I'm trying to stream audio from my windows pc to a orange pi running `ARMBIAN 5.30 stable Ubuntu 16.04.2 LTS 3.4.113-sun8i`, in the verbose output in the pc and in the orange pi shows that the connection has been stablished but it gets refused right after with no "explanation". I'm following intructions from this thread, it shows how to add the tcp protocol to pulseaudio in the orange pi and on the windows machine the audio is captured with linco and it streams with plink (putty command line interface). Why the connection would be refusing to stay connected?
PS: in the installation process `/etc/default/pulseaudio` didn't exist after pulseaudio installation, but as it's just for iniate pulseaudio on system boot I don't think that relates with the problem that I'm having.
This is the output in the windows machine:
C:\Users\Rinaldi\Documents\Audio Streamer>linco.exe -B 16 -C 2 -R 44100   | plink -v 192.168.11.5 -l test -pw test "cat - | pacat --server 127.0.0.1 --playback"
Connecting to 192.168.11.5 port 22
We claim version: SSH-2.0-PuTTY_Release_0.70
**** LineInCode v2.10(2003-12-31)
**** (C) 2003 Roman Mamedov
**** Using "Microphone (High Definition Aud"
**** 44100 Hz, 16 Bit, Stereo
**** Press Ctrl-C to stop recording...
Server version: SSH-2.0-OpenSSH_7.2p2 Ubuntu-4ubuntu2.2
Using SSH protocol version 2
Doing ECDH key exchange with curve Curve25519 and hash SHA-256
Server also has ecdsa-sha2-nistp256/ssh-rsa host keys, but we don't know any of them
Host key fingerprint is:
ssh-ed25519 256 92:36:1f:f8:7e:79:4f:0f:9c:54:92:96:cd:a0:cb:a1
Initialised AES-256 SDCTR client->server encryption
Initialised HMAC-SHA-256 client->server MAC algorithm
Initialised AES-256 SDCTR server->client encryption
Initialised HMAC-SHA-256 server->client MAC algorithm
Using username "test".
Sent password
Access granted
Opening session as main channel
Opened main channel
Started a shell/command
Connection failure: Connection refused
Server sent command exit status 1
Disconnected: All channels closed
Output on the orangepi:
test@orangepiplus:~$ pulseaudio -v
I: [pulseaudio] main.c: setrlimit(RLIMIT_NICE, (31, 31)) failed: Operation not permitted
I: [pulseaudio] main.c: setrlimit(RLIMIT_RTPRIO, (9, 9)) failed: Operation not permitted
I: [pulseaudio] core-util.c: Failed to acquire high-priority scheduling: No such file or directory
I: [pulseaudio] main.c: This is PulseAudio 8.0
I: [pulseaudio] main.c: Page size is 4096 bytes
I: [pulseaudio] main.c: Machine ID is 963f5bc5e80e46e0b997c29e4993b5ab.
I: [pulseaudio] main.c: Session ID is 22.
I: [pulseaudio] main.c: Using runtime directory /run/user/1002/pulse.
I: [pulseaudio] main.c: Using state directory /home/test/.config/pulse.
I: [pulseaudio] main.c: Using modules directory /usr/lib/pulse-8.0/modules.
I: [pulseaudio] main.c: Running in system mode: no
I: [pulseaudio] main.c: System supports high resolution timers
I: [pulseaudio] cpu-arm.c: CPU flags: V6 V7 VFP EDSP NEON VFPV3
I: [pulseaudio] svolume_arm.c: Initialising ARM optimized volume functions.
I: [pulseaudio] sconv_neon.c: Initialising ARM NEON optimized conversions.
I: [pulseaudio] mix_neon.c: Initialising ARM NEON optimized mixing functions.
I: [pulseaudio] remap_neon.c: Initialising ARM NEON optimized remappers.
I: [pulseaudio] module-device-restore.c: Successfully opened database file '/home/test/.config/pulse/963f5bc5e80e46e0b997c29e4993b5ab-device-volumes'.
I: [pulseaudio] module.c: Loaded "module-device-restore" (index: #0; argument: "").
I: [pulseaudio] module-stream-restore.c: Successfully opened database file '/home/test/.config/pulse/963f5bc5e80e46e0b997c29e4993b5ab-stream-volumes'.
I: [pulseaudio] module.c: Loaded "module-stream-restore" (index: #1; argument: "").
