forumtrekker Posted December 3, 2025 Posted December 3, 2025 Good to know. I'm interested in getting the red LCD's to work as they are cheaper and more available, I purchased the waveshare only to test my SPI, SBC, and DTS formatting were functional. Now that I confirmed how to translate DTS to work with my SBC, I can work on the red ili9486/8 without worrying about it being a formatting issue. 0 Quote
forumtrekker Posted December 5, 2025 Posted December 5, 2025 (edited) I think I have a partial success but I'm struggling to get anything but white on the red display! Will update when I have more results. panel-mipi is loading, and Card-1-SPI appears under /sys/class/drm/ which is very promising. Verified that /lib/firmware/panel-mipi-dbi-spi is still present, still patched with Kungfupancake's init, and is loaded according to lsmod (as well as dmesg) Spoiler sudo dmesg | grep drm [ 4.002790] rockchip-drm display-subsystem: bound ff900000.vop (ops vop_component_ops [rockchipdrm]) [ 4.004049] rockchip-drm display-subsystem: bound ff8f0000.vop (ops vop_component_ops [rockchipdrm]) [ 4.028685] rockchip-drm display-subsystem: bound ff940000.hdmi (ops dw_hdmi_rockchip_ops [rockchipdrm]) [ 4.030113] [drm] Initialized rockchip 1.0.0 for display-subsystem on minor 0 [ 4.030278] rockchip-drm display-subsystem: [drm] Cannot find any crtc or sizes [ 4.030440] rockchip-drm display-subsystem: [drm] Cannot find any crtc or sizes [ 6.796700] systemd[1]: Starting modprobe@drm.service - Load Kernel Module drm... [ 6.863822] systemd[1]: modprobe@drm.service: Deactivated successfully. [ 6.864868] systemd[1]: Finished modprobe@drm.service - Load Kernel Module drm. [ 8.238975] [drm] Initialized panel-mipi-dbi 1.0.0 for spi1.0 on minor 1 [ 8.345046] [drm] Initialized panfrost 1.4.0 for ff9a0000.gpu on minor 2 [ 9.048179] panel-mipi-dbi-spi spi1.0: [drm] fb0: panel-mipi-dbid frame buffer device sudo dmesg | grep mipi [ 8.230250] panel-mipi-dbi-spi spi1.0: supply power not found, using dummy regulator [ 8.230448] panel-mipi-dbi-spi spi1.0: supply io not found, using dummy regulator [ 8.238975] [drm] Initialized panel-mipi-dbi 1.0.0 for spi1.0 on minor 1 [ 9.048179] panel-mipi-dbi-spi spi1.0: [drm] fb0: panel-mipi-dbid frame buffer device sudo dmesg | grep spi [ 8.074489] OF: /spi@ff1d0000/ads7846@1: Read of boolean property 'ti,swap-xy' with a value. [ 8.076419] ads7846 spi1.1: touchscreen, irq 77 [ 8.078736] input: ADS7846 Touchscreen as /devices/platform/ff1d0000.spi/spi_master/spi1/spi1.1/input/input0 [ 8.230250] panel-mipi-dbi-spi spi1.0: supply power not found, using dummy regulator [ 8.230448] panel-mipi-dbi-spi spi1.0: supply io not found, using dummy regulator [ 8.238975] [drm] Initialized panel-mipi-dbi 1.0.0 for spi1.0 on minor 1 [ 9.048179] panel-mipi-dbi-spi spi1.0: [drm] fb0: panel-mipi-dbid frame buffer device sudo ls -al /sys/class/drm/ total 0 drwxr-xr-x 2 root root 0 Dec 31 1969 . drwxr-xr-x 73 root root 0 Dec 31 1969 .. lrwxrwxrwx 1 root root 0 Dec 5 01:28 card0 -> ../../devices/platform/display-subsystem/drm/card0 lrwxrwxrwx 1 root root 0 Dec 5 01:28 card0-HDMI-A-1 -> ../../devices/platform/display-subsystem/drm/card0/card0-HDMI-A-1 lrwxrwxrwx 1 root root 0 Dec 5 01:29 card1 -> ../../devices/platform/ff1d0000.spi/spi_master/spi1/spi1.0/drm/card1 lrwxrwxrwx 1 root root 0 Dec 5 01:28 card1-SPI-1 -> ../../devices/platform/ff1d0000.spi/spi_master/spi1/spi1.0/drm/card1/card1-SPI-1 lrwxrwxrwx 1 root root 0 Dec 5 01:29 card2 -> ../../devices/platform/ff9a0000.gpu/drm/card2 lrwxrwxrwx 1 root root 0 Dec 5 01:29 renderD128 -> ../../devices/platform/ff9a0000.gpu/drm/renderD128 My current DTS: Spoiler /dts-v1/; / { fragment@0 { target = <0xffffffff>; __overlay__ { status = "okay"; #address-cells = <0x01>; #size-cells = <0x00>; ili9486@0 { compatible = "panel-mipi-dbi-spi"; reg = <0>; spi-max-frequency = <40000000>; reset-gpios = <0xffffffff 0x1d 0x00>; dc-gpios = <0xffffffff 0x1c 0x00>; write-only; format = "b6x2g6x2r6x2"; width-mm= <84>; height-mm=<56>; panel-timing { hactive = <480>; vactive = <320>; hback-porch = <0>; vback-porch = <0>; clock-frequency = <0>; hfront-porch = <0>; hsync-len = <0>; vfront-porch = <0>; vsync-len = <0>; }; }; ads7846@1 { compatible = "ti,ads7846"; status = "okay"; reg = <1>; id = <1>; spi-max-frequency = <2000000>; ti,x-plate-ohms = [00 3c]; ti,pressure-max = [00 ff]; ti,swap-xy = <0>; ti,invert-y = <1>; vcc-supply = <0xffffffff>; interrupts = <0x12 0x02>; interrupt-parent = <0xffffffff>; pendown-gpio = <0xffffffff 0x12 0x00>; phandle = <0x02>; }; }; }; metadata { title = "Enable ili9486/8 Red LCD 3.5inch on SPI1"; compatible = "rockchip,rk3399"; category = "misc"; exclusive = "GPIO1_B0\0GPIO1_A7\0GPIO1_B1\0GPIO1_B2\0GPIO4_D2\0GPIO4_D4\0GPIO4_D5"; description = "Enable Waveshare 3.5inch RPi LCD (C) on SPI1."; }; fragment@1 { target = <0xffffffff>; __overlay__ { num-cs = <0x02>; cs-gpios = <0xffffffff 0x0a 0x00 0xffffffff 0x1a 0x00>; pinctrl-names = "default\0high_speed"; pinctrl-0 = <0xffffffff 0xffffffff 0xffffffff>; }; }; __symbols__ { ili9486 = "/fragment@0/__overlay__/ili9486@0"; ads7846 = "/fragment@0/__overlay__/ads7846@1"; }; __fixups__ { spi1 = "/fragment@0:target:0\0/fragment@1:target:0"; gpio4 = "/fragment@0/__overlay__/ili9486@0:reset-gpios:0\0/fragment@0/__overlay__/ili9486@0:dc-gpios:0\0/fragment@0/__overlay__/ads7846@1:interrupt-parent:0\0/fragment@0/__overlay__/ads7846@1:pendown-gpio:0\0/fragment@1/__overlay__:cs-gpios:12"; vcc5v0_sys = "/fragment@0/__overlay__/ads7846@1:vcc-supply:0"; gpio1 = "/fragment@1/__overlay__:cs-gpios:0"; spi1_clk = "/fragment@1/__overlay__:pinctrl-0:0"; spi1_rx = "/fragment@1/__overlay__:pinctrl-0:4"; spi1_tx = "/fragment@1/__overlay__:pinctrl-0:8"; }; }; Edit: I installed XFCE to test, and strangely this has caused dmesg to throw errors related to panel-mipi. I had these same errors when panel-mipi was missing from /lib/firmware but it is still present there. Spoiler sudo dmesg | grep mipi [ 4.601157] panel-mipi-dbi-spi spi1.0: supply power not found, using dummy regulator [ 4.601515] panel-mipi-dbi-spi spi1.0: supply io not found, using dummy regulator [ 4.601904] panel-mipi-dbi-spi spi1.0: Direct firmware load for panel-mipi-dbi-spi.bin failed wit h error -2 [ 4.601941] panel-mipi-dbi-spi spi1.0: No config file found for compatible 'panel-mipi-dbi-spi' ( error=-2) [ 4.601960] panel-mipi-dbi-spi spi1.0: probe with driver panel-mipi-dbi-spi failed with error -2 Edited December 5, 2025 by forumtrekker 0 Quote
robertoj Posted December 5, 2025 Author Posted December 5, 2025 (edited) Can you share the DTS you used, to have success with the waveshare LCD? The only thing we need to extract from it are the gpio pins. And I am curious how you made a waveshare LCD work. The gpio formatting in your DTS looks very weird. Can you start with the DTS I shared? Share also which armbian and Linux version you are using. (I can only help with a Linux 6.11 or newer). If you only get a white LCD screen, it means that the LCD is not getting the right control signals in the correct pins. You don't need to try XFCE at this point. It won't work. Edited December 5, 2025 by robertoj 0 Quote
forumtrekker Posted December 5, 2025 Posted December 5, 2025 (edited) My latest post on page two shows the waveshare clone LCD DTS, working under FBTFT not DRM. The gpio formatting is strange, but it is what I lifted from Radxa provided DTS for a different waveshare LCD that I'm adapting for the displays here. This DTS I have is functional, and I'm certain the pins are correct as the Red ili9488 display shows purple / blue lines using FBTFT (probably incorrect init sequence, since it shows purple and red using your FBTFT init sequence under ili9341 driver instead of ili9486. fb_ili9486 does not work as you also experienced), and the Blue waveshare clone display works perfectly. Current working red DTS: Spoiler /dts-v1/; / { fragment@0 { target = <0xffffffff>; __overlay__ { status = "okay"; #address-cells = <0x01>; #size-cells = <0x00>; ili9486@0 { compatible = "panel-mipi-dbi-spi"; /* compatible = "ilitek,ili9341"; Don't forget to include init sequence and modprobe fbtft for this to semi-function. Add regwidth 16, buswidth 8, txbuflen 32768 for fbtft*/ reg = <0>; spi-max-frequency = <40000000>; reset-gpios = <0xffffffff 0x1d 0x00>; dc-gpios = <0xffffffff 0x1c 0x00>; write-only; format = "b6x2g6x2r6x2"; width-mm= <84>; height-mm=<56>; panel-timing { hactive = <480>; vactive = <320>; hback-porch = <0>; vback-porch = <0>; clock-frequency = <0>; hfront-porch = <0>; hsync-len = <0>; vfront-porch = <0>; vsync-len = <0>; }; }; ads7846@1 { compatible = "ti,ads7846"; status = "okay"; reg = <1>; id = <1>; spi-max-frequency = <2000000>; ti,x-plate-ohms = [00 3c]; ti,pressure-max = [00 ff]; ti,swap-xy = <0>; ti,invert-y = <1>; vcc-supply = <0xffffffff>; interrupts = <0x12 0x02>; interrupt-parent = <0xffffffff>; pendown-gpio = <0xffffffff 0x12 0x00>; phandle = <0x02>; }; }; }; metadata { title = "Enable Waveshare 3.5inch RPi LCD (C) on SPI1"; compatible = "rockchip,rk3399"; category = "misc"; exclusive = "GPIO1_B0\0GPIO1_A7\0GPIO1_B1\0GPIO1_B2\0GPIO4_D2\0GPIO4_D4\0GPIO4_D5"; description = "Enable Waveshare 3.5inch RPi LCD (C) on SPI1."; }; fragment@1 { target = <0xffffffff>; __overlay__ { num-cs = <0x02>; cs-gpios = <0xffffffff 0x0a 0x00 0xffffffff 0x1a 0x00>; pinctrl-names = "default\0high_speed"; pinctrl-0 = <0xffffffff 0xffffffff 