yogesh sampath Posted June 22, 2017 Posted June 22, 2017 boot0 version : 4.0.0 set pll start set pll end rtc[0] value = 0x00000000 rtc[1] value = 0x00000000 rtc[2] value = 0x00000000 rtc[3] value = 0x00000000 rtc[4] value = 0x00000000 rtc[5] value = 0x00000000 DRAM driver version: V1.1 rsb_send_initseq: rsb clk 400Khz -> 3Mhz Set DRAM_VCC failed initializing SDRAM Fail. HELLO! BOOT0 is starting! boot0 commit : 045061a8bb2580cb3fa02e301f52a015040c158f
pfeerick Posted June 22, 2017 Posted June 22, 2017 You know, it would be really helpful if you said more than "IT DOESN'T WORK"!! For instance - which image are you using? How did you write it? What power supply did you use? Have you tried other images with the pine64? What do you have plugged into it? You know, the little details that let other people get an idea of your setup and what could be going on. Otherwise I couldn't be blamed for saying that you need to tell the hamster in the wheel driving the turbine powering your pine64 needs to run a bit faster since I honestly believe at the moment you are running your pine64 via hamster power (isn't the imagination a good thing!).
