rjohnson Posted November 24, 2024 Posted November 24, 2024 I'm looking to build an ntp server using the OrangePi Zero 3 and I noticed there is no pps-gpio device tree overlay for the h616 chipset only the h5 chipset. Has anyone created a custom dt overlay? Thanks in advance. 0 Quote
robertoj Posted November 25, 2024 Posted November 25, 2024 Take this dts as reference, change the gpio to the opiz3 pin you want Do you know how to use armbian-add-overlay? https://www.kernel.org/doc/Documentation/devicetree/bindings/pps/pps-gpio.txt https://forum.banana-pi.org/t/bpi-m2-zero-how-to-define-the-pps-gpio-pin-a-gnss-solution/17562 0 Quote
Guest Posted December 4, 2024 Posted December 4, 2024 Try this simple DTS file made by myself. sun50i-h616-pps-gpio.dtbo sun50i-h616-pps-gpio.dts 0 Quote
