ir_led Posted 16 hours ago Posted 16 hours ago I got a board and want to test if it turns on at all. Is there any way to short the pins somewhere to get it to turn on? I don't have the remote but I suppose connecting the DC barrel should be enough to get some lights but nothing happens? Any help is appreciated. 0 Quote
Hqnicolas Posted 15 hours ago Posted 15 hours ago We are very sorry that your device was damaged, I suggest you contact the manufacturer of the product so that they can give you all the support you deserve as a paying consumer of the product. If the manufacturer is listed in the link below, I believe you will have better luck with your device. https://www.armbian.com/partners/ I would like you to replace your device with a device from my preferred manufacturer https://www.banana-pi.org/ 1 Quote