I: [pulseaudio] module-card-restore.c: Successfully opened database file '/home/test/.config/pulse/963f5bc5e80e46e0b997c29e4993b5ab-card-database'.
I: [pulseaudio] module.c: Loaded "module-card-restore" (index: #2; argument: "").
I: [pulseaudio] module.c: Loaded "module-augment-properties" (index: #3; argument: "").
I: [pulseaudio] module.c: Loaded "module-switch-on-port-available" (index: #4; argument: "").
I: [pulseaudio] module-udev-detect.c: Found 3 cards.
I: [pulseaudio] module.c: Loaded "module-udev-detect" (index: #5; argument: "").
W: [pulseaudio] authkey.c: Failed to open cookie file '/home/test/.config/pulse/cookie': No such file or directory
W: [pulseaudio] authkey.c: Failed to load authentication key '/home/test/.config/pulse/cookie': No such file or directory
W: [pulseaudio] authkey.c: Failed to open cookie file '/home/test/.pulse-cookie': No such file or directory
W: [pulseaudio] authkey.c: Failed to load authentication key '/home/test/.pulse-cookie': No such file or directory
I: [pulseaudio] module.c: Loaded "module-native-protocol-unix" (index: #6; argument: "").
I: [pulseaudio] module.c: Loaded "module-default-device-restore" (index: #7; argument: "").
I: [pulseaudio] module.c: Loaded "module-rescue-streams" (index: #8; argument: "").
I: [pulseaudio] sink.c: Created sink 0 "auto_null" with sample spec s16le 2ch 44100Hz and channel map front-left,front-right
I: [pulseaudio] sink.c:     device.description = "Dummy Output"
I: [pulseaudio] sink.c:     device.class = "abstract"
I: [pulseaudio] sink.c:     device.icon_name = "audio-card"
I: [pulseaudio] source.c: Created source 0 "auto_null.monitor" with sample spec s16le 2ch 44100Hz and channel map front-left,front-right
I: [pulseaudio] source.c:     device.description = "Monitor of Dummy Output"
I: [pulseaudio] source.c:     device.class = "monitor"
I: [pulseaudio] source.c:     device.icon_name = "audio-input-microphone"
I: [pulseaudio] module.c: Loaded "module-null-sink" (index: #10; argument: "sink_name=auto_null sink_properties='device.description="Dummy Output"'").
I: [pulseaudio] module.c: Loaded "module-always-sink" (index: #9; argument: "").
I: [pulseaudio] module.c: Loaded "module-intended-roles" (index: #11; argument: "").
I: [pulseaudio] module.c: Loaded "module-suspend-on-idle" (index: #12; argument: "").
I: [pulseaudio] client.c: Created 0 "Login Session 22"
I: [pulseaudio] module.c: Loaded "module-systemd-login" (index: #13; argument: "").
I: [pulseaudio] module.c: Loaded "module-position-event-sounds" (index: #14; argument: "").
I: [pulseaudio] module.c: Loaded "module-filter-heuristics" (index: #15; argument: "").
I: [pulseaudio] module.c: Loaded "module-filter-apply" (index: #16; argument: "").
W: [pulseaudio] server-lookup.c: Unable to contact D-Bus: org.freedesktop.DBus.Error.NotSupported: Unable to autolaunch a dbus-daemon without a $DISPLAY for X11
W: [pulseaudio] main.c: Unable to contact D-Bus: org.freedesktop.DBus.Error.NotSupported: Unable to autolaunch a dbus-daemon without a $DISPLAY for X11
I: [pulseaudio] main.c: Daemon startup complete.
I: [pulseaudio] module-device-restore.c: Storing port for device sink:auto_null.
I: [pulseaudio] module-device-restore.c: Storing volume/mute for device+port sink:auto_null:null.
I: [pulseaudio] module-device-restore.c: Storing port for device source:auto_null.monitor.
I: [pulseaudio] module-device-restore.c: Storing volume/mute for device+port source:auto_null.monitor:null.
I: [pulseaudio] module-suspend-on-idle.c: Sink auto_null idle for too long, suspending ...
I: [pulseaudio] module-device-restore.c: Synced.
I: [pulseaudio] client.c: Created 1 "Login Session 23"
I: [pulseaudio] client.c: Freed 1 "Login Session 23"
