CONQ Posted November 13, 2024 Posted November 13, 2024 I builded u-boot for orangepi3B from https://github.com/orangepi-xunlong/orangepi-build repo and I compiled armbian with officiall repo wit this config:https://github.com/armbian/build/blob/main/config/boards/orangepi3b.csc GitHub (https://github.com/orangepi-xunlong/orangepi-build). Problem: Data: - Version (branch) u-boot cloned form orangepi-build official repo: - Debug via UART from OPI3B: CONQ., [13.11.2024 10:14] DDR Version V1.10 20210810 ln ddrconfig:7 LPDDR4X, 324MHz BW=32 Col=10 Bk=8 CS0 Row=17 CS1 Row=17 CS=2 Die BW=8 Size=8192MB tdqss: cs0 dqs0: -72ps, dqs1: -168ps, dqs2: -96ps, dqs3: -168ps, tdqss: cs1 dqs0: -72ps, dqs1: -144ps, dqs2: -96ps, dqs3: -168ps, change to: 324MHz PHY drv:clk:36,ca:36,DQ:29,odt:60 vrefinner:16%, vrefout:41% dram drv:40,odt:0 clk skew:0x64 change to: 528MHz PHY drv:clk:36,ca:36,DQ:29,odt:60 vrefinner:16%, vrefout:41% dram drv:40,odt:0 clk skew:0x58 change to: 780MHz PHY drv:clk:36,ca:36,DQ:29,odt:60 vrefinner:16%, vrefout:41% dram drv:40,odt:0 clk skew:0x58 change to: 1056MHz(final freq) PHY drv:clk:36,ca:36,DQ:29,odt:60 vrefinner:16%, vrefout:22% dram drv:40,odt:80 vref_ca:00000071 clk skew:0x46 cs 0: the read training result: DQS0:0x40, DQS1:0x3d, DQS2:0x44, DQS3:0x3b, min : 0xf 0x10 0x10 0x10 0x2 0x3 0x6 0x6 , 0x5 0x6 0x4 0x2 0xa 0xd 0xe 0xf , 0x2 0x1 0xf 0x11 0xe 0xc 0xe 0xd , 0x6 0x5 0x9 0x1 0xb 0xd 0xc 0xd , mid :0x2a 0x2a 0x2c 0x2b 0x20 0x21 0x24 0x24 ,0x23 0x25 0x22 0x20 0x27 0x2c 0x2e 0x2d , 0x22 0x22 0x2f 0x2e 0x2b 0x2b 0x2c 0x2a ,0x22 0x22 0x27 0x1e 0x2a 0x2a 0x2a 0x2a , max :0x46 0x44 0x49 0x46 0x3e 0x40 0x42 0x43 ,0x42 0x45 0x41 0x3f 0x44 0x4c 0x4e 0x4b , 0x43 0x43 0x4f 0x4c 0x49 0x4b 0x4a 0x48 ,0x3f 0x3f 0x46 0x3c 0x4a 0x47 0x48 0x47 , range:0x37 0x34 0x39 0x36 0x3c 0x3d 0x3c 0x3d ,0x3d 0x3f 0x3d 0x3d 0x3a 0x3f 0x40 0x3c , 0x41 0x42 0x40 0x3b 0x3b 0x3f 0x3c 0x3b ,0x39 0x3a 0x3d 0x3b 0x3f 0x3a 0x3c 0x3a , the write training result: DQS0:0x3d, DQS1:0x30, DQS2:0x3a, DQS3:0x30, min :0x59 0x5b 0x5c 0x5c 0x51 0x52 0x54 0x5a 0x58 ,0x4a 0x4d 0x49 0x47 0x4f 0x53 0x55 0x55 0x51 , 0x4a 0x4b 0x54 0x55 0x53 0x53 0x56 0x57 0x56 ,0x4b 0x4c 0x4e 0x49 0x53 0x53 0x53 0x53 0x4d , mid :0x75 0x76 0x76 0x77 0x69 0x6a 0x6d 0x72 0x70 ,0x66 0x64 0x62 0x61 0x68 0x6d 0x6d 0x70 0x6b , 0x65 0x62 0x6f 0x71 0x6c 0x6b 0x6e 0x6e 0x6e ,0x65 0x63 0x67 0x60 0x6c 0x6c 0x6d 0x6c 0x64 , max :0x92 0x91 0x91 0x92 0x82 0x83 0x87 0x8b 0x89 ,0x83 0x7c 0x7c 0x7c 0x81 0x87 0x86 0x8b 0x85 , 0x80 0x7a 0x8b 0x8d 0x86 0x84 0x86 0x86 0x87 ,0x80 0x7b 0x80 0x78 0x86 0x86 0x87 0x85 0x7c , range:0x39 0x36 0x35 0x36 0x31 0x31 0x33 0x31 0x31 ,0x39 0x2f 0x33 0x35 0x32 0x34 0x31 0x36 0x34 , 0x36 0x2f 0x37 0x38 0x33 0x31 0x30 0x2f 0x31 ,0x35 0x2f 0x32 0x2f 0x33 0x33 0x34 0x32 0x2f , cs 1: the read training result: DQS0:0x42, DQS1:0x3c, DQS2:0x44, DQS3:0x3c, min : 0xf 0xf 0xf 0x10 0x1 0x2 0x5 0x7 , 0x5 0x6 0x3 