I just created a new image and am reporting the following:
- On the first boot, I don't have Ethernet (I don't use wireless) and
- The eMMC is not detected.
Thanks
root@orangepi-4a:~# cat /etc/armbian-release
# PLEASE DO NOT EDIT THIS FILE
BOARD=orangepi-4a
BOARD_NAME="Orange Pi 4A"
BOARDFAMILY=sun55iw3
BUILD_REPOSITORY_URL=https://github.com/armbian/build
BUILD_REPOSITORY_COMMIT=28862c7
LINUXFAMILY=sunxi64
ARCH=arm64
BOOT_SOC=
IMAGE_TYPE=user-built
BOARD_TYPE=csc
INITRD_ARCH=arm64
KERNEL_IMAGE_TYPE=Image
KERNEL_TARGET=edge
KERNEL_TEST_TARGET=
FORCE_BOOTSCRIPT_UPDATE=
FORCE_UBOOT_UPDATE=
OVERLAY_DIR="/boot/dtb/allwinner/overlay"
VENDOR="Armbian-unofficial"
VENDORCOLOR="247;16;0"
VENDORDOCS="https://docs.armbian.com/"
VENDORURL="https://duckduckgo.com/"
VENDORSUPPORT="https://community.armbian.com/"
VENDORBUGS="https://armbian.atlassian.net/"
BOOTSCRIPT_FORCE_UPDATE="no"
BOOTSCRIPT_DST="boot.cmd"
VERSION=26.05.0-trunk
REVISION=26.05.0-trunk
BRANCH=edge
root@orangepi-4a:~#
root@orangepi-4a:~#
root@orangepi-4a:~# dmesg | grep -i mmc
[    4.418379] sunxi-mmc 4020000.mmc: Got CD GPIO
[    4.418857] sunxi-mmc 4021000.mmc: allocated mmc-pwrseq
[    4.444666] sunxi-mmc 4022000.mmc: initialized, max. request size: 2048 KB, uses new timings mode
[    4.444692] sunxi-mmc 4021000.mmc: initialized, max. request size: 2048 KB, uses new timings mode
[    4.445215] sunxi-mmc 4020000.mmc: initialized, max. request size: 2048 KB, uses new timings mode
[    4.487006] mmc0: host does not support reading read-only switch, assuming write-enable
[    4.490389] mmc0: new high speed SDXC card at address aaaa
[    4.497740] mmcblk0: mmc0:aaaa SC64G 59.5 GiB
[    4.522286]  mmcblk0: p1 p2
[    4.585097] mmc2: error -110 whilst initialising MMC card
[    4.592377] mmc1: new high speed SDIO card at address 0001
[    4.596828] mmc2: Failed to initialize a non-removable card
[    7.193467] EXT4-fs (mmcblk0p2): mounted filesystem 757e37e7-0e5e-4683-8110-4a8276f032d5 ro with writeback data mode. Quota mode: none.
[   10.627502] EXT4-fs (mmcblk0p2): re-mounted 757e37e7-0e5e-4683-8110-4a8276f032d5 r/w.
[   12.277240] brcmfmac mmc1:0001:1: Direct firmware load for brcm/brcmfmac43456-sdio.xunlong,orangepi-4a.bin failed with error -2
root@orangepi-4a:~#
root@orangepi-4a:~#
root@orangepi-4a:~# uname -a
Linux orangepi-4a 7.0.0-rc6-edge-sunxi64 #2 SMP PREEMPT Sun Mar 29 22:40:00 UTC 2026 aarch64 GNU/Linux
root@orangepi-4a:~#
Edited by JamesCL
