thanks to this tutorial:
I was able to add optical S/PDIF module to my orange pi zero plus 2 h3 - It works :)
But I noticed the the every time when a sound is played it causes the SPDIF output on the OPI to initialise (switch on the red light) which takes about 1-2 seconds, after the sound has finished the SPDIF output goes back to sleep (switch off the red light).
As a result on every new audio that is played the first 1-2 second is lost off :(
This is not a problem if I'm listening radio but in case of quick phrases spoken by the synthesizer(my case) this is a real problem.
Is there any way to keep S/PDIF output ON between sounds?