0xffffffff>; }; }; __symbols__ { ili9486 = "/fragment@0/__overlay__/ili9486@0"; ads7846 = "/fragment@0/__overlay__/ads7846@1"; }; __fixups__ { spi1 = "/fragment@0:target:0\0/fragment@1:target:0"; gpio4 = "/fragment@0/__overlay__/ili9486@0:reset-gpios:0\0/fragment@0/__overlay__/ili9486@0:dc-gpios:0\0/fragment@0/__overlay__/ads7846@1:interrupt-parent:0\0/fragment@0/__overlay__/ads7846@1:pendown-gpio:0\0/fragment@1/__overlay__:cs-gpios:12"; vcc5v0_sys = "/fragment@0/__overlay__/ads7846@1:vcc-supply:0"; gpio1 = "/fragment@1/__overlay__:cs-gpios:0"; spi1_clk = "/fragment@1/__overlay__:pinctrl-0:0"; spi1_rx = "/fragment@1/__overlay__:pinctrl-0:4"; spi1_tx = "/fragment@1/__overlay__:pinctrl-0:8"; }; }; Current working waveshare fbtft, laggy (waveshare LCD is a parallel display with shift register hacks and kind of bad, so lag is expected.) Haven't tried DMA or fbcp since fbtft is outdated anyway. I've commented what each line / hexadecimal represents, to make it easy to follow. Spoiler /dts-v1/; / { fragment@0 { target = <0xffffffff>; /* spi1 */ __overlay__ { status = "okay"; #address-cells = <0x01>; #size-cells = <0x00>; ili9486@0 { compatible = "fb_ili9486"; reg = <0x00>; /* CS0 */ spi-max-frequency = <0xf42400>; /* 16 MHz, higher or lower than this doesn't work on waveshare clone */ txbuflen = <0x8000>; /* 32768 */ rotate = <0x5a>; /* 90 */ bgr = <0x00>; /* I have no idea */ fps = <0x1e>; /* 30. Lags despite fps */ buswidth = <0x08>; /* Only 8 works on red lcd */ regwidth = <0x10>; /* 16 */ debug = <0x00>; reset-gpios = <0xffffffff 0x1d 0x01>; /* gpio4 29 1 */ dc-gpios = <0xffffffff 0x1c 0x00>; /* gpio4 28 0 */ phandle = <0x01>; /* unsure, unable to compile without, phandle errors with. still works */ }; ads7846@1 { compatible = "ti,ads7846"; status = "okay"; reg = <0x01>; /* CS1 */ id = <0x01>; spi-max-frequency = <0x1e8480>; /* 2MHz */ ti,x-plate-ohms = [00 3c]; ti,pressure-max = [00 ff]; ti,swap-xy = <0x00>; ti,invert-y = <0x01>; vcc-supply = <0xffffffff>; /* vcc5v0_sys */ interrupts = <0x12 0x02>; /* gpio4 18 2 */ interrupt-parent = <0xffffffff>; /* gpio4 */ pendown-gpio = <0xffffffff 0x12 0x00>; /* gpio4 18 0 */ phandle = <0x02>; }; }; }; metadata { title = "Enable Waveshare 3.5inch RPi LCD (C) on SPI1"; compatible = "rockchip,rk3399"; category = "misc"; exclusive = "GPIO1_B0\0GPIO1_A7\0GPIO1_B1\0GPIO1_B2\0GPIO4_D2\0GPIO4_D4\0GPIO4_D5"; description = "Enable Waveshare 3.5inch RPi LCD (C) on SPI1."; }; fragment@1 { target = <0xffffffff>; /* spi1 */ __overlay__ { num-cs = <0x02>; cs-gpios = <0xffffffff 0x0a 0x00 0xffffffff 0x1a 0x00>; /* gpio1 10 0, gpio4 26 0 */ pinctrl-names = "default\0high_speed"; pinctrl-0 = <0xffffffff 0xffffffff 0xffffffff>; /* spi_clk, spi_rx, spi_tx */ }; }; __symbols__ { ili9486 = "/fragment@0/__overlay__/ili9486@0"; ads7846 = "/fragment@0/__overlay__/ads7846@1"; }; __fixups__ { spi1 = "/fragment@0:target:0\0/fragment@1:target:0"; gpio4 = "/fragment@0/__overlay__/ili9486@0:reset-gpios:0\0/fragment@0/__overlay__/ili9486@0:dc-gpios:0\0/fragment@0/__overlay__/ads7846@1:interrupt-parent:0\0/fragment@0/__overlay__/ads7846@1:pendown-gpio:0\0/fragment@1/__overlay__:cs-gpios:12"; vcc5v0_sys = "/fragment@0/__overlay__/ads7846@1:vcc-supply:0"; gpio1 = "/fragment@1/__overlay__:cs-gpios:0"; spi1_clk = "/fragment@1/__overlay__:pinctrl-0:0"; spi1_rx = "/fragment@1/__overlay__:pinctrl-0:4"; spi1_tx = "/fragment@1/__overlay__:pinctrl-0:8"; }; }; I spent several weeks trying variations of the DTS you provided, and I was never able to get it to work properly. I only got positive results when I started using the formatting I am now. The formatting is semi-understandable, every gpio and spi is just referenced at the end of the file by line name and position in increases of 4 (0 refers to the first item in a line, 4 to the second, 8 to the third etc), instead of being directly called in their location. For example, the target of fragment0 is 0xfffffff, which at the bottom of the DTS in the fixups section, is referred to as spi1. The cs-gpios are referred to in fixups in both gpio4 and gpio1. I am using latest armbian compiled per your instructions / forum posts, running edge compiled armbian with kernel 6.18.0-rc6, with panel-mipi selected at kernel build time according to the KungfuPancake github, firmware placed in lib/firmware, and drm verified to be loaded and semi functioning. I've essentially followed all your forum posts but have not had the success you have had. I'm now wondering if I have to tell armbian how to use the display with DRM, because I read somewhere that fbtft will draw constantly to your screen, but DRM will only draw when called and by default stays a white screen until called by the system. I