herrmeier Posted July 30, 2017 Posted July 30, 2017 (edited) Hi Igor and everyone else who is supporting this forum with their time and effort. Thanks in advance for reading this and giving it a thought! Question: Any idea where I could turn off mounting /dev/sda1 read only? Problem description: Before moving cubietruck to a new location I did an dist-upgrade, after that a reboot didn't work. First I was asked for debug and root password. After editing I did try to solve my problems without using your help. But I did not succeed yet. Neither with installing a new image and restoring my lamp-stack from backup nor with solutions I found in this forum (changing u-boot config and so on). I did backup sd-card(16GB) and ssd(112GB) with rsync -aAhHXv to an external ext4 backup-harddrive, right after my cubietruck stopped booting. with sudo mount -o remount,rw /dev/sda1 / I can remount rw and start apache2, which doesn't start if /dev/sda1 ist mounted read only (ro) and prints an error AH000015, because it obviously can't write into in /var/log/apache2. So my 1st goal is to mount /dev/sda1 rw. I already deleted remount on error ro in fstab, but that didn't help. My problem seems to be, that even though sd-card and ssd came through an external test on another Ubuntu-PC sudo fsck.ext4 -v -f -c /dev/sdx1 without problems, my cubietruck boots only readonly. https://pastebin.com/2p3udhMu, https://pastebin.com/fJfH3Pce armbianmonitor -u https://pastebin.com/gdwdtU9k "Bad CRC" on system start This is the 1st error-message I see. It could be the source of my problems. How should I remove it? dmesg --level=err,warn|less https://pastebin.com/HaAJ73NT uname -a Linux cubietruchostname 4.11.6-sunxi #6 SMP Fri Jun 23 19:56:18 CEST 2017 armv7l armv7l armv7l GNU/Linux boot https://pastebin.com/5b4zBe26 /boot# less armbianEnv.txt verbosity=7 console=both disp_mode=1920x1080p60 rootdev=UUID=9e95b6ee-7600-4b79-8c96-4ba27d15e063 rootfstype= lmgtfy websearch - connected postings Edited July 30, 2017 by herrmeier info-update2
