1737.519983] [VFE]vfe select input flag = 0, s_input have not be used . [ 1737.520063] [VFE]..........................vfe clk close!....................... [ 1737.520102] [VFE]vfe_close end [ 1613.793181] [OV5640@lex]init_sensor - frame_rate: 0, max_win_size: 11 [ 1621.742431] [OV5640@lex]CSI_SUBDEV_PWR_ON! [ 1621.810043] [OV5640@lex]sensor_init 0x0 [ 1621.848152] [OV5640@lex]write sensor in function sensor_init=OK [ 1621.849336] [OV5640@lex]sensor_init DONE - exit [ 1621.849347] [OV5640@lex]CSI_SUBDEV_STBY_ON! [ 1621.849355] [OV5640@lex]sensor_s_release_af [ 1621.860033] [OV5640@lex]disalbe oe! [ 1737.333646] [OV5640@lex]sensor_s_fmt [ 1737.333658] [OV5640@lex]capture_mode: 0 - V4L2_MODE_??? [ 1737.510072] [OV5640@lex]s_fmt set width = 640, height = 480 [ 1737.512425] [OV5640@lex]** pre_div = 3,mul = 70,sys_div = 1,pll_rdiv = 2,sclk_rdiv = 2 [ 1737.512439] [OV5640@lex]read pclk = 56000000 [ 1737.512452] [OV5640@lex]pv_fps(30) = pv_pclk(56000000) / ((vts_extra(0) + vts(984)) * hts(1896)) [ 1737.512465] [OV5640@lex]pv fps = 30 - ulres = 30 Please somebody help Link to comment Share on other sites More sharing options...
Димитър Мазнеков Posted December 15, 2017 Share Posted December 15, 2017 Did you resolve that problem? I'm facing it too... Link to comment Share on other sites More sharing options...
