Orange Pi Zero 3 ili9486 TFT LCD
Go to solution Solved by WDR_s,
Starting with the DTS that worked for me in the orange pi zero 3, with ili9341:
https://forum.armbian.com/topic/44191-orangepi-zero-lts-ili9341-tft-lcd-and-later-orangepi-zero-3/?do=findComment&comment=204672
My DTS is for a customized set of pins that works for me, and it is different than/from the waveshare set of pins.
You need to change:
* file name change to: ili9486-ads7846-spi1.dts
* gpio pin selections everywhere in the DTS
* "adafruit,yx240qv29" should be "ilitek,ili9486"
* change "rotation" to "rotate"
* change "reset-gpios = <&pio N N 0>;" to "reset-gpios = <&pio N N 1>;
Then sudo armbian-add-overlay ili9486-ads7846-spi1.dts
Reboot
(does anyone know the correct DRM driver for ili9486?)
I used your DTS and modified the driver and some other things and it looked like this:
root@orangepizero3:~/testopiz3# cat ili9486-ads7846-spi1.dts
/dts-v1/;
/plugin/;
    compatible = "allwinner,sun50i-h616";
    fragment@0 {
        target = <&spi1>;
        __overlay__ {
            status = "okay";
            cs-gpios = <&pio 7 9 0>,<&pio 2 15 0>; /*PH9=CS0 for lcd, PC15=CS1 for touch*/
            ili9486: ili9486@0 {
                compatible = "ilitek,ili9486";
                reg = <0>;
                pinctrl-names = "default";
                spi-max-frequency = <24000000>;
                rotate = <270>;
                bgr = <0>;
                fps = <30>;
                buswidth = <8>;
                reset-gpios = <&pio 2 14 1>; /* PC14 */
                dc-gpios = <&pio 2 7 0>; /* PHC7 */
                debug = <3>;
            ads7846: ads7846@1 {
                compatible = "ti,ads7846";
                reg = <1>;
                spi-max-frequency = <1000000>;
                interrupt-parent = <&pio>;
                interrupts = <2 10 2>; /* PC10 - IRQ */
                pendown-gpio = <&pio 2 10 1>; /* PC10 */
                /* OPTIONS */
                ti,x-min = /bits/ 16 <0>;
                ti,y-min = /bits/ 16 <0>;
                ti,x-max = /bits/ 16 <0xFFF>;
                ti,y-max = /bits/ 16 <0xFFF>;
                ti,pressure-min = /bits/ 16 <0>;
                ti,pressure-max = /bits/ 16 <0xFFF>;
                ti,x-plate-ohms = /bits/ 16 <400>;
                ti,swap-xy = <1>;
the screen didn't turn on and I get this:
root@orangepizero3:~/testopiz3# dmesg|grep spi
[    1.336361] sun50i-h616-pinctrl 300b000.pinctrl: pin-64 (5010000.spi) status -517
[    1.336380] sun6i-spi 5010000.spi: Error applying setting, reverse things back
[    1.336625] sun50i-h616-pinctrl 300b000.pinctrl: pin-230 (5011000.spi) status -517
[    1.336642] sun6i-spi 5011000.spi: Error applying setting, reverse things back
[    1.344519] sun50i-h616-pinctrl 300b000.pinctrl: pin-64 (5010000.spi) status -517
[    1.344537] sun6i-spi 5010000.spi: Error applying setting, reverse things back
[    1.344790] sun50i-h616-pinctrl 300b000.pinctrl: pin-230 (5011000.spi) status -517
[    1.344807] sun6i-spi 5011000.spi: Error applying setting, reverse things back
[    1.353376] spi-nor spi0.0: supply vdd not found, using dummy regulator
[    1.368687] spi-nor spi0.0: spi-nor-generic (16384 Kbytes)
[    5.756110] ads7846 spi1.1: supply vcc not found, using dummy regulator
[    5.774274] ads7846 spi1.1: touchscreen, irq 72
[    5.778306] [drm] Initialized ili9486 1.0.0 20200118 for spi1.0 on minor 2
[    5.791888] spi_master spi1: noqueue transfer failed
[    5.791896] ili9486 spi1.0: [drm] *ERROR* Failed to update display -5
[    5.806250] input: ADS7846 Touchscreen as /devices/platform/soc/5011000.spi/spi_master/spi1/spi1.1/input/input4
[    6.332084] spi_master spi1: noqueue transfer failed
[    6.341922] spi_master spi1: noqueue transfer failed
[    6.343037] ili9486 spi1.0: [drm] fb0: ili9486drmfb frame buffer device
[    6.376583] SPI driver fb_ili9486 has no spi_device_id for ilitek,ili9486
[    6.392717] spi_master spi1: noqueue transfer failed
[    6.484766] spi_master spi1: noqueue transfer failed
[    6.496428] spi_master spi1: noqueue transfer failed
[    6.507222] spi_master spi1: noqueue transfer failed
[    6.524186] spi_master spi1: noqueue transfer failed
[    6.583772] spi_master spi1: noqueue transfer failed
[    6.665947] spi_master spi1: noqueue transfer failed
