Mark Leaf Posted December 16, 2024 Posted December 16, 2024 Looked at a lot of other forums posts and it seems to be a common problem for the Orange pi 5B, but all the solutions i've tried hasn't worked. Most of the problems they seemed to have is not updating the armbianEnv.txt to include the "b" for this specific model from the opi 5. Below is the error message I always get whenever trying to boot from the EMMC. Using 6.1 kernel sometimes I can't see the EMMC in /dev, after installing the orange pi Ubuntu image I can see it. After I run armbian-install I can't see it in /dev. I put the orange pi image back on the sd card and I can see the EMMC was installed, the boot/armbianEnv.txt also does have the "b". Using the 6.12 kernel the EMMC in /dev is always there after updating the armbianEnv.txt file though it is blk1 instead of blk0, but after installing it onto the EMMC I still get the same message below and a lot of things don't work like the HDMI. Not sure what else to try, it just doesn't seem to want to load with the emmc. DDR d5483af87d cym 23/11/23-16:15:24,fwver: v1.15 LPDDR4X, 2112MHz channel[0] BW=16 Col=10 Bk=8 CS0 Row=16 CS=1 Die BW=16 Size=1024MB channel[1] BW=16 Col=10 Bk=8 CS0 Row=16 CS=1 Die BW=16 Size=1024MB channel[2] BW=16 Col=10 Bk=8 CS0 Row=16 CS=1 Die BW=16 Size=1024MB channel[3] BW=16 Col=10 Bk=8 CS0 Row=16 CS=1 Die BW=16 Size=1024MB Manufacturer ID:0x1 CH0 RX Vref:31.4%, TX Vref:20.8%,0.0% CH1 RX Vref:30.5%, TX Vref:18.8%,0.0% CH2 RX Vref:32.2%, TX Vref:18.8%,0.0% CH3 RX Vref:33.0%, TX Vref:18.8%,0.0% change to F1: 528MHz change to F2: 1068MHz change to F3: 1560MHz change to F0: 2112MHz out U-Boot SPL board init U-Boot SPL 2017.09 (Nov 20 2024 - 16:59:31) unrecognized JEDEC id bytes: ff, ff, ff unknown raw ID ff ff ff Trying to boot from MMC2 MMC: no card present mmc_init: -123, time 0 spl: mmc init failed with error: -123 Trying to boot from MMC1 Card did not respond to voltage select! mmc_init: -95, time 13 spl: mmc init failed with error: -95 SPL: failed to boot from all boot devices ### ERROR ### Please RESET the board ### # Reset the board to bootrom # Here's also the logs from Kernel 6.1 when the emmc doesn't load: https://paste.next.armbian.com/lahurekilu 0 Quote
linhz0hz Posted January 2 Posted January 2 I hit the same issue. Sometimes emmc is not recognized. Joshua's ubuntu-rockchip seems to work for me but I prefer working with armbian. 0 Quote