0x1 0x9 0xd 0xe 0xf , 0x3 0x1 0xf 0xf 0xd 0xb 0xe 0xc , 0x6 0x6 0x9 0x1 0xa 0xd 0xd 0xb , mid :0x2c 0x2c 0x2e 0x2d 0x21 0x23 0x24 0x27 ,0x22 0x26 0x21 0x1f 0x26 0x2c 0x2d 0x2f , 0x22 0x22 0x2f 0x2e 0x2b 0x2b 0x2c 0x2a ,0x23 0x23 0x28 0x1f 0x2a 0x2b 0x2b 0x29 , max :0x4a 0x49 0x4e 0x4a 0x41 0x44 0x44 0x48 ,0x40 0x46 0x40 0x3d 0x44 0x4c 0x4c 0x4f , 0x42 0x44 0x4f 0x4d 0x49 0x4b 0x4b 0x49 ,0x41 0x41 0x47 0x3e 0x4a 0x4a 0x4a 0x47 , range:0x3b 0x3a 0x3f 0x3a 0x40 0x42 0x3f 0x41 ,0x3b 0x40 0x3d 0x3c 0x3b 0x3f 0x3e 0x40 , 0x3f 0x43 0x40 0x3e 0x3c 0x40 0x3d 0x3d ,0x3b 0x3b 0x3e 0x3d 0x40 0x3d 0x3d 0x3c , the write training result: DQS0:0x3d, DQS1:0x30, DQS2:0x3a, DQS3:0x30, min :0x5a 0x5c 0x5d 0x5c 0x53 0x53 0x55 0x5b 0x57 ,0x4e 0x50 0x4c 0x4b 0x53 0x59 0x59 0x5a 0x55 , 0x4b 0x4b 0x55 0x55 0x55 0x55 0x57 0x58 0x57 ,0x4a 0x4c 0x4f 0x49 0x53 0x52 0x53 0x52 0x4e , mid :0x76 0x76 0x78 0x77 0x6a 0x6a 0x6c 0x73 0x6f ,0x6b 0x6a 0x68 0x67 0x6d 0x73 0x73 0x75 0x6f , 0x67 0x63 0x70 0x72 0x6f 0x6d 0x6e 0x6f 0x6f ,0x65 0x63 0x67 0x61 0x6d 0x6d 0x6d 0x6d 0x65 , max :0x92 0x91 0x93 0x93 0x82 0x82 0x84 0x8b 0x88 ,0x88 0x85 0x84 0x84 0x87 0x8d 0x8d 0x90 0x8a , 0x84 0x7c 0x8c 0x90 0x89 0x86 0x86 0x87 0x88 ,0x81 0x7b 0x80 0x7a 0x87 0x88 0x87 0x88 0x7d , range:0x38 0x35 0x36 0x37 0x2f 0x2f 0x2f 0x30 0x31 ,0x3a 0x35 0x38 0x39 0x34 0x34 0x34 0x36 0x35 , 0x39 0x31 0x37 0x3b 0x34 0x31 0x2f 0x2f 0x31 ,0x37 0x2f 0x31 0x31 0x34 0x36 0x34 0x36 0x2f , CA Training result: CONQ., [13.11.2024 10:14] cs:0 min :0x44 0x44 0x3f 0x3c 0x3f 0x3b 0x47 ,0x48 0x41 0x42 0x39 0x41 0x38 0x44 , cs:0 mid :0x82 0x83 0x7c 0x7c 0x7b 0x7b 0x73 ,0x82 0x83 0x7e 0x7a 0x7c 0x79 0x6f , cs:0 max :0xc0 0xc3 0xba 0xbc 0xb7 0xbc 0x9f ,0xbd 0xc5 0xbb 0xbb 0xb8 0xbb 0x9b , cs:0 range:0x7c 0x7f 0x7b 0x80 0x78 0x81 0x58 ,0x75 0x84 0x79 0x82 0x77 0x83 0x57 , cs:1 min :0x41 0x43 0x3c 0x3f 0x3d 0x3a 0x44 ,0x46 0x41 0x3d 0x3c 0x3f 0x3b 0x46 , cs:1 mid :0x82 0x81 0x7b 0x7c 0x7b 0x7a 0x71 ,0x82 0x80 0x7c 0x7b 0x7c 0x7a 0x71 , cs:1 max :0xc4 0xbf 0xbb 0xba 0xba 0xba 0x9f ,0xbf 0xbf 0xbb 0xbb 0xb9 0xba 0x9d , cs:1 range:0x83 0x7c 0x7f 0x7b 0x7d 0x80 0x5b ,0x79 0x7e 0x7e 0x7f 0x7a 0x7f 0x57 , out U-Boot SPL board init U-Boot SPL 2017.09-orangepi (Nov 12 2024 - 22:27:40) Trying to boot from MMC1 Card did not respond to voltage select! spl: mmc init failed with error: -95 Trying to boot from MMC2 Card did not respond to voltage select! spl: mmc init failed with error: -95 Trying to boot from MTD2 No misc partition Trying fit image at 0x400 sector ## Verified-boot: 0 ## Checking atf-1 0x00040000 ... sha256(2f01bd8955...) + OK ## Checking uboot 0x00a00000 ... sha256(d82fb13996...) + OK ## Checking fdt 0x00b457b0 ... sha256(5c6babd1aa...) + OK ## Checking atf-2 0xfdcc9000 ... sha256(f1fecab971...) + OK ## Checking atf-3 0xfdcd0000 ... sha256(d7aa45eb18...) + OK Jumping to U-Boot(0x00a00000) via ARM Trusted Firmware(0x00040000) Total: 