[    6.683600] spi_master spi1: noqueue transfer failed
[    8.071086] spi_master spi1: noqueue transfer failed
[    8.225788] spi_master spi1: noqueue transfer failed
[    8.260765] spi_master spi1: noqueue transfer failed
[    8.423577] spi_master spi1: noqueue transfer failed
[    8.455263] spi_master spi1: noqueue transfer failed
[    8.522713] spi_master spi1: noqueue transfer failed
[    8.564872] spi_master spi1: noqueue transfer failed
[    8.575518] spi_master spi1: noqueue transfer failed
[    9.074598] spi_master spi1: noqueue transfer failed
[    9.084348] spi_master spi1: noqueue transfer failed
[    9.116925] spi_master spi1: noqueue transfer failed
[    9.131941] spi_master spi1: noqueue transfer failed
[    9.144523] spi_master spi1: noqueue transfer failed
[    9.155518] spi_master spi1: noqueue transfer failed
[    9.363656] spi_master spi1: noqueue transfer failed
[    9.378223] spi_master spi1: noqueue transfer failed
[    9.391305] spi_master spi1: noqueue transfer failed
[    9.402360] spi_master spi1: noqueue transfer failed
[    9.536236] spi_master spi1: noqueue transfer failed
[    9.644439] spi_master spi1: noqueue transfer failed
[   10.144929] spi_master spi1: noqueue transfer failed
[   10.268524] spi_master spi1: noqueue transfer failed
[   10.285998] spi_master spi1: noqueue transfer failed
[   10.295763] spi_master spi1: noqueue transfer failed
[   10.610540] spi_master spi1: noqueue transfer failed
[   10.778565] spi_master spi1: noqueue transfer failed
[   11.373986] spi_master spi1: noqueue transfer failed
[   11.536724] spi_master spi1: noqueue transfer failed
[   11.615775] spi_master spi1: noqueue transfer failed
[   11.630380] spi_master spi1: noqueue transfer failed
[   11.641227] spi_master spi1: noqueue transfer failed
[   11.691254] spi_master spi1: noqueue transfer failed
[   11.727754] spi_master spi1: noqueue transfer failed
[   11.738178] spi_master spi1: noqueue transfer failed
[   12.109599] spi_master spi1: noqueue transfer failed
[   12.305293] spi_master spi1: noqueue transfer failed
[   12.664486] spi_master spi1: noqueue transfer failed
[   12.674529] spi_master spi1: noqueue transfer failed
[   13.020004] spi_master spi1: noqueue transfer failed
[   13.032088] spi_master spi1: noqueue transfer failed
[   13.042854] spi_master spi1: noqueue transfer failed
[   13.074828] spi_master spi1: noqueue transfer failed
[   13.203632] spi_master spi1: noqueue transfer failed
[   13.315447] spi_master spi1: noqueue transfer failed
[   57.093748] spi_master spi1: noqueue transfer failed
Edited by WDR_s
I see that you didnt change any gpios. You must change them... what are the pins in the orange pi zero 3 that will control the lcd? (you must have the LCD schematic)
If you try my original DTS, without having a screen like mine, do you get these 2 files?
/dev/fb0
/dev/input/event0
According to this https://mjmwired.net/kernel/Documentation/devicetree/bindings/display/ilitek,ili9486.yaml
You must use the line:
compatible = "waveshare,rpi-lcd-35", "ilitek,ili9486";
I changed a few pins and the dts looked like this:
/dts-v1/;
/plugin/;
        fragment@0 {
                target = <&spi1>;
                __overlay__ {
                        status = "okay";
                cs-gpios = <&pio 2 5 0>,<&pio 7 9 0>; /*PH5=CS0 for lcd, PH9=CS1 for touch*/
        fragment@1 {
                target = <&spi1>;
                __overlay__ {
                        /* needed to avoid dtc warning */
                        #address-cells = <1>;
                        #size-cells = <0>;
                                reg = <0>;
                                spi-max-frequency = <16000000>;
                                rotate = <90>;
                                fps = <30>;
                                buswidth = <8>;
                                regwidth = <16>;
                                bgr = <0>;
                                reset-gpios = <&pio 0 8 1>; /* PC15 */
                                dc-gpios = <&pio 0 5 0>; /* PC5*/
                                //debug = <3>;
                                init = <0x10000b0 0x00
                                        0x1000011
                                        0x20000ff