tried adding a line in /boot/armbian.conf which should use the /dev/fb0 device as a display when /sys/class/drm/card1-spi is present (which it is), but it doesn't change anything. Edit: it seems adding this is not necessary if plymouth is installed. extras="fbcon=map:1" I appreciate your help! EDIT: I went through the first page of this thread again to check I haven't missed anything. since I've done multiple reinstall's etc... and realized after installing xfce this time, I didn't go through the updating of initramfs to ensure panel-mipi loads properly with plymouth installed. Panel-mipi seemed to still load fine and be present, but I went through the steps in your thread here and it fixed the following error I was having since installing XFCE, AND the screen is showing blue and black bars. The evidence seems to be pointing to the drm driver being initialized and used properly, so i'm going to make sure my gpio pin polarity is correct in my DTS since DRM expects flipped values in some cases compared to FBTFT, then I will check my wiring and shorten them in case it is physics / interference problem, and finally I'll try other init sequences from lcdwiki. [ 4.601941] panel-mipi-dbi-spi spi1.0: No config file found for compatible 'panel-mipi-dbi-spi' (error=-2) Edited December 5, 2025 by forumtrekker fixed formatting of code, fixed kernel version 0 Quote
forumtrekker Posted December 5, 2025 Posted December 5, 2025 (edited) I got the display to work! I left out a phandle = <0x01> line in my ili9486@0 section, adding it made it work. DTS was fine otherwise. It's a little glitchy and laggy so I need to tinker with it more, but I see plymouth displaying properly! I can't seem to get into tty or XFCE, but I believe I'm not running wayland and it sounds like thats a requirement for tinydrm? I'll figure it out, but the hard part is over. Once I get everything polished I'll write a summary of my steps so its easy for others to follow. Working DTS for the red ili9488 display using tinydrm driver: Spoiler /dts-v1/; / { fragment@0 { target = <0xffffffff>; __overlay__ { status = "okay"; #address-cells = <0x01>; #size-cells = <0x00>; ili9486@0 { compatible = "panel-mipi-dbi-spi"; reg = <0>; spi-max-frequency = <40000000>; reset-gpios = <0xffffffff 0x1d 0x00>; dc-gpios = <0xffffffff 0x1c 0x00>; write-only; format = "b6x2g6x2r6x2"; width-mm= <84>; height-mm=<56>; phandle = <0x01>; panel-timing { hactive = <480>; vactive = <320>; hback-porch = <0>; vback-porch = <0>; clock-frequency = <0>; hfront-porch = <0>; hsync-len = <0>; vfront-porch = <0>; vsync-len = <0>; }; }; ads7846@1 { compatible = "ti,ads7846"; status = "okay"; reg = <1>; id = <1>; spi-max-frequency = <2000000>; ti,x-plate-ohms = [00 3c]; ti,pressure-max = [00 ff]; ti,swap-xy = <0>; ti,invert-y = <1>; vcc-supply = <0xffffffff>; interrupts = <0x12 0x02>; interrupt-parent = <0xffffffff>; pendown-gpio = <0xffffffff 0x12 0x00>; phandle = <0x02>; }; }; }; metadata { title = "Enable Waveshare 3.5inch RPi LCD (C) on SPI1"; compatible = "rockchip,rk3399"; category = "misc"; exclusive = "GPIO1_B0\0GPIO1_A7\0GPIO1_B1\0GPIO1_B2\0GPIO4_D2\0GPIO4_D4\0GPIO4_D5"; description = "Enable Waveshare 3.5inch RPi LCD (C) on SPI1."; }; fragment@1 { target = <0xffffffff>; __overlay__ { num-cs = <0x02>; cs-gpios = <0xffffffff 0x0a 0x00 0xffffffff 0x1a 0x00>; pinctrl-names = "default\0high_speed"; pinctrl-0 = <0xffffffff 0xffffffff 0xffffffff>; }; }; __symbols__ { ili9486 = "/fragment@0/__overlay__/ili9486@0"; ads7846 = "/fragment@0/__overlay__/ads7846@1"; }; __fixups__ { spi1 = "/fragment@0:target:0\0/fragment@1:target:0"; gpio4 = "/fragment@0/__overlay__/ili9486@0:reset-gpios:0\0/fragment@0/__overlay__/ili9486@0:dc-gpios:0\0/fragment@0/__overlay__/ads7846@1:interrupt-parent:0\0/fragment@0/__overlay__/ads7846@1:pendown-gpio:0\0/fragment@1/__overlay__:cs-gpios:12"; vcc5v0_sys = "/fragment@0/__overlay__/ads7846@1:vcc-supply:0"; gpio1 = "/fragment@1/__overlay__:cs-gpios:0"; spi1_clk = "/fragment@1/__overlay__:pinctrl-0:0"; spi1_rx = "/fragment@1/__overlay__:pinctrl-0:4"; spi1_tx = "/fragment@1/__overlay__:pinctrl-0:8"; }; }; Edit: Removing XFCE & plymouth seems to break things, display is pure white again. It also rearranges /sys/class/drm to be card1-SPI-1 instead of card0-SPI-1. Adding this line to /boot/armbianEnv.txt results in the blue and black stripes again, instead of a white screen, but prevents the screen from working with plymouth or XFCE. extras="fbcon=map:0" Reinstalling plymouth and XFCE reverts this white screen and shows boot messages again but no tty console, only if there is no fbcon line at all. Installing just plymouth and not XFCE shows boot messages only if fbcon=map:1 is set, note the 1 instead of 0. Still no tty. The last boot message is and the one after (which I see on serial console) is this, so maybe plymouth finishes writing boot messages to display and the system just never accesses it again? Maybe I need xorg to access /dev/dri/card0 instead of /dev/fb0, since it is not a fbtft device but a DRM one? [ OK ] Finished plymout… Write Out Runtime Data. Edited December 5, 2025 by forumtrekker 0 Quote
