Hi guys,
Since I'm out of GPIOs I would like to reuse the Debug UART0 RX/TX in "release" if no serial module is attached.
I'm using a nanopi Duo2 but that question applies to the general strategy.
The NanoPi UART0 RX can be used as PA5, PWM output.
I did already play successfully with overlay files for other purposes so I know a little how that works.
Can I create a overlay with shared usage, and depending on the loaded module (tty*) the RS232 is
operating, or when this is stopped i can use the PWM out?
Is this "Shared overlay" in general the right approach? If yes could someone point me to some hints
how to craft such a sharing overlay?
Sure I need to figure out in general how to setup PWM but thats a different story i think.
      Thilo
