khollan Posted October 7, 2024 Posted October 7, 2024 I am trying to get BigTreeTech Pi TFT43 display working on a Radxa Rockpi 3A I have. I put the latest Armbian image on the rockpi, but I'm at a loss as to how I configure the device tree to make the screen work. I have verified that the screen does work on a Raspberry Pi 3B+ while using BTT's instructions here, but those instructions don't seem to translate to Armbian. All other examples I have found seem to be specific to the SBC vendor's custom branches. It looks like the vdd_mipi regulator is not enabled so I guess that should be the first step, how do I enable it? Thanks for your help! 0 Quote
robertoj Posted October 7, 2024 Posted October 7, 2024 Can you get the gt911_btt_tft43_dip.dtbo source file DTS? I think there's a thread that explains how to decompile a DTBO into a DTS. In the DTS, you will find the exact kernel module needed. If you don't have it in /lib/kernel/6.xxx/kernel/drivers, you need to build an armbian image, and extract the KOs needed (look in the raspberry, run lsmod) Check out these threads: https://forum.armbian.com/topic/44191-orangepi-zero-lts-ili9341-tft-lcd-and-later-orangepi-zero-3/ https://forum.armbian.com/topic/27457-connecting-banana-pi-m2-zero-with-ili9341-display-over-spi-on-latest-armbian-image/page/2/#comments There's discussion about the thought process of making your DTS and there's a big difference between SPI and DSI... you should find examples of OTHER DSI screens I dont know why Raspberry OS uses KO parameter in the config.txt (equivalent to armbianEnv.txt), but more commonly, these parameters are passed in the DTS (creating a DTBO) Well, I see that the DTS is available, and it only refers to the touch part of the screen You will need to see how the raspberry community has made the screen work, and modify the DTS for your SBC https://forums.raspberrypi.com/viewtopic.php?t=315337 0 Quote