                                        0x100003a 0x55
                                        0x1000036 0x28
                                        0x10000c2 0x44
                                        0x10000c5 0x00 0x00 0x00 0x00
                                        0x10000e0 0x0f 0x1f 0x1c 0x0c 0x0f 0x08 0x48 0x98 0x37 0x0a 0x13 0x04 0x11 0x0d 0x00
                                        0x10000e1 0x0f 0x32 0x2e 0x0b 0x0d 0x05 0x47 0x75 0x37 0x06 0x10 0x03 0x24 0x20 0x00
                                        0x10000e2 0x0f 0x32 0x2e 0x0b 0x0d 0x05 0x47 0x75 0x37 0x06 0x10 0x03 0x24 0x20 0x00
                                        0x1000036 0x28
                                        0x1000011
                                        0x1000029>;
                                reg = <1>;
                                spi-max-frequency = <2000000>;
                                interrupts = <2 7 2>; /* high-to-low edge triggered */
                                pendown-gpio = <&pio 2 7 0>;
                                ti,keep-vref-on = <1>;
                                ti,x-min = /bits/ 16 <200>;
                                ti,x-max = /bits/ 16 <3900>;
                                ti,y-min = /bits/ 16 <200>;
                                ti,y-max = /bits/ 16 <3900>;
                                ti,x-plate-ohms = /bits/ 16 <60>;
                                ti,pressure-max = /bits/ 16 <255>;
                                ti,swap-xy = <1>;
the screen still doesn't give an image, but I get this:
root@orangepizero3:~# dmesg|grep spi
[ 1.329893] sun50i-h616-pinctrl 300b000.pinctrl: pin-64 (5010000.spi) status -517
[ 1.329912] sun6i-spi 5010000.spi: Error applying setting, reverse things back
[ 1.330164] sun50i-h616-pinctrl 300b000.pinctrl: pin-230 (5011000.spi) status -517
[ 1.330182] sun6i-spi 5011000.spi: Error applying setting, reverse things back
[ 1.340115] spi-nor spi0.0: supply vdd not found, using dummy regulator
[ 1.356682] spi-nor spi0.0: spi-nor-generic (16384 Kbytes)
[ 5.611681] SPI driver ads7846 has no spi_device_id for ti,tsc2046
[ 5.611706] SPI driver ads7846 has no spi_device_id for ti,ads7843
[ 5.611710] SPI driver ads7846 has no spi_device_id for ti,ads7845
[ 5.611715] SPI driver ads7846 has no spi_device_id for ti,ads7873
[ 5.612139] ads7846 spi1.1: supply vcc not found, using dummy regulator
[ 5.625190] ads7846 spi1.1: touchscreen, irq 71
[ 5.636919] input: ADS7846 Touchscreen as /devices/platform/soc/5011000.spi/spi_master/spi1/spi1.1/input/input0
[ 5.774741] SPI driver fb_ili9486 has no spi_device_id for ilitek,ili9486
[ 5.774845] fb_ili9486 spi1.0: fbtft_property_value: regwidth = 16
[ 5.774856] fb_ili9486 spi1.0: fbtft_property_value: buswidth = 8
[ 5.774863] fb_ili9486 spi1.0: fbtft_property_value: rotate = 90
[ 5.774871] fb_ili9486 spi1.0: fbtft_property_value: fps = 30
[ 5.785022] fb_ili9486 spi1.0: fbtft_property_value: regwidth = 16
[ 5.785046] fb_ili9486 spi1.0: fbtft_property_value: buswidth = 8
[ 5.785054] fb_ili9486 spi1.0: fbtft_property_value: rotate = 90
[ 5.785061] fb_ili9486 spi1.0: fbtft_property_value: fps = 30
[ 5.808854] fb_ili9486 spi1.0: fbtft_property_value: regwidth = 16
[ 5.808866] fb_ili9486 spi1.0: fbtft_property_value: buswidth = 8
[ 5.808873] fb_ili9486 spi1.0: fbtft_property_value: rotate = 90
[ 5.808881] fb_ili9486 spi1.0: fbtft_property_value: fps = 30
[ 10.844939] fb_ili9486 spi1.0: fbtft_property_value: regwidth = 16
[ 10.844949] fb_ili9486 spi1.0: fbtft_property_value: buswidth = 8
[ 10.844956] fb_ili9486 spi1.0: fbtft_property_value: rotate = 90
[ 10.844964] fb_ili9486 spi1.0: fbtft_property_value: fps = 30
[ 11.087041] fb_ili9486 spi1.0: fbtft_property_value: regwidth = 16
[ 11.087073] fb_ili9486 spi1.0: fbtft_property_value: buswidth = 8
[ 11.087083] fb_ili9486 spi1.0: fbtft_property_value: rotate = 90
[ 11.087091] fb_ili9486 spi1.0: fbtft_property_value: fps = 30
[ 21.220361] fb_ili9486 spi1.0: fbtft_property_value: regwidth = 16
[ 21.220384] fb_ili9486 spi1.0: fbtft_property_value: buswidth = 8
[ 21.220391] fb_ili9486 spi1.0: fbtft_property_value: rotate = 90
[ 21.220399] fb_ili9486 spi1.0: fbtft_property_value: fps = 30
[ 21.220581] spi spi1.0: deferred probe pending
do i have to add anything to /boot/armbianEnv.txt ? i'm in doubt!
