Orange Pi Zero 3 ili9486 TFT LCD
Go to solution Solved by WDR_s,
  • Solution
LCD and Touch working 😊
All that's left is to calibrate it, but it's working normally.
Thank you, robertoj, for helping me so far.
Updated DTS
Spoiler
/dts-v1/;
/plugin/;
    compatible = "allwinner,sun50i-h616";
    fragment@0 {
        target = <&spi1>;
        __overlay__ {
            status = "okay";
        cs-gpios = <&pio 7 5 0>,<&pio 2 15 0>; /*PH5=CS0 for lcd, PC15=CS1 for touch*/
            display: display@0 {
                compatible = "ilitek,ili9341";
                reg = <0>;
                pinctrl-names = "default";
                spi-max-frequency = <20000000>;
                rotate = <270>;
                bgr = <0>;
                fps = <30>;
                buswidth = <8>;
                regwidth = <16>;
                height = <480>;
                width = <320>;
                reset-gpios = <&pio 2 14 1>; /* PC14 */
                dc-gpios = <&pio 2 6 0>; /* PC6 */
                debug = <3>;
                init = <0x10000b0 0x00 // Interface Mode Control
                        0x1000011  // Sleep Out
                        0x20000ff  // Delay (255ms)
                        0x10000C0 0x0D 0x0D  // Power Control 1
                        0x10000C1 0x43  // Power Control 2
                        0x10000C5 0x00 0x48 0x80  // VCOM Control 1
                        0x10000C7 0x00  // VCOM Control 2
                        0x1000036 0x28  // Memory Access Control (Rotação)
                        0x100003A 0x55  // Pixel Format Set (16bit)
                        0x10000B1 0xB0 0x11  // Frame Rate Control
                        0x10000F0 0x01 // Enable Extended Comand Set
                        0x10000F6 0x00 0x01 0x32 // SPI ilInterface Control
                        0x1000026 0x01 // Gamma Set
                        0x10000E0 0x0F 0x31 0x2B 0x0C 0x0E 0x08 0x4E 0xF1 0x37 0x07 0x10 0x03 0x0E 0x09 0x00  // Positive Gamma Correction
                        0x10000E1 0x00 0x0E 0x14 0x03 0x11 0x07 0x31 0xC1 0x48 0x08 0x0F 0x0C 0x31 0x36 0x0F  // Negative Gamma Correction
                        0x10000B6 0x02 0x02 0x3B  // Display Function Control
                        0x1000029>; // Display ON
            ads7846: ads7846@1 {
                compatible = "ti,ads7846";
                reg = <1>;
                spi-max-frequency = <1000000>;
                interrupt-parent = <&pio>;
                interrupts = <2 10 2>; /* PC10 - IRQ */
                pendown-gpio = <&pio 2 10 1>; /* PC10 */
                /* OPTIONS */
                ti,x-min = /bits/ 16 <0>;
                ti,y-min = /bits/ 16 <0>;
        ti,x-max = /bits/ 16 <0xFFF>;
        ti,y-max = /bits/ 16 <0xFFF>;
                ti,pressure-min = /bits/ 16 <0>;
                ti,pressure-max = /bits/ 16 <0xFFF>;
                ti,x-plate-ohms = /bits/ 16 <400>;
                ti,swap-xy = <1>;
running directly on the board, the LCD and Touch, in this dts:
Spoiler
/dts-v1/;
/plugin/;
    fragment@0 {
        target = <&spi1>;
        __overlay__ {
            status = "okay";
        cs-gpios = <&pio 7 5 0>,<&pio 2 10 0>; /*PH5=CS0 for lcd, PC10=CS1 for touch*/
                reg = <0>;
                rotate = <270>;
                bgr = <0>;
                fps = <30>;
                buswidth = <8>;
                regwidth = <16>;
                height = <480>;
                width = <320>;
                reset-gpios = <&pio 2 7 1>; /* PC7 */
                dc-gpios = <&pio 2 14 0>; /* PC14 */
                debug = <3>;
                reg = <1>;
                interrupts = <2 6 2>; /* PC6 - IRQ */
                pendown-gpio = <&pio 2 6 1>; /* PC6 */
                /* OPTIONS */
                ti,swap-xy = <1>;
Nicely done!!
How are you going to use it? X11? Wayland? What window manger and desktop?
Is your mouse cursor jumpy or stable? Is there RGB noise when you drag windows on the desktop?
I have those issues. My setup: orange pi zero3, ili9488, drm, x11, openbox and idesk.
I wonder if my problem comes from sharing the SPI bus with 2 chip selects... but if you have one SPI and 2 chip selects, but no noise problems, then SPI is not my problem.
i installed xfce to test the touch, the touch is stable when dragging the window there is a noise, but i think it's because of the frequency.
maybe I can help you.
