0xf1 Posted 6 hours ago Share Posted 6 hours ago (edited) when I switch to static IP, there is no a connection to default gateway. but when using DHCP everything works fine. $ ip route default via 192.168.88.1 dev end1 proto static metric 100 169.254.0.0/16 dev end1 scope link metric 1000 192.168.88.0/24 dev end1 proto kernel scope link src 192.168.88.32 metric 100 $ ip a 1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000 link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00 inet 127.0.0.1/8 scope host lo valid_lft forever preferred_lft forever 2: end1: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc mq state UP group default qlen 1000 link/ether 76:e2:40:53:b4:f6 brd ff:ff:ff:ff:ff:ff inet 192.168.88.32/24 brd 192.168.88.255 scope global noprefixroute end1 valid_lft forever preferred_lft forever $ ping 192.168.88.1 PING 192.168.88.1 (192.168.88.1) 56(84) bytes of data. ^C --- 192.168.88.1 ping statistics --- 4 packets transmitted, 0 received, 100% packet loss, time 3032ms Ping to another network address like 192.168.88.30 works fine. Looks like armbian-config does not save gateway and dns during configuration what am I doing wrong? Edited 6 hours ago by 0xf1 0 Quote Link to comment Share on other sites More sharing options...
0xf1 Posted 5 hours ago Author Share Posted 5 hours ago problem is solved, my router had different APR record assigned for this static IP/MAC 0 Quote Link to comment Share on other sites More sharing options...