Regarding these lines:
Make sure that you make the comments match with the actual DTS code, for example PH5=<&pio 7 5 0>, because H=7
Also according to the gpio formula, C=2.
Also insert some initial comment lines at the top, summarizing the pinout you discovered for the orange pi zero 3, to show your intermediate work
You are very close. All those spi1.0, spi1.1 dmesg messages indicate that there's no conflict internally in the CPU, but probably the one or a few IOs are connected to the incorrect pin(s).
Another thing to try is change "reset-gpios = <&pio 0 8 1>" to "reset-gpios = <&pio 0 8 0>" because sometimes different kernel modules handle the polarity in the opposite way than it is expected.
Also try changing "compatible = "ilitek,ili9486";" to "compatible = "waveshare,rpi-lcd-35";" and look at the example in https://mjmwired.net/kernel/Documentation/devicetree/bindings/display/ilitek,ili9486.yaml to find the little differences in parameters.
Keep googling this forum for ili9486, maybe someone did it already :)
How is it going with the ili9486 LCD? :)
the armbianEnv.txt only needs the user-overlay line with the dts you are using (without the dts extension)… but seeing your progress, I am sure the armbianEnv.txt is perfect as it is now
your problem might be the gpio numbers (1st and 2nd parameter in <&pio xxx xxx xxx>) and the polarity setting (3rd parameter)
DO NOT ADD ANYTHING ELSE SPI RELATED
Thanks for asking!
I'm using this dts:
/dts-v1/;
/plugin/;
        fragment@0 {
                target = <&spi1>;
                __overlay__ {
                        status = "okay";
                        spidev@0{
                                status = "disabled";
                        spidev@1{
        fragment@1 {
                target = <&pio>;
                __overlay__ {
                        ili9486_pins: ili9486_pins {
                                allwinner,pins = "PC15", "PC14";
                                allwinner,function = "gpio_in", "gpio_in";
        fragment@2 {
                target = <&spi1>;
                __overlay__ {
                        #size-cells = <0>;
                        ili9486: ili9486@0{
                                reg = <0>;
                                pinctrl-0 = <&ili9486_pins>;
                                txbuflen = <32768>;
                                rotate = <90>;
                                bgr = <0>;
                                fps = <30>;
                                buswidth = <8>;
                                regwidth = <16>;
                                reset-gpios = <&pio 0 15 1>;
                                dc-gpios = <&pio 0 14 0>;
                                debug = <0>;
                                        0x1000011
                                        0x20000ff
                                        0x100003a 0x55
                                        0x1000036 0x28
                                        0x10000c2 0x44
                                        0x1000036 0x28
                                        0x1000011
                                        0x1000029>;
Come on, even if I change the pins I still get the same thing.
[    1.329785] sun50i-h616-pinctrl 300b000.pinctrl: pin-64 (5010000.spi) status -517
[    1.329803] sun6i-spi 5010000.spi: Error applying setting, reverse things back
[    1.330040] sun50i-h616-pinctrl 300b000.pinctrl: pin-230 (5011000.spi) status -517
[    1.330057] sun6i-spi 5011000.spi: Error applying setting, reverse things back
[    1.338159] sun50i-h616-pinctrl 300b000.pinctrl: pin-64 (5010000.spi) status -517
[    1.338177] sun6i-spi 5010000.spi: Error applying setting, reverse things back
[    1.338407] sun50i-h616-pinctrl 300b000.pinctrl: pin-230 (5011000.spi) status -517
[    1.338424] sun6i-spi 5011000.spi: Error applying setting, reverse things back
[    1.346464] spi-nor spi0.0: supply vdd not found, using dummy regulator
[    1.364614] spi-nor spi0.0: spi-nor-generic (16384 Kbytes)
[    5.757805] SPI driver fb_ili9486 has no spi_device_id for ilitek,ili9486
[    5.758014] fb_ili9486 spi1.0: fbtft_property_value: regwidth = 16
[    5.758033] fb_ili9486 spi1.0: fbtft_property_value: buswidth = 8
[    5.758046] fb_ili9486 spi1.0: fbtft_property_value: debug = 0
[    5.758057] fb_ili9486 spi1.0: fbtft_property_value: rotate = 90
[    5.758070] fb_ili9486 spi1.0: fbtft_property_value: fps = 30
[    5.758081] fb_ili9486 spi1.0: fbtft_property_value: txbuflen = 32768
[    5.809159] fb_ili9486 spi1.0: fbtft_property_value: regwidth = 16