Do you use x11's evdev component? Does it make any difference of stability before and after running xcalibrate/xinput_calibrator?
I find that xinput_calibrator does not do anything toward pressure sensitivity. I need to make it less sensitive... anyone knows a good way of doing this?
I also felt that xinput_calibration didn't change anything.
I was configuring it here, because the touch didn't reach the corner of the LCD and it was stable, but now it's shaking too, but now the touch reaches the corner of the screen.
So it's probably just the settings, I'll see if I can sort it out.
For touch calibration, the straighforward intuitive way does not work.
Try this procedure: https://forum.armbian.com/topic/44191-orangepi-zero-lts-ili9341-tft-lcd-and-later-orangepi-zero-3/#findComment-204741
The copy location /etc/X11/xorg.conf.d/ might be different. The xinput calibration text output will tell you that directory.
The DTS also has some pressure and resistivity parameters, but I don't know how they work exactly.
My 60 MHz SPI connection is 1 m long, the cable was made with a CAT5 ethernet cable.
The problem was reduced by making a 50 cm cable.
Maybe I need termination resistors too. I could start with 1000ohms between MOSI and GND in the LCD wire ends. If it doesn't work, reduce the resistance, until I don't see noise.
Posted (edited)
i dont know if this is new, but i see a ili9486 driver in the kernel config, which is unselected by default.
Warning.... I just looked at some of the code in the linux mailing list discussion, and it looks like it is made specifically for 2 raspberry LCD hats
* PISCREEN 3.5" 320x480 TFT (Ozzmaker 3.5")
* RPILCD 3.5" 320x480 TFT (Waveshare 3.5")
Which have a SPI->parallel chip on the circuitboard
https://patchwork.kernel.org/project/dri-devel/patch/eb5672abbdb89d7018793c76d7193bfb78a2ea88.1580059987.git.kamlesh.gurudasani@gmail.com/
WDR_s: are you still having good experience with the ili9341 driver for the ili9486 LCD?
Edited by robertoj
Posted (edited)
I was missing because I was testing the ili9486.
So, I used the conversion from ili9341 to ili9486, for a while and it worked well, however, it was slow because it did not support more than 21mhz, so I tried to make the ili9486 work, after a few days I managed to make it work, but I had to disable the “dma-names” because it was making the screen not update, I am now using the ili9486 at 48mhz, working well.
I'm using the LCD directly on the board.
Edited by WDR_s
Thank you... that is what I need: a 480x320 LCD that works with a driver other than panel-mipi-dbi
Do you keep having problems with cursor shakiness? Any screen redraw "garble"?
my dts for reference:
Spoiler
/dts-v1/;
/plugin/;
    fragment@0 {
        target = <&spi1>;
        __overlay__ {
            status = "okay";
        dma-names = "";
        cs-gpios = <&pio 7 9 0>,<&pio 2 10 0>; /*PH9=CS0 for lcd, PC15=CS1 for touch*/
            ili9486: ili9486@0 {
                compatible = "waveshare,rpi-lcd-35";
                reg = <0>;
                spi-max-frequency = <46000000>;
                rotate = <270>;
                bgr = <0>;
                fps = <30>;
                buswidth = <8>;
                reset-gpios = <&pio 2 7 0>; /* PC7 */
                debug = <3>;
                reg = <1>;
                /* OPTIONS */
                ti,swap-xy = <1>;
        ti,invert-x = <0>;
        ti,invert-y = <1>;
my touch is still shaking, but I was focusing on the lcd, I'll try the touch later.
It is too bad that the cursor is shaking even if the driver panel-mipi-dbi is not used....
Now I have a feeling that using a separate software SPI for touch would be the best solution.
I will get an ili9486 soon, but it is different to yours: it has a red PCB and does not have the serial-to-parallel chip like those made for raspberry.
Posted (edited)
Hi! I'm trying to make it work too!
How should I name your DTS file from April 3? And then, after copying it, should I run the armbian-add-overlay command and reboot? That's it? I don't need to change Armbian Env?
Thanks for your help!
Edited by pithecantrope
pithecanthrope,
That DTS is specific for the raspberry pi lcd... not for the red pcb ili9486. Do you have that?
You can name the DTS any filename, for example ~/ili9486/ili9486-35.dts
cd ~/ili9486-35
sudo armbian-add-overlay ili9486-35.dts
The command will also add it to armbianEnv.txt
Make sure to not add any other overlays related to SPI
It is very nice that the raspberry pi lcd doesn't need us to fabricate a custom cable, just plug it in the correct orientation.
Are you using Linux 6.12?