forumtrekker Posted December 6, 2025 Posted December 6, 2025 Did a fresh install of community Armbian desktop this time, running current 6.12.60 from here. It seems there is no need to compile from scratch if you are using the panel-mipi driver from kungfupanda, I copied my DTS, panel-mipi.bin, etc. from my edge custom compiled installation to the community one and it worked fine after repeating the initramfs process, but I still get a stuck display after a bit, this time on the Armbian loading screen. SSH and Serial console work fine, its just the system stops knowing how to use the display after the initial boot sequence is done, and the kernel hands off the display to X11 / Wayland? This is consistent with how I believe tinydrm works, which is storing the image in memory and displaying new ones from memory if given (which in this case, none are given after a certain stage in the boot process and this hand off to the window manager never happens.) Need to figure out how to tell the system to keep using the drm display. I already tried putting /dev/dri/card0 instead of /dev/fb0 in 99-fbdev.conf, and I've been trying the following extraarg in /boot/armbianEnv.txt to try and get it to work. Screen still pauses halfway through boot messages / loading screen. extraargs=video=SPI-1:480x320@30 0 Quote
robertoj Posted December 11, 2025 Author Posted December 11, 2025 I am glad you made the LCD work with a DRM driver Three clarifications: the driver panel-mipi-dbi is provided in the OS image you write in the microSD. The DTS is something you get from this thread, and install it with armbian-add-overlay. Kungfupancake provides a txt or a bin file that defines the configuration sent to the LCD, when the kernel driver starts, and instructions on how to install it. The panel-mipi-dbi driver (the recent versions I tried) does not support X11, and you need 100% Wayland, and 0% X11 See my thread to install rpi-greeter (one of the 2 login managers that work with Wayland), and Labwc: 0 Quote
forumtrekker Posted December 17, 2025 Posted December 17, 2025 (edited) Will comment on the new thread, since the initial question of driving SPI displays with tinyDRM has been answered. Although, I'm starting to wonder if the kungfupancake modifications are inadequate for my display, since I still cannot get a full plymouth boot log to display (it seems to "run off the screen" a little at some point then just stop). Maybe its overflowing some buffer or the display is mis-sized or something and the screen is attempting to display physically off the screen? I don't really know. I might need to peruse LCDwiki to find other init commands. Edit: Actually it seems to be the SPI speed. A conservative 16 or 20 MHZ gets the display working, with significantly unusable screen tearing any higher than that. I have a direct jumper connection but my jumper cables are pretty long (about 20 cm) and some are crossed over, which might mean there is some interference. Will try shortening, since the low 16 or 20 MHz speed has very low FPS rates. It is strange because your display seems to work on 40MHz Edit 2: The ili9488 data sheet indicates it can use 16, 18, and 24 bit color modes, however attempting to use 16 bit (r5g6r5 on the format line) results in a worse tearing and garbled messes. Looks like it is over DPI or DSI only, not SPI. Also in the data sheet is indicatons that 20 MHz is the max framerate, explaining why higher rates are unstable. Should have read the data sheet! Everything seems to be working according to the hardware specifications, so squeezing more framerate is seeing if panel-mipi is capable of partial updates or seeing if I can up the data bus width.0 Edit 3: Confused again, because later in the data sheet, SPI mode states 8 colors (R1G1B1), 65k colors (R5G6B5) and 262K colors (R6G6B6) are supported, yet panel-mipi states only 666 is supported. Running 565 under panel-mipi shows the artifacts and tearing making it unusable, and trying 111 results in a white screen. This forum implies the LCD CAN use 565 mode. I'm quite confused, and this has probably become the wrong forum for this discussion? https://forum.clockworkpi.com/t/lcd-ili9488-really-doesnt-support-565-rgb-mode/16573 Edit 4: This github thread indicates that the