[    5.809172] fb_ili9486 spi1.0: fbtft_property_value: buswidth = 8
[    5.809179] fb_ili9486 spi1.0: fbtft_property_value: debug = 0
[    5.809185] fb_ili9486 spi1.0: fbtft_property_value: rotate = 90
[    5.809192] fb_ili9486 spi1.0: fbtft_property_value: fps = 30
[    5.809198] fb_ili9486 spi1.0: fbtft_property_value: txbuflen = 32768
[   10.473865] fb_ili9486 spi1.0: fbtft_property_value: regwidth = 16
[   10.473880] fb_ili9486 spi1.0: fbtft_property_value: buswidth = 8
[   10.473889] fb_ili9486 spi1.0: fbtft_property_value: debug = 0
[   10.473897] fb_ili9486 spi1.0: fbtft_property_value: rotate = 90
[   10.473906] fb_ili9486 spi1.0: fbtft_property_value: fps = 30
[   10.473914] fb_ili9486 spi1.0: fbtft_property_value: txbuflen = 32768
[   11.180842] fb_ili9486 spi1.0: fbtft_property_value: regwidth = 16
[   11.180863] fb_ili9486 spi1.0: fbtft_property_value: buswidth = 8
[   11.180871] fb_ili9486 spi1.0: fbtft_property_value: debug = 0
[   11.180877] fb_ili9486 spi1.0: fbtft_property_value: rotate = 90
[   11.180884] fb_ili9486 spi1.0: fbtft_property_value: fps = 30
[   11.180891] fb_ili9486 spi1.0: fbtft_property_value: txbuflen = 32768
[   21.220456] fb_ili9486 spi1.0: fbtft_property_value: regwidth = 16
[   21.220480] fb_ili9486 spi1.0: fbtft_property_value: buswidth = 8
[   21.220487] fb_ili9486 spi1.0: fbtft_property_value: debug = 0
[   21.220493] fb_ili9486 spi1.0: fbtft_property_value: rotate = 90
[   21.220501] fb_ili9486 spi1.0: fbtft_property_value: fps = 30
[   21.220507] fb_ili9486 spi1.0: fbtft_property_value: txbuflen = 32768
[   21.220809] spi spi1.0: deferred probe pending
And when I change the driver compatibility from “compatible = ‘ilitek,ili9486’;” to “compatible = ‘waveshare,rpi-lcd-35’;”, it shows this:
[    1.331757] sun50i-h616-pinctrl 300b000.pinctrl: pin-64 (5010000.spi) status -517
[    1.331776] sun6i-spi 5010000.spi: Error applying setting, reverse things back
[    1.332039] sun50i-h616-pinctrl 300b000.pinctrl: pin-230 (5011000.spi) status -517
[    1.332056] sun6i-spi 5011000.spi: Error applying setting, reverse things back
[    1.341951] spi-nor spi0.0: supply vdd not found, using dummy regulator
[    1.356645] spi-nor spi0.0: spi-nor-generic (16384 Kbytes)
[   21.992398] spi spi1.0: deferred probe pending
Every time I change the pins, the driver doesn't load correctly, it always shows me the same driver message.
this error is the wrong pins, but I haven't found a way to solve it yet.
Do you have any suggestions?
I used your dts, I just changed the drivers:
OrangePi Zero 3 -> ILI9846LCD connections
SPI CLOCK = PH6
SPI DO (LCD MISO) = PH8 (OPIZ MISO)
SPI DI (LCD MOSI) = PH7 (OPIZ MOSI)
LCD DATA/CONTROL = PC15
LCD RESET = PC10
CHIP SELECT = PH9 < NOT USED ANYMORE ;)
VCC = 3.3V PIN
GND = GND PIN
/dts-v1/;
/plugin/;
    compatible = "allwinner,sun4i-a10", "allwinner,sun7i-a20", "allwinner,sun8i-h3", "allwinner,sun50i-a64", "allwinner,sun50i-h5";
        fragment@0 {
            target = <&pio>;
            __overlay__{
                display_pins: display_pins {
                    pins = "PC8", "PC10"; /* DC, reset pins*/
                    function = "gpio_out", "gpio_out";
        fragment@1 {
        target = <&spi1>;
        __overlay__ {
            #size-cells = <0>;
            status="okay";
            pinctrl-0 = <&spi1_pins>; /* Mux the PI to make sure they are set in spi Mode */
            /*cs-gpios = <&pio 0 13 0>;  /* PA13 chip select NOT USED! */
            num-chipselects = <0>;
            display: display@0 {
                compatible = "waveshare,rpi-lcd-35","ilitek,ili9486";
                /*compatible = "ilitek,ili9486";*/
                reg = <0>;
                pinctrl-1 = <&display_pins>;
                rotation = <270>; /* rotate for ili9486, rotation for rpi-lcd-35 */
                bgr=<0>;
                fps = <15>;
                buswidth = <8>;
                reset-gpios = <&pio 2 10 0>; /* PC10 reset pin*/
                dc-gpios = <&pio 2 8 0>; /* PC8 Data control pin */
                debug = <3>;
                        0x1000011
                        0x20000ff
                        0x100003a 0x55
                        0x1000036 0x28
                        0x10000c2 0x44
                        0x1000036 0x28
                        0x1000011
                        0x1000029>;
    __overrides__ {
        rotate =  <&display>,"rotate:0";
        fps =     <&display>,"fps:0";
        debug =   <&display>,"debug:0";
i knew it wouldn't work, but it starts the driver on your dts.