555.305 ms INFO: Preloader serial: 2 NOTICE: BL31: v2.3():v2.3-152-g4e725b15f:cl NOTICE: BL31: Built : 10:51:13, Jul 15 2021 INFO: GICv3 without legacy support detected. INFO: ARM GICv3 driver initialized in EL3 INFO: pmu v1 is valid INFO: dfs DDR fsp_param[0].freq_mhz= 1056MHz INFO: dfs DDR fsp_param[1].freq_mhz= 324MHz INFO: dfs DDR fsp_param[2].freq_mhz= 528MHz INFO: dfs DDR fsp_param[3].freq_mhz= 780MHz INFO: Using opteed sec cpu_context! INFO: boot cpu mask: 0 INFO: BL31: Initializing runtime services WARNING: No OPTEE provided by BL2 boot loader, Booting device without OPTEE initialization. SMC`s destined for OPTEE will return SMC_UNK ERROR: Error initializing runtime service opteed_fast INFO: BL31: Preparing for EL3 exit to normal world INFO: Entry point address = 0xa00000 INFO: SPSR = 0x3c9 U-Boot 2017.09-orangepi (Nov 12 2024 - 22:27:40 +0000) Model: Orange Pi 3B PreSerial: 2, raw, 0xfe660000 DRAM: 7.7 GiB Sysmem: init Relocation Offset: ed233000 Relocation fdt: eb9f6470 - eb9fecc0 CR: M/C/I Using default environment failed to find reset-gpios property dwmmc@fe2b0000: 0, dwmmc@fe2c0000: 2, sdhci@fe310000: 1 Device 0: unknown device Card did not respond to voltage select! Card did not respond to voltage select! Device 0: unknown device Device 1: Device 2: SF: Detected sfc_nor with page size 256 Bytes, erase size 4 KiB, total 16 MiB Vendor: 0x2207 Rev: V1.00 Prod: sfc_nor Type: Hard Disk Capacity: 16.0 MB = 0.0 GB (32768 x 512) ... is now current device Bootdev(scan): mtd 2 PartType: EFI DM: v1 boot mode: None I2c0 speed: 100000Hz vsel-gpios- not found! Error: -2 vdd_cpu init 900000 uV PMIC: RK8090 (on=0x10, off=0x00) vdd_logic init 900000 uV vdd_gpu init 900000 uV vdd_npu init 900000 uV io-domain: OK Failed to get scmi clk dev dmc_fsp failed, ret=-19 Model: Orange Pi 3B rockchip_set_ethaddr: vendor_storage_write failed -5 CLK: (sync kernel. arm: enter 816000 KHz, init 816000 KHz, kernel 0N/A) apll 816000 KHz dpll 528000 KHz gpll 1188000 KHz cpll 1000000 KHz npll 1200000 KHz vpll 24000 KHz hpll 24000 KHz ppll 200000 KHz armclk 816000 KHz aclk_bus 150000 KHz pclk_bus 100000 KHz aclk_top_high 300000 KHz aclk_top_low 200000 KHz hclk_top 150000 KHz pclk_top 100000 KHz aclk_perimid 300000 KHz hclk_perimid 150000 KHz pclk_pmu 100000 KHz Net: eth1: ethernet@fe010000 Hit key to stop autoboot('CTRL+C'): 0 Card did not respond to voltage select! Card did not respond to voltage select! failed to find reset-gpios property CONQ., [13.11.2024 10:14] Device 0: Vendor: 0x126f Rev: S0614B0G Prod: 201907020013 Type: Hard Disk Capacity: 122104.3 MB = 119.2 GB (250069680 x 512) ... is now current device Scanning nvme 0:1... Found U-Boot script /boot/boot.scr Failed to iterate over directory boot ** File not found /boot/boot.scr ** ## Executing script at 00c00000 Wrong image format for "source" command SCRIPT FAILED: continuing... starting USB... Bus dwc3@fcc00000: Register 2000140 NbrPorts 2 Starting the controller USB XHCI 1.10 Bus dwc3@fd000000: Register 2000140 NbrPorts 2 Starting the controller USB XHCI 1.10 scanning bus dwc3@fcc00000 for devices... 