Go to solution Solved by robertoj,
hello! i was trying to hook up a 3.5" display to my orange pi zero 2w, but when i try to use the DTS, all i get is black and white stripes. does anyone know a fix or what this even means?
Posted (edited)
It probably means that you are close to having it work.
75% of the effort (or good luck) results in the LCD displaying noise or bad image.
What model LCD?
Photos?
Confirm the wiring matches the default SPI terminals and the custom GPIO I included in the DTS.
Are you connecting the touch chip terminals?
LInux and armbian version? Downloaded or self compiled?
Run the tests I have shown in several of my LCD threads: ili9341, ili9488.
Edited by robertoj
its an ili9488 3.5" cheap red SPI display, pretty much right after posting the comment i got it to output a garbled image, i did change the pins to match my pin connections. i was running orange pi branded debian, doing stuff on armbian doesn't work for some reason, im going to try to compile it myself. i completely removed touch from the DTS because i dont really need it. i am on orange pi zero 2w btw. for some reason i cant upload an image
My DTS is for the Orange Pi Zero 3.
There's another thread that shows the correct GPIO wiring and DTS GPIO definitions for Orange Pi Zero 2w.
hello again, i searched around and pretty much everything links back to this thread. this is the best result i could get on latest armbian, does anyone know what i can change? i think the problem is that the image is kinda shifted down and then goes back up? im pretty sure i need to change some kind of offset, but other than that im stumped
Posted (edited)
Try a lower SPI frequency and use direct wires from the orange pi zero 2w to the LCD
There might be something in the panel-mipi-dbi-spi.bin firmware to improve the display of the received bytes, but first do these two improvements (first try the direct wires)
Opiz2w cases:
https://forum.armbian.com/topic/52880-orangepi-zero-2w-wrong-color-display-on-mpi3501/
https://forum.armbian.com/topic/44191-orangepi-zero-lts-ili9341-tft-lcd-and-later-orangepi-zero-3/page/2/
https://forum.armbian.com/topic/46824-orange-pi-zero-3-ili9486-tft-lcd/
Edited by robertoj
Posted (edited)
thanks! direct wiring has definitely changed something, i guess ill keep changing stuff and update if i get something
upd: the direct wiring has definitely made an improvement, but it still looks offset, i have no idea how to fix this, changing stuff in panel-timing just.. does stuff randomly, and i have no idea how to pick the right one. does anyone know the solution to this kind of weirdness?
this is the best i could get it:
Edited by p a s h
Posted (edited)
post the link of the online store where you bought your LCD.
Why do you describe your problem as "offset", if your problem is a big rectangle that covers 25% of your screen?
Edited by robertoj
now that i think of it, i think you're right; the data being displayed is not offset its just straight up not displayed in some regions and wraps around for some reason. i bought the display here. its very likely resold from aliexpress.
Posted (edited)
The online store link doesnt work :(
Did you try lowering the SPI frequency?
Are you using the panel-mipi-dbi-spi driver?
I have no idea about the timing parameters in the firmware bin file. Are you familiar with notro's python script that turns a txt into a firmware bin file?
There's a chance that your LCD is bad. Try buying an extra LCD.
Future note for when you succeed with the driver: X11 will not work. There's a driver issue. If you can compile MESA3D you might get the needed updated driver. I have been using wayland+labwc... and I am currently in the effort to add a wayland greeter for the display manager (lightdm or greetd). (search my threads)
Edited by robertoj
oh so THAT'S why Xfce didnt launch, good to know. i did try lowering the SPI frequency but the result is pretty much the same. i am using the panel-mipi-dbi-spi driver, i will check the script later and see how it actually works. i am 100% sure the display is not defective, it works perfectly fine through tft_eSPI on an esp32, i will try getting an another unit and see if it changes anything.
Hmmm ok Now I am out of ideas.
Are you using a downloaded armbian image? I have been using only self-compiled armbian images... (I need features of the latest linux-edge)
It also prevents some problems if you uninstall or disable plymouth (interferes with loading the firmware file).
i am using a downloaded image, trying to compile armbian has been an awful experience, i guess ill keep trying different settings and see if anything changes
Posted (edited)
Quote
what specific issues did you run into?
ok so, i tried to replicate the issues i had but they just... didnt happen? everything just... works perfectly fine????? i have no idea if it was just that i was particularly unlucky or something, but i just compiled a working image fairly easily.
edit: nevermind, when i retried after a restart i got a
Failed to update binfmts [ update-binfmts --enable qemu-arm ]
error, googling yielded almost no information (host: fedora 42)
Quote
Make sure to power the VCC and LED with 3.3v, not 5v
i did!
Quote
its a russian store, so it probably has a bunch of countries region blocked (for me it works, even through VPN)
Edited by p a s h
Posted (edited)
Share your DTS, maybe you missed something
Run:
dmesg | grep -E 'spi|panel' and post the result
I already saw the online store... it is the same LCD that I use (I have both 3.5" and 4.0" and they work with the same DTS and bin file)
Edited by robertoj
Are you using the same GPIO wiring as I am?
Previously, I was using different GPIO for the chip select, and touch wasn't working... now with my current GPIO in my DTS, it works perfectly.