[    1.331860] sun50i-h616-pinctrl 300b000.pinctrl: pin-64 (5010000.spi) status -517
[    1.331878] sun6i-spi 5010000.spi: Error applying setting, reverse things back
[    1.332144] sun50i-h616-pinctrl 300b000.pinctrl: pin-230 (5011000.spi) status -517
[    1.332162] sun6i-spi 5011000.spi: Error applying setting, reverse things back
[    1.342085] spi-nor spi0.0: supply vdd not found, using dummy regulator
[    1.356632] spi-nor spi0.0: spi-nor-generic (16384 Kbytes)
[    5.826794] [drm] Initialized ili9486 1.0.0 20200118 for spi1.0 on minor 2
[    5.846062] spi_master spi1: noqueue transfer failed
[    5.846070] ili9486 spi1.0: [drm] *ERROR* Failed to update display -5
[    6.392853] spi_master spi1: noqueue transfer failed
[    6.401813] spi_master spi1: noqueue transfer failed
[    6.402930] ili9486 spi1.0: [drm] fb0: ili9486drmfb frame buffer device
[    6.493015] spi_master spi1: noqueue transfer failed
[    6.601019] spi_master spi1: noqueue transfer failed
[    6.612073] spi_master spi1: noqueue transfer failed
[    6.623854] spi_master spi1: noqueue transfer failed
[    6.641744] spi_master spi1: noqueue transfer failed
[    6.751695] spi_master spi1: noqueue transfer failed
[    6.846563] spi_master spi1: noqueue transfer failed
[    6.880841] spi_master spi1: noqueue transfer failed
[    6.891036] spi_master spi1: noqueue transfer failed
[    6.904580] spi_master spi1: noqueue transfer failed
[    6.914475] spi_master spi1: noqueue transfer failed
[    7.142242] spi_master spi1: noqueue transfer failed
[    7.226228] spi_master spi1: noqueue transfer failed
[    7.268840] spi_master spi1: noqueue transfer failed
[    9.517124] spi_master spi1: noqueue transfer failed
[   10.039018] spi_master spi1: noqueue transfer failed
[   10.232173] spi_master spi1: noqueue transfer failed
[   10.275680] spi_master spi1: noqueue transfer failed
[   10.690564] spi_master spi1: noqueue transfer failed
[   10.731026] spi_master spi1: noqueue transfer failed
[   10.805702] spi_master spi1: noqueue transfer failed
[   10.858116] spi_master spi1: noqueue transfer failed
[   10.871689] spi_master spi1: noqueue transfer failed
[   10.907571] spi_master spi1: noqueue transfer failed
[   11.375140] spi_master spi1: noqueue transfer failed
[   11.384944] spi_master spi1: noqueue transfer failed
[   11.420367] spi_master spi1: noqueue transfer failed
[   11.433719] spi_master spi1: noqueue transfer failed
[   11.445033] spi_master spi1: noqueue transfer failed
[   11.456640] spi_master spi1: noqueue transfer failed
[   11.544898] spi_master spi1: noqueue transfer failed
[   11.559093] spi_master spi1: noqueue transfer failed
[   11.579468] spi_master spi1: noqueue transfer failed
[   11.591184] spi_master spi1: noqueue transfer failed
[   11.625091] spi_master spi1: noqueue transfer failed
[   11.644903] spi_master spi1: noqueue transfer failed
[   11.656759] spi_master spi1: noqueue transfer failed
[   11.668277] spi_master spi1: noqueue transfer failed
[   11.679463] spi_master spi1: noqueue transfer failed
[   11.839080] spi_master spi1: noqueue transfer failed
[   11.944803] spi_master spi1: noqueue transfer failed
[   12.044634] spi_master spi1: noqueue transfer failed
[   12.129035] spi_master spi1: noqueue transfer failed
[   12.311136] spi_master spi1: noqueue transfer failed
[   12.711328] spi_master spi1: noqueue transfer failed
[   12.743744] spi_master spi1: noqueue transfer failed
[   12.754734] spi_master spi1: noqueue transfer failed
[   13.128266] spi_master spi1: noqueue transfer failed
[   13.377586] spi_master spi1: noqueue transfer failed
[   13.550212] spi_master spi1: noqueue transfer failed
[   13.750005] spi_master spi1: noqueue transfer failed
[   14.008841] spi_master spi1: noqueue transfer failed
[   14.074675] spi_master spi1: noqueue transfer failed
[   14.085395] spi_master spi1: noqueue transfer failed
[   14.095476] spi_master spi1: noqueue transfer failed
[   14.110914] spi_master spi1: noqueue transfer failed
[   14.158867] spi_master spi1: noqueue transfer failed
[   14.204317] spi_master spi1: noqueue transfer failed
[   14.214390] spi_master spi1: noqueue transfer failed
[   15.225220] spi_master spi1: noqueue transfer failed
[   16.014905] spi_master spi1: noqueue transfer failed
[   16.024943] spi_master spi1: noqueue transfer failed
[   16.106431] spi_master spi1: noqueue transfer failed
[   16.120397] spi_master spi1: noqueue transfer failed
[   16.131900] spi_master spi1: noqueue transfer failed
[   16.168199] spi_master spi1: noqueue transfer failed
[   16.184874] spi_master spi1: noqueue transfer failed
[   16.219440] spi_master spi1: noqueue transfer failed
[   16.256967] spi_master spi1: noqueue transfer failed
[   16.315349] spi_master spi1: noqueue transfer failed
Edited by WDR_s
Hello.