1 USB Device(s) found scanning bus dwc3@fd000000 for devices... 1 USB Device(s) found scanning usb for storage devices... 0 Storage Device(s) found Device 0: unknown device failed to find reset-gpios property ethernet@fe010000 Waiting for PHY auto negotiation to complete......... TIMEOUT ! phy_startup() failed: -110FAILED: -110missing environment variable: pxeuuid missing environment variable: bootfile Retrieving file: pxelinux.cfg/01-b2-f2-2a-36-55-ae ethernet@fe010000 Waiting for PHY auto negotiation to complete.......user interrupt! phy_startup() failed: -4FAILED: -4missing environment variable: bootfile Retrieving file: pxelinux.cfg/00000000 ethernet@fe010000 Waiting for PHY auto negotiation to complete.user interrupt! phy_startup() failed: -4FAILED: -4missing environment variable: bootfile Retrieving file: pxelinux.cfg/0000000 ethernet@fe010000 Waiting for PHY auto negotiation to complete.user interrupt! phy_startup() failed: -4FAILED: -4missing environment variable: bootfile Retrieving file: pxelinux.cfg/000000 ethernet@fe010000 Waiting for PHY auto negotiation to complete.user interrupt! phy_startup() failed: -4FAILED: -4missing environment variable: bootfile Retrieving file: pxelinux.cfg/00000 ethernet@fe010000 Waiting for PHY auto negotiation to complete.. - Version cloned via armbian during compilation: declare -g BOOTSOURCE="https://github.com/u-boot/u-boot.git" # We ❤️ Mainline U-Boot declare -g BOOTBRANCH="tag:v2024.10" declare -g BOOTPATCHDIR="v2024.10" # Don't set BOOTDIR, allow shared U-Boot source directory for disk space efficiency The problem: Device 0: Vendor: 0x126f Rev: S0614B0G Prod: 201907020013 Type: Hard Disk Capacity: 122104.3 MB = 119.2 GB (250069680 x 512) ... is now current device Scanning nvme 0:1... Found U-Boot script /boot/boot.scr Failed to iterate over directory boot ** File not found /boot/boot.scr ** ## Executing script at 00c00000 Wrong image format for "source" command SCRIPT FAILED: continuing... starting USB... Bus dwc3@fcc00000: Register 2000140 NbrPorts 2 Starting the controller USB XHCI 1.10 Bus dwc3@fd000000: Register 2000140 NbrPorts 2 Starting the controller USB XHCI 1.10 scanning bus dwc3@fcc00000 for devices... 1 USB Device(s) found scanning bus dwc3@fd000000 for devices... 1 USB Device(s) found scanning usb for storage devices... 0 Storage Device(s) found Suspicions: 1. Too old compilation version at u-boot? 2. Bad forrmating , GPT partitioning ? 3. Old version rkbin (binary devicetree) for orangepi-build-next ? 4. Something else.... 0 Quote
CONQ Posted November 13, 2024 Author Posted November 13, 2024 I tried using the same tag what in u-boot compilation : but doesn't work: I would have to go deep to change it. 0 Quote