Quote
we need full logs of your compilation.  Run like "./compile.sh [...] SHARE_LOG=yes"
here: https://paste.armbian.com/oyozunowab (running through docker on fedora 42 latest everything after a restart, the same issue happens on a fresh download too)
Quote
Spoiler
/dts-v1/;
/plugin/;
    compatible = "allwinner,sun50i-h616";
    fragment@0 {
        target = <&spi1>;
        __overlay__ {
            status = "okay";
            cs-gpios = <&pio 7 5 0>;
            panel: panel@0 {
                compatible = "panel-mipi-dbi-spi";
                reg = <0>;
                spi-max-frequency = <40000000>;
                width-mm=<79>;
                height-mm=<54>;
                reset-gpios = <&pio 8 6 0>;
                dc-gpios = <&pio 7 4 0>;
                write-only;
                format = "b6x2g6x2r6x2";
                panel-timing {
                    hactive = <480>;
                    vactive = <320>;
                    hback-porch = <0>;
                    vback-porch = <0>;
                    clock-frequency = <0>;
                    hfront-porch = <0>;
                    hsync-len = <0>;
                    vfront-porch = <0>;
                    vsync-len = <0>;
Quote
i dont have it available atm, i will include it as soon as i can get access to it, but last time i checked dmesg there was pretty much no errors
Quote
no, not really, i changed the pins for D/C and reset iirc
Your gpios lines are declaring reset="i6" and dc="h4"... is that correct?
At this point, we can see that all pins are correctly defined and connected.
Maybe wire length issue? Bad terminal connection? My wires are 15cm long... directly connected with dupont connectors.
Quote
yep, thats how i connected them
Quote
i think it might be that? ill try to get some fresh wires and see if it helps
Posted (edited)
I noticed this problem a long time ago, but now I feel it is important to fix it:
I get a slim black bar on the left side, and a portion of the pixels on the right get "cropped" because they don't fit in the LCD display area?
I get the left 2 pixels of the screen "cropped", so in console, the first left-side are always missing the left pixels.
Do you get the same in your LCD? Do you know a way to fix it? I am talking about this LCD: RED PCB LCD https://www.aliexpress.us/item/3256802847521952.html?
Edited by robertoj
Hello!
First of all, thank you robertoj for this treasure trove of information - truly, I searched so much of the internet before finding this, because seemingly nobody is sharing DTS files for tft screens at all that aren't on a raspberry pi (which uses a different system afaik).
I am using a rockpi 4bplus, trying to get an ili9488/86 tft screen to work, and struggling. I've used your latest DTS from page 1, using panel-mipi, verified it loads into initramfs using your other threads, compiled my own armbian edge on kernel 6.18 (and tried on kernel 6.12), corrected all FDT err not found errors on the DTS for my use case (my gpio numbers were out of scope)... still, all I get on my display is a blank white screen with no dmesg errors or comments about spi, panel etc... ;-; Not sure what else to try at this point.
I'll post my files below, along with translated gpio pin numbers:
/dts-v1/;
/plugin/;
    compatible = "radxa,rockpi4b-plus", "radxa,rockpi4", "rockchip,rk3399";
    fragment@0 {
        target = <&spi1>;
        __overlay__ {
            #address-cells = <1>;
            #size-cells = <0>;
            pinctrl-names = "default"; /* new for linux 6.13 */
            pinctrl-0 = <&spi1_clk &spi1_cs0 &spi1_rx &spi1_tx>; /* new for linux 6.13 */
            cs-gpios = <&spi1_cs0>, <&gpio4 26 0>; /* lcd, touch chip select */
            panel: panel@0 {
                status = "okay";
                reg = <0>;
                width-mm=<84>;
                height-mm=<56>;
                reset-gpios = <&gpio4 29 1>; /* taken from rock3c setup, then modified for armbian */
                dc-gpios = <&gpio4 28 0>; /* 1 is low, 0 is high */
                write-only;
                panel-timing {
                     hactive = <480>;
                     vactive = <320>;
                     hback-porch = <0>;
                     vback-porch = <0>;
                     hfront-porch = <0>;
                     hsync-len = <0>;
                     vfront-porch = <0>;
                     vsync-len = <0>;
            ads7846: ads7846@1 {
                   compatible = "ti,ads7846";
                   reg = <1>;
                   spi-max-frequency = <1000000>;
                   interrupt-parent = <&gpio4>;
                   interrupts = <21 2>;  /* 2 is IRQ_TYPE_EDGE_FALLING
                   pendown-gpio = <&gpio4 21 0>; /* same as interrupt, pulled high */
                   vcc-supply = <&vcc5v0_sys>; /* Fill in the voltage according to the actual power supply c>
        /* OPTIONS */
                   ti,x-min = /bits/ 16 <0>;
                   ti,y-min = /bits/ 16 <0>;
                   ti,x-max = /bits/ 16 <0XFFF>;
                   ti,y-max = /bits/ 16 <0XFFF>;
                   ti,pressure-min = /bits/ 16 <0>;
                   ti,pressure-max = /bits/ 16 <0XFFF>;
                   ti,x-plate-ohms = /bits/ 16 <400>;
                   ti,swap-xy = <1>;
Posted (edited)
If you already checked "dmesg|grep panel-mipi" and "dmesg|grep spi", check this:
* share which LCD you are using. Half of those LCDs are waveshare clones, which need a different driver. My DTS works in the RED LCDs.
* Look at the uboot messages in the serial port output. Does it confirm it is finding your dtbo and using it?
* verify that panel-mipi-dbi.ko exists in the modules folder. I know it is not preselected by default within the linux configuration menu
* Search the word "pinctrl" in this thread https://forum.armbian.com/topic/44191-orangepi-zero-lts-ili9341-tft-lcd-and-later-orangepi-zero-3/#comment-204741
To confirm that the kernel driver is using the gpio and spi pins
* send link of the rock3c DTS you are referencing, to see an example of how GPIOs are configured
* correct the gpio pin map you shared. Instead of tx/rx, use MOSI, MISO. Highlight and label clearly the CS0, CS1, RESET, DC, IRQ
* explain how those gpio numbers gpioX,XX transform into the DTS gpioX XX 1/0
If you at least get noise in the LCD, you are 50% done :) (and maybe you will get lucky in the last 50%)
Edited by robertoj