datasheet is in error, and does NOT support 565 color, so looks like this display is restricted to 9-12 fps. Bummer. https://github.com/notro/panel-mipi-dbi/issues/2 Edit 5: This thread shows some ili9488 can work on 16 bit 565 mode?? Will try messing with panel-mipi init codes, but maybe this only applies for microcontrollers. https://forum.clockworkpi.com/t/ideas-for-improving-lcd-speed/17159/16 Edit 6: The MIPI DBI states the following formats, taken from this site: Spoiler Based on this rationale document the following pixel formats describing the bit layout going over the wire: - RGB111 (option 1): x2r1g1b1r1g1b1 (2 pixels per byte) - BGR111 (option 1): x2b1g1r1b1g1r1 (2 pixels per byte) - RGB111 (option 2): x1r1g1b1x1r1g1b1 (2 pixels per byte) - BGR111 (option 2): x1b1g1r1x1b1g1r1 (2 pixels per byte) - RGB565: r5g6b5 (2 bytes) - BGR565: b5g6r5 (2 bytes) - RGB666: r6x2g6x2b6x2 (3 bytes) - BGR666: b6x2g6x2r6x2 (3 bytes) Coupled with editing the init line from 18 bit to 16 or 3 bit color mode, in accordance to the thread I linked in edit 5 . Spoiler command 0x28 # Positive gamma control command 0xE0 0x00 0x03 0x09 0x08 0x16 0x0A 0x3F 0x78 0x4C 0x09 0x0A 0x08 0x16 0x1A 0x0F # Negative Gamma Control command 0xE1 0x00 0x16 0x19 0x03 0x0F 0x05 0x32 0x45 0x46 0x04 0x0E 0x0D 0x35 0x37 0x0F # Power Control 1 command 0xC0 0x17 0x15 # Power Control 2 command 0xC1 0x41 # VCON DIsplay burnout prevention command 0xC5 0x00 0x4D 0x80 # Memory Access Control command 0x36 0xE0 # Pixel Interface Format, 0x66 is 18 bit color, 0x55 is 16 bit color, 0x61 or 0x22 is 3 bit color command 0x3A 0x66 #Interface Mode Control command 0xB0 0x00 # Frame Rate Control command 0xB1 0xA0 # Display Function Control command 0xB6 0x02 0x02 0x3B # Entry Mode Set command 0xB7 0xC6 # Adjust Control 3 command 0xF7 0xA9 0x51 0x2C 0x82 #command 0x21 # Exit Sleep command 0x11 delay 200 # Display on command 0x29 delay 100 Still, yields no different results: it actually seems like editing the color init line in the bin file does nothing, and what actually matters is the color format specified in the DTS. R5G6B5 still shows garbled mess, and any of the four 3 bit color modes only shows a white screen. Edited December 19, 2025 by forumtrekker More reserach 0 Quote
pami Posted January 11 Posted January 11 (edited) Hi everyone. I'm new here. I found and ordered a 4-inch touchscreen with an ili9488 and xpt2046 on AliExpress. I was thinking about connecting it to a Raspberry Pi Zero 2W for my 3D printer's KlipperScreen. Since I had accelerometers connected to spi0, I connected the display and touchscreen to spi1. I thought it would be easy, since I found an article about connecting an ili9341 display to an Orange Pi Zero 3 for the same purpose: https://3dtoday.ru/blogs/3c60a2061c/dnevnik-tronxy-crux-1-displei-klipperscreen-seipery. But I'm new to Linux, so I followed guides to configure Klipper, literally copying and pasting commands. I'm using a ready-made mainsailos 64-bit. I spent almost a week trying to get the display working. I tried various ready-made libraries, but most of them gave me errors. For example, only after a couple of days of trying to use fbcp-9341 did I realize it doesn't support touch input, which isn't what I need, and that the library is only designed for 32-bit systems. I tried using AI based on the article with and without 3dtoday. But the best I could achieve was after some .dtbo file was /dev/fb1 and /dev/event0. When running one Python script, the screen displayed rectangles with gradients from white to black, but after changing the .dtbo file, when I ran the same script, I only got a black screen with multicolored dull horizontal stripes. I couldn't display any color other than black, white, and gray. I followed most of the steps suggested by the AI, since, as I already said, I'm a Linux noob. I'd be glad if someone could help me. My connection pins: Display -> Zero 2W CS - GPIO18(CE0.SPI1) RST - GPIO26 DC - GPIO13 SDI - GPIO20(MOSI.SPI1) SCK - GPIO21(SCK.SPI1) BL(LED) - GPIO6 Touch_CK - GPIO21(SCK.SPI1) Touch_CS - GPIO17(CE1.SPI1) Touch_DI - GPIO20(MOSI.SPI1) Touch_DO - GPIO19(MISO.SPI1) Touch_PEN - GPIO12 Note: I'm from Russia and my English is pretty bad, so all text was translated using a translator. I'm attaching a photo of the latest result I was able to achieve. Edited January 11 by pami 0 Quote
