Menion Posted September 11, 2017 Posted September 11, 2017 Hi all I am trying to build Armbian (Xenial Server) for H5 orangepipc2 I nee to customize kernel config to add some DVB drivers. The compilation starts but I get this error, but without any usefull information What I get is: CC [M] drivers/staging/rtl8723bs/os_dep/rtw_proc.o CC [M] drivers/staging/rtl8723bs/os_dep/sdio_intf.o CC [M] drivers/staging/rtl8723bs/os_dep/sdio_ops_linux.o CC [M] drivers/staging/rtl8723bs/os_dep/wifi_regd.o CC [M] drivers/staging/rtl8723bs/os_dep/xmit_linux.o LD [M] drivers/staging/rtl8723bs/r8723bs.o AR drivers/staging/built-in.o AR drivers/built-in.o [ error ] ERROR in function compile_kernel [ compilation.sh:338 ] [ error ] Kernel was not built [ @host ] [ o.k. ] Process terminated output.log in debug directory is not helping too much Displaying message: Compressing sources for the linux-source package Displaying message: Compiling dev kernel 4.13.0 info Displaying message: Compiler version aarch64-linux-gnu-gcc 7.1.1 info Displaying message: Using kernel config file lib/config/kernel/linux-sun50i-dev.config info Displaying message: Exporting new kernel config /home/menion/armbian/build/output/linux-sun50i-dev.config info Displaying message: ERROR in function compile_kernel compilation.sh:338 err Displaying message: Kernel was not built @host err Displaying message: Process terminated info (I would add timestamp in output.log anyhow) I am really lost, maybe some Armbian devs can help here Bye
zador.blood.stained Posted September 11, 2017 Posted September 11, 2017 The actual error message will he earlier/higher in the output, compilation doesn't stop immediately on error since it runs multiple processes in parallel.
