Rob Latour Posted April 12, 2025 Posted April 12, 2025 Armbianmonitor: https://paste.armbian.com/danepiravi When I try a sudo apt update it works. However, when I try a sudo apt upgrade or sudo apt full-upgrade they fail, Here is an example of what I am getting: sudo apt full-upgrade Reading package lists... Done Building dependency tree... Done Reading state information... Done You might want to run 'apt --fix-broken install' to correct these. The following packages have unmet dependencies: libraspberrypi0 : Depends: raspberrypi-bootloader but it is not installable or raspi-firmware but it is not installed E: Unmet dependencies. Try 'apt --fix-broken install' with no packages (or specify a solution). any help would be appreciated. 0 Quote
Rob Latour Posted April 13, 2025 Author Posted April 13, 2025 The following has resolved the issue for me: armbian-upgrade sudo apt remove libraspberrypi0 libraspberrypi-bin sudo apt update sudo apt upgrade thanks to geoW here: https://help.nextcloud.com/t/internal-server-error-after-php8-3-upgrade-on-12-apr-ncp-1-55-3-on-rpi5/222576/2 0 Quote