Posted (edited)
robertoj,
Thanks for your answer! I have raspberry pi LCD 3.5 inch https://www.waveshare.com/wiki/3.5inch_RPi_LCD_(A)Yes, I'm using Linux 6.12.23. I did like you said. Used latest DTS (April 3). Display is still white :(My armbianEnv:
verbosity=1
bootlogo=false
console=both
disp_mode=1920x1080p60
rootdev=UUID=6b7fd251-3dcf-4583-9378-223fcd52e8db
rootfstype=ext4
user_overlays=ili9486-35
usbstoragequirks=0x2537:0x1066:u,0x2537:0x1068:u
My dmesg: [ 1.524875] sun4i-drm display-engine: bound 1100000.mixer (ops 0xffff80008121b478)
[ 1.525068] sun4i-drm display-engine: bound 6510000.tcon-top (ops 0xffff800081220248)
[ 1.525400] sun4i-drm display-engine: bound 6515000.lcd-controller (ops 0xffff800081218098)
[ 1.526527] sun4i-drm display-engine: bound 6000000.hdmi (ops 0xffff80008121a540)
[ 1.527009] [drm] Initialized sun4i-drm 1.0.0 for display-engine on minor 0
[ 1.710803] sun4i-drm display-engine: [drm] fb0: sun4i-drmdrmfb frame buffer device
[ 1.729347] sun6i-spi 5010000.spi: Error applying setting, reverse things back
[ 1.729724] sun6i-spi 5011000.spi: Failed to request TX DMA channel
[ 1.729735] sun6i-spi 5011000.spi: Failed to request RX DMA channel
[ 1.729803] ili9486@0 enforce active low on GPIO handle
[ 1.729841] sun6i-spi 5011000.spi: cannot register SPI host
[ 1.736253] sun6i-spi 5010000.spi: Error applying setting, reverse things back
[ 1.736622] sun6i-spi 5011000.spi: Failed to request TX DMA channel
[ 1.736634] sun6i-spi 5011000.spi: Failed to request RX DMA channel
[ 1.736686] ili9486@0 enforce active low on GPIO handle
[ 1.736721] sun6i-spi 5011000.spi: cannot register SPI host
[ 1.744337] spi-nor spi0.0: supply vdd not found, using dummy regulator
[ 1.773831] sun6i-spi 5011000.spi: Failed to request TX DMA channel
[ 1.773862] sun6i-spi 5011000.spi: Failed to request RX DMA channel
[ 1.773934] ili9486@0 enforce active low on GPIO handle
[ 5.476562] systemd[1]: Starting modprobe@drm.service - Load Kernel Module drm...
[ 5.545342] systemd[1]: modprobe@drm.service: Deactivated successfully.
[ 5.546346] systemd[1]: Finished modprobe@drm.service - Load Kernel Module drm.
[ 6.742260] ads7846 spi1.1: supply vcc not found, using dummy regulator
[ 6.742814] ads7846 spi1.1: touchscreen, irq 73
[ 6.743326] input: ADS7846 Touchscreen as /devices/platform/soc/5011000.spi/spi_master/spi1/spi1.1/input/input6
[ 6.760484] [drm] Initialized ili9486 1.0.0 for spi1.0 on minor 1
[ 6.762759] ili9486 spi1.0: [drm] fb1: ili9486drmfb frame buffer device
[ 6.913940] [drm] Initialized panfrost 1.2.0 for 1800000.gpu on minor 2
Posted (edited)
Try again with Linux 6.10 or older if you have an armbian img.
Two things I found needed for linux 6.12+:
1. Define the pinctrl-names and pinctrl-0 parameters
2. MAYBE: rebuild Armbian in your computer, with one less Armbian patch
As seen in:
https://forum.armbian.com/topic/47971-driving-the-ili9488-lcd-40-inch-cheap-chinese-clone/#findComment-216779
In this thread, you can see how I detected miscofigurations of the SPI GPIO:
https://forum.armbian.com/topic/50418-dont-use-kernel-61216-on-sunxi64/page/2/#findComment-216924
WDR_s: did you try upgrading to Linux 6.12? (you could get H264 acceleration if you upgrade)
Edited by robertoj
Hi all, I was quickly able to get the 3.5inch RPi LCD (B) working with an Orange Pi Zero 2W, but the colors are all wrong, it seems that it wants BGR.
Any hints where to change color order? I could not find anything for the DTS. Using this driver with following DTS:
Spoiler
/dts-v1/;
/plugin/;
    fragment@0 {
        target = <&spi1>;
        __overlay__ {
            status = "okay";
            cs-gpios = <&pio 7 5 0>;
                compatible = "waveshare,rpi-lcd-35", "ilitek,ili9486";
                reg = <0>;
                spi-max-frequency = <32000000>;
                reset-gpios = <&pio 8 6 0>;
                dc-gpios = <&pio 7 4 0>;
                rotation = <180>;
Spoiler
