Panhandle_Ponics Posted Saturday at 09:00 PM Share Posted Saturday at 09:00 PM (edited) I’m trying to help people use my Pi Hat with RPi clones and everything works, except for the DS18B20 temperature sensors. Using current versions of Armbian on both a Banana Pi M2 Zero, a Banana Pi M4 Berry, and an Orange Pi 3B, but no devices show up in /sys/bus/w1/devices. /etc/modules contains: w1-gpio w1-therm /boot/armbianEnv.txt contains: overlays=w1-gpio param_w1_pin=PA6 param_w1_pin_int_pullup=1 NOTE: PA6 is used so that it matches up with the default 1-Wire pin used on an RPi. These hats are already built, I can’t change this to a different pin. Edited Saturday at 10:47 PM by Panhandle_Ponics 0 Quote Link to comment Share on other sites More sharing options...
robertoj Posted 7 hours ago Share Posted 7 hours ago Look for successful or failure experiences in SBCs with the same ARM chip. For example, the banana pi zero m2 zero shares the same chip as the orange pi zero. Execute dmesg|grep w1 to see if the kernel module is loaded Look in the uboot messages, to see if there's an error applying the DTBO Use gpioinfo to see if PA6 is not already claimed by the kernel for something else 0 Quote Link to comment Share on other sites More sharing options...
