Murat Demirtas Posted March 3, 2025 Posted March 3, 2025 (edited) Hello, friends... The current MIPI DSI driver provided by Rockchip Inc. in older U-Boot versions (v2023 and earlier) is not compatible with U-Boot’s uclass subsystems.(a waste of time if you want to develop). I have done extensive research and made modifications to several files to make it work with the latest U-Boot versions. I have tested it with U-Boot 2023.10, 2024.10 and v2025.rc3 on orange pi 4 lts, and it works perfectly. I'm attaching the necessary files for those who need them. This u-boot driver is nearly identical to Rockchip's Linux kernel driver, uses same driver file but there some limitations because of u-boot system, but it correctly displays the splash image when vidconsole0 probed by u-boot.. Additionally, i want to say that, in linux kernel side, the same dw-rockchip-dsi driver in latest armbian distribitions works with from kernels 5.18 to latest kernel v6.6 and v.6.12. I tested it. Tested with custom 400x1200 60hz 4 lane standart mipi dsi panel from chinese panel manufacturer. I attached all modified files as attachment. Good lucks. dm tree command output from u-boot is reset 1 [ + ] rockchip_reset | `-- reset syscon 27 [ + ] rk3399_syscon |-- syscon@ff770000 nop 3 [ + ] rockchip_iodomain | `-- io-domains video 0 [ + ] rk3399_vop |-- vop@ff8f0000 vidconsole 0 [ + ] vidconsole0 | `-- vop@ff8f0000.vidconsole0 video 1 [ + ] rk3399_vop |-- vop@ff900000 vidconsole 1 [ + ] vidconsole0 | `-- vop@ff900000.vidconsole0 video_brid 0 [ + ] dw-mipi-dsi-rockchip |-- dsi@ff960000 dsi_host 0 [ + ] dw_mipi_dsi | |-- dsihost panel 0 [ + ] rm68200_panel | `-- panel@0 pinctrl 0 [ + ] rockchip_rk3399_pinc |-- pinctrl U-Boot 2024.10-armbian-2024.10-Sf919-Pbfb2-H3d34-Vade7-Bb703-R448a-dirty (Mar 03 2025 - 06:16:04 +0300) SoC: Rockchip rk3399 Reset cause: RST Model: Orange Pi 4 LTS Board DRAM: 4 GiB (effective 3.9 GiB) PMIC: RK808 Core: 285 devices, 32 uclasses, devicetree: separate MMC: mmc@fe320000: 1, mmc@fe330000: 0 Loading Environment from MMC... Reading from MMC(0)... *** Warning - bad CRC, using default environment rm68200_panel_of_to_plat() rm68200_panel panel@0: reset pin set done rm68200_panel_probe() rm68200_panel panel@0: Initializing MIPI DSI Panel Driver rm68200_panel_probe() rm68200_panel panel@0: Reset sequence done rm68200_panel_probe() rm68200_panel panel@0: dsi set 4 lane, video-burst, RGB 24-bit mode rm68200_panel_enable_backlight() rm68200_panel panel@0: Panel set backlight func(), initializing panel rm68200_panel_enable_backlight() rm68200_panel panel@0: attaching mipi dsi panel rm68200_panel_enable_backlight() rm68200_panel panel@0: perform panel initialization sequence rm68200_panel_enable_backlight() rm68200_panel panel@0: panel initialization sequence done, panel probed! rm68200_panel_enable_backlight() rm68200_panel panel@0: Panel set backlight func(), initializing panel rm68200_panel_enable_backlight() rm68200_panel panel@0: attaching mipi dsi panel rm68200_panel_enable_backlight() rm68200_panel panel@0: perform panel initialization sequence rm68200_panel_enable_backlight() rm68200_panel panel@0: panel initialization sequence done, panel probed! In: serial@ff1a0000 Out: serial@ff1a0000 Err: serial@ff1a0000 Model: Orange Pi 4 LTS Board Net: Could not get PHY for ethernet@fe300000: addr 1 eth_initialize() No ethernet found. Hit any key to stop autoboot: 0 => dcdcddcdcdcdc<INTERRUPT> => setenv splashimage 0x82000000 => setenv splashfile /boot/splash.bmp => load mmc 0:1 ${splashimage} ${splashfile} 1920138 bytes read in 61 ms (30 MiB/s) => bmp display ${splashimage} => <INTERRUPT> => uclass_get_device_by_ofnode() Looking for clock-controller@ff760000 uclass_find_device_by_ofnode() Looking for clock-controller@ff760000 uclass_find_device_by_ofnode() - checking reset uclass_find_device_by_ofnode() - checking reset uclass_find_device_by_ofnode() - result for clock-controller@ff760000: reset (ret=0) uclass_get_device_by_ofnode() - result for clock-controller@ff760000: reset (ret=0) rm68200_panel_enable_backlight() rm68200_panel panel@0: Panel set backlight func(), initializing panel rm68200_panel_enable_backlight() rm68200_panel panel@0: attaching mipi dsi panel rm68200_panel_enable_backlight() rm68200_panel panel@0: perform panel initialization sequence rm68200_panel_enable_backlight() rm68200_panel panel@0: panel initialization sequence done, panel probed! dsi_phy_post_set_mode() dw-mipi-dsi-rockchip dsi@ff960000: Set mode 00000000f4f3b4a0 enable 1 device_bind_common() Bound device vop@ff900000.vidconsole0 to vop@ff900000 notify_dynamic() Sending event 5/(unknown) to spy 'efi_disk add' notify_dynamic() Sending event 5/(unknown) to spy 'efi_disk add' In: serial@ff1a0000 Out: serial@ff1a0000 Err: serial@ff1a0000 Model: Orange Pi 4 LTS Board raydium-rm68200.c dw_mipi_dsi.c rk_vop.c dw_mipi_dsi_rockchip.c clk_rk3399.c .config rk3399-orangepi.dts Edited March 3, 2025 by Murat Demirtas 0 Quote
Murat Demirtas Posted March 19, 2025 Author Posted March 19, 2025 (edited) i modified the dts file. There was a boot error when use both vopl and vopb and when not use both in linux kernel. the example boot sequence mipi video i will upload who interest. There is a flicker when load kernel from uboot that i am on the solve. rk3399-orangepi.dts Edited March 19, 2025 by Murat Demirtas 0 Quote