robertoj Posted January 12 Author Posted January 12 (edited) Forumtrekker: I am 99% sure that if you see the LCD working OK once, with kungfupancake or any other a txt/bin file, for just console text, it will work for any graphics. There's an issue with plymouth: it modifies the initrd in a way that it loses track of the bin file, and the kernel driver fails to load. See: https://forum.armbian.com/topic/53568-how-to-add-a-specific-single-file-in-the-initrdimg-ideally-automatically-with-update-initramfs/#comment-221767 I am running my SPI at 40MHz fine with 20cm wires. I don't have time to see your DTS file, but are you using the same CS pin as I do? I have noticed there's a default "chip select" pin, which makes everything work better. If you are using panel-mipi-dbi driver, don't use any additional DTS for the LCD, not even additional SPI DTS, and armbianEnv.txt that refer to the LCD. According to the notro wiki, the ili9486 and ili9488 will only work with RGB888 mode (because we use SPI). There's the "format" parameter line just for that, in my DTS. Can you send a good photo of your LCD front and back? My method is for a Red PCB LCD. I don't know the brand, but it is not Waveshare, Creality or any known company. Sorry, saying "Chinese LCD" is like saying "wet water": redundant and not specific. pami: the english in your post is fine, but you can separate ideas and separate processes in paragraphs, to let me focus in one problem at a time Many LCD guides, due to being so old, use the fbcopy driver, or another "classic framebuffer" driver. I could make my ili9341 work with it, but since I learned to use the panel-mipi-dbi I only started using that. It get's you more fluid animations and probably Linux will prefer it in the future. If one dtbo file and a python script makes your LCD work fine, share that script and DTBO (best if you can decompile the DTBO into DTS), in this thread, as attached files. Send more photos of your LCD. AI suggestions will only work if the solution is well documented somewhere in the internet, and the AI has found it. AI will re-word the answer and take credit for it. Edited January 12 by robertoj 0 Quote
pami Posted January 13 Posted January 13 1) Language. Either I expressed myself incorrectly or I was misunderstood, but my communication on this forum will most likely proceed as follows: My message in Russian -> Translator -> My message in English And the same in reverse order. 2) A little information about me. I'm a school student, so I'm unlikely to understand any of the high-tech terms. 3) AI If it helps, here's the most productive thread of conversation with Deepseek: https://chat.deepseek.com/share/20dl6vpqy97gpu4et4 4) DTBO and DTS Thanks to AI, almost every new version of dts had a new name, but they all seemed to compile to dtbo with the same name. I'm thinking of finding one that can produce a gradient, but I haven't succeeded yet, and I haven't tried everything. I don't know what color it should be, but mine was a white-to-black gradient. I'll also attach a Python script for it. I didn't create it separately, but wrote it directly into the SSH console (as far as I understand). 5) Raspberry Pi I have a primary 32 GB SD card, which I've been using since installing Klipper on my 3D printer. I also have a spare 64 GB SD card, which I installed MainsailOS, KlipperScreen, and added printer.cfg to. Initially, when I tried using ready-made libraries, I used the primary card, and even used it for a few attempts with AI. But then I switched to a second (spare) card, so that if I messed up the firmware or made any irreparable changes, I could reinstall the OS, reset it to its original state (as mentioned at the beginning), and then repeat all the necessary operations from the beginning. It's probably best to record all your steps somewhere so that after successfully setting up the screen on the spare card, you can repeat the necessary steps on the main card. Just in case, I'll save the current config.txt and all created dts files on my PC. 6) Display I'm attaching a photo of my display and another from the product page on AliExpress. I already have it soldered into the Raspberry Pi. During my attempts, I soldered from spi1 to spi0 and back maybe five times. But I'm tired of this and want to stick with the current pinout with spi1, since I have two more accelerometers on spi0, which I desoldered while setting up the display. 7) Display nuance During the first connection, I slightly damaged the solder mask of the ground plane near the positive contact of the display with a soldering iron and shorted it out with solder. I thought something on the display was broken, so I desoldered and checked some components (the microcircuit, capacitors, and resistor), but they were intact. It was only later that I discovered the real problem. After solving the problem, I connected the 5-volt power supply, but after a couple of hours, I decided to switch it to 3.3 volts just in case. I can switch it back to 5 volts if necessary. I hope this short-circuit situation didn't affect the operation in any way. If this is helpful, I've attached all the DTS versions I currently have; they can be opened in Notepad++. When I find the one that produces the gradient, I'll edit this post or write a new one. test_display.txt ili9488-debug.dts ili9488-fixed.dtbo ili9488-fixed.dts ili9488-fixed-gpio.dts ili9488-full-init.dts ili9488-priority.dts ili9488-test.dts ili9488-test-18bit.dts ili9488-test-bgr.dts ili9488-test-reg36.dts ili9488-test-rotate.dts ili9488-working.dts ili9488-xpt2046.dts ili9488-64bit.dts ili9488-correct-horizontal.dts 0 Quote