On this screen you need CS, when connected directly to the board, using dupont I'm not sure because I don't have it.
The driver will only load if reset and dc are set to 2.
At the moment that's all I've found, but it still gives an error when it loads the driver, so I'm trying to solve it.
reset-gpios = <&pio 2 0 0>:
dc-gpios = <&pio 2 0 0>:
Those 2 lines contradict each other: both reset and dc (data/command) cant be the same.
Can you send a drawing of the wiring between the orange pi zero and the LCD display? (in terms of SPI-MISO, MOSI, DC, RESET, LED, etc, and the DTS you have just tried?
I know that, I was just giving an example.
it should be like this: <&pio 2 N N>:
I'm currently using this one:
/dts-v1/;
/plugin/;
    fragment@0 {
        target = <&spi1>;
        __overlay__ {
            status = "okay";
        cs-gpios = <&pio 2 9 0>,<&pio 7 15 0>; /*PH9=CS0 for lcd, PC15=CS1 for touch*/
                reg = <0>;
                rotation = <270>;
                bgr = <0>;
                fps = <30>;
                buswidth = <8>;
                reset-gpios = <&pio 2 14 0>; /* PC14 */
                debug = <3>;
Hi WDR_s, did you manage to make any progress. if you are still getting the pinctrl errors as shown above the problems relate to PC0 (Pin 64) and PH6 (Pin 230). Are you running any addtional overlays? Can you check sudo cat /sys/kernel/debug/gpio to ensure the pins are not being used elsewhere?
Best of luck
Ryzer
WDR_s, can you check if the manufacturer actually says ili9486? I have an LCD from aliexpress, which claims it is ili9486, but deeper in the webpage it reads st7796s... and someone complained it is actually ili9488.
Maybe you havent identified correctly the LCD controller ilitek chip.
Here are other things we can try for the ili9486, ili9488 or st7796, using the panel-mipi-dbi-spi driver (changing the raspberry pi methods into armbian methods)
https://forums.raspberrypi.com/viewtopic.php?t=376047
https://forums.raspberrypi.com/viewtopic.php?t=358240&hilit=Ili9341#p2165638
https://github.com/notro/panel-mipi-dbi/wiki
https://gitlab.freedesktop.org/drm/misc/kernel/-/blob/drm-misc-next/Documentation/devicetree/bindings/display/panel/panel-mipi-dbi-spi.yaml?ref_type=heads
Thank you for answering...
What did you do, when you thought you had an ili9488 LCD?
in the raspberry forum, someone told me that st7796s is not the same as ili9488… but I found that the ili9341 driver with a slight modification could be made into a ili9488 driver
Hi, I'm back, now I'm trying once again to connect the screen to the orange pi zero 3.
I was looking at this link, panel-mipi-dbi-spi, it doesn't work on the ili9486, but it works on the ili9341, so I would have to modify the ili9486 to the ili9341.
I'll try that now .
I now have the dupont wires.
Edited by WDR_s
I'm making progress with the dts I've modified:
/dts-v1/;
/plugin/;
    fragment@0 {
        target = <&spi1>;
        __overlay__ {
            status = "okay";
            cs-gpios = <&pio 7 5 0>,<&pio 2 15 0>; /*PH5=CS0 for lcd, PC15=CS1 for touch*/
                compatible = "ilitek,ili9341";
                //comoatible = "ilitek,ili9486";
                reg = <0>;
                spi-max-frequency = <25000000>;
                //txbuflen = <32768>;
                rotate = <90>;
                bgr = <0>;
                fps = <30>;
                buswidth = <8>;
                regwidth = <8>;
                height = <320>;
                width = <480>;
                dc-gpios = <&pio 2 6 0>; /* PC6 */
                debug = <3>;
                init = <0x10000b0 0x00 // Interface Mode Control
                        0x1000011 // Sleep Out
                        0x20000ff // Delay 255ms
                        0x100003a 0x55 // Pixel Format (55h = 16 bits/pixel)
                        0x1000036 0x48 // Memory Access Control
                        0x10000c2 0x44 // Power Control 3
                        0x10000c5 0x00 0x00 0x00 0x00 // VCOM Control 1
                        0x10000e0 0x0f 0x31 0x2b 0x0c 0x0e 0x08 0x4e 0xf1 0x37 0x07 0x10 0x03 0x0e 0x09 0x00 // Gamma C>                        0x10000e1 0x00 0x0e 0x14 0x03 0x11 0x07 0x31 0xc1 0x48 0x08 0x0f 0x0c 0x31 0x36 0x0f // Frame R>
                        0x10000b1 0x00 0x1F  // 30Hz
                        0x10000b6 0x0A 0x82 0x27 0x00 // Display Function Control
                        0x1000011 // Exit Sleep Mode
                        0x1000029 // Display ON
                        0x20000ff>;  // Delay 255ms
I got this image, but I have to modify it a bit more.
