Roman B Posted December 25, 2024 Posted December 25, 2024 Current community builds(Debian 12 and Ubuntu 24.04 as well) doesn't support audio codec. Even after enabling codecs with armbian-config ls /dev/snd command displays: seq timer when expectation is to have by-path controlC0 pcmC0D0c pcmC0D0p seq timer Have anybody face with the same issue? any advises how to solve it? 0 Quote
Solution Roman B Posted December 26, 2024 Author Solution Posted December 26, 2024 armbian-config app sets param overlay in /boot/armbianEnv.txt to the: overlays=sun8i-h3-analog-codec Fix is changing it to: overlays=analog-codec 0 Quote
robertoj Posted December 26, 2024 Posted December 26, 2024 thank you for posting the fix 👍🏽 Can you show the contents of armbianEnv.txt? Also find the sun8i-h3-analog-codec.dtbo file inside the /boot/dtb/… folder you can always check that overlays are being used, by looking at the uboot messages, before loading the kernel. https://docs.armbian.com/User-Guide_Armbian_overlays/ 0 Quote
Roman B Posted December 26, 2024 Author Posted December 26, 2024 Hi @robertoj My working armbianEnv.txt has the following content: verbosity=1 bootlogo=false console=both disp_mode=1920x1080p60 overlay_prefix=sun8i-h3 overlays=analog-codec usbhost2 usbhost3 rootdev=UUID=0fbbb0fc-697c-46c9-a6b1-3c16cc045b69 rootfstype=ext4 usbstoragequirks=0x2537:0x1066:u,0x2537:0x1068:u 0 Quote
robertoj Posted December 27, 2024 Posted December 27, 2024 that looks like a normal armbianEnv.txt If there was a "sun8i-h3-analog-codec" in the overlays line, that is pretty weird. 0 Quote