robertoj Posted January 14 Author Posted January 14 (edited) Hi Pami, I haven't had time to check your connection list and DTS. The LCD you showed is exactly the same I have I have both ili9486 and ili9488, and they work with the same connections, same DTS, same bin, same driver You should be able to copy all the wiring I describe in the DTS, the DTS, bin/txt and armbianEnv.txt line, and it should work. Start from a fresh self-built armbian OS, with the panel-mipi-dbi driver activated in the linux config phase. Edited January 14 by robertoj 0 Quote
pami Posted January 14 Posted January 14 It seems that I will definitely have to change the connection pins and something else, because I have a raspberry pi zero 2w, not an orange pi zero 3. Well, okay, I'll try to use your DTS only to adapt it for my board when I have free time. 0 Quote
robertoj Posted January 14 Author Posted January 14 I missed the fact that you have an orange pi zero 2w... I think there's a success experience with that orange pi in this thread or in this Allwinner section. Please share if you have success 0 Quote
pami Posted January 21 Posted January 21 Unfortunately, nothing's working for me yet(. It didn't work with dts, and my Python tests have only resulted in a gray screen and nothing else. I'm still using deepseek, as I don't understand it myself. Maybe I should connect the display's MISO? Although the display only seems to receive data, not transmit it. 0 Quote
robertoj Posted January 22 Author Posted January 22 I don't know what you could improve right now... But I know that LCD only receives data. My LCD works the same, with its MISO pin connected or disconnected. 0 Quote
forumtrekker Posted Sunday at 09:20 PM Posted Sunday at 09:20 PM (edited) Pami, I have not personally found any LLM capable of generating working DTS files no matter what. It seems to be too niche for the LLM to understand. This DTS could potentially be a good starting ground for the pi, replacing "bcm2835" which refers to the pi zero 1, with "bcm2710" which refers to the pi zero 2. The github repository I linked is a good guide to getting the red displays working for a voron printer using panel-mipi driver, and I referenced it to create the DTS I use for the rock pi 4b. Also, try lowering the SPI speed to 20, 16, or 10 MHz, then raise it when you verify it works. I was frustrating myself for weeks thinking my DTS was broken, when it was fine the entire time, just my SPI speed was too high. robertoj: I appreciate your help, but I believe the issue I have with the red display (I have the same one as pami sent) is a combination of SPI commands being sent at the wrong interval (at the end of the clock cycle instead of in line), as well as insufficient SPI speed - where the display freezes above 24 MHz, and shows extreme visual tearing below it. At RGB666, its too much data for a measly 20MHz SPI rate, and the board does not support any other RGB modes in SPI. Since the TE pin is not exposed on the board, I cannot sync the SPI writes to the display. At least, that is my theory. I've given up on using an SPI display, and instead transitioned to an RGB Parallel display, which uses one gpio pin per color bit. Note that, at least in the display datasheet I received, the display actually does have the pins needed to drive it over DPI RGB Parallel. You can drive the board in 16, 18, or 24 bit mode over DPI RGB Parallel. These pins are not exposed on the board, but you could use an FPC breakout board to interface with these pins, and drive the display in DPI RGB parallel instead (accounting for the backlight voltage needed). The advantage of using RGB Parallel is it natively uses the GPU (RGB Parallel is the same technology as VGA) and has very fast refresh rate. For anyone here in future, any DPI hats that exist, like the adafruit kippah or othermod dpi topper, do not have the correct pinout to interface with this specific ili9486/8, but if you were to rearrange the pins on either the HATS or with an intermediary FPC PCB, then they would work plug and play. Edited Sunday at 09:20 PM by forumtrekker 0 Quote