Edited by WDR_s
Nice progress.
I think that your SPI, DC, CS, RESET configurations are correct. DONT CHANGE THOSE :)
Regarding the ili9341 vs ili9486 driver... hopefully you will find an example using the ilitek,ili9486 driver, with a correct init parameter.
(check that the init is the same as the people having success in https://forum.armbian.com/topic/11701-35-lcd-ili9486-with-orange-pi-zero/#comment-86679 )
With the correct init parameter, you configure the LCD to receive the data in the correct pixel format and ordering, to match the format sent by the CPU. Also, it configures VCOM, a key parameter that I think is electrical and not data related... read the LCD manual, I can't remember what it is for.
Search for ili9486 in the raspberry pi forum. Maybne someone figured it out already.
Here's how I used the mipi driver for the ili9488, based on someone's success with Raspberry Pi https://forum.armbian.com/topic/47971-driving-the-ili9488-lcd-40-inch-cheap-chinese-clone/#findComment-207964
LCD working, modifying it to work on the ili9341 drriver, with this DTS. Now it's time to get the touch working too.
/dts-v1/;
/plugin/;
    fragment@0 {
        target = <&spi1>;
        __overlay__ {
            status = "okay";
            cs-gpios = <&pio 7 5 0>,<&pio 2 15 0>; /* PH5=CS0 for LCD, PC15=CS1 for touch */
            display: display@1 {
                //compatible = "ilitek,ili9486";
                reg = <0>;
                txbuflen = <65536>;
                rotate = <90>;
                bgr = <0>;
                fps = <30>;
                buswidth = <8>;
                regwidth = <16>;
                height = <480>;
                width = <320>;
                debug = <3>;
                        0x20000ff  // Delay (255ms)
                        0x10000C0 0x0D 0x0D  // Power Control 1
                        0x10000C1 0x43  // Power Control 2
                        0x10000C5 0x00 0x48 0x80  // VCOM Control 1
                        0x10000C7 0x00  // VCOM Control 2
                        0x1000036 0x28  // Memory Access Control (Rotação)
                        0x100003A 0x55  // Pixel Format Set (16bit)
                        0x10000B1 0xB0 0x11  // Frame Rate Control
                        0x10000F0 0x01 // Enable Extended Comand Set
                        0x10000F6 0x00 0x01 0x32 // SPI ilInterface Control
                        0x1000026 0x01 // Gamma Set
                        0x10000E0 0x0F 0x31 0x2B 0x0C 0x0E 0x08 0x4E 0xF1 0x37 0x07 0x10 0x03 0x0E 0x09 0x00  // Positive Gamma Correction
                        0x10000E1 0x00 0x0E 0x14 0x03 0x11 0x07 0x31 0xC1 0x48 0x08 0x0F 0x0C 0x31 0x36 0x0F  // Negative Gamma Correction
                        0x10000B6 0x02 0x02 0x3B  // Display Function Control
                        0x1000029>; // Display ON
Edited by WDR_s
Great :)
Does the opiz3 fit well under this LCD?
Are you still going to modify the DTS to plug the LCD directly on the OPIZ3?
There are 2 ways that the touch IC is connected: same SPI bus, and separate SPI bus... which one is it for this LCD?
If it is the same SPI bus, refer my ili9488 thread as a base
If it needs a separate SPI bus, see my ili9341 thread, and search for gpio-spi... I can't make this work in opiz3 yet, only opiz
Before trying the touch, I wanted to test something else and it worked.
Now connected directly to the orange pi zero 3.
The ones above were with dupont wires, but I'm not sure if the touch will work.
/dts-v1/;
/plugin/;
    fragment@0 {
        target = <&spi1>;
        __overlay__ {
            status = "okay";
            cs-gpios = <&pio 7 9 0>,<&pio 2 15 0>; /* PH5=CS0 for LCD, PC15=CS1 for touch */
                reg = <0>;
                txbuflen = <65536>;
                rotate = <90>;
                bgr = <0>;
                fps = <30>;
                buswidth = <8>;
                regwidth = <16>;
                height = <480>;
                width = <320>;
                reset-gpios = <&pio 2 7 1>; /* PC7 */
                dc-gpios = <&pio 2 14 0>; /* PC14 */
                debug = <3>;
I had to change the CS, RESET and DC.
Before
After
Orangepi had the good idea to make the SPI pins match the Raspberry Pi pins :)
I read somewhere that the mipi-dbi driver doesn't have the rotate/rotation parameter... I guess I need a different initialization byte sequence for the LCD to do the rotation. Or does anyone know that there's a rotation parameter?
