Danubio Rodriguez Posted Saturday at 12:07 AM Posted Saturday at 12:07 AM (edited) I have a big problem with the latest Armbian images, the problem not only persists with the latest versions, with the previous one the same thing happened to me with the old Ubuntu images, it works without problems with the old kernel, I have a video published with the problem since it works but at certain times the device turns off and does not turn on a single LED light until I reconnect it, I thought it was a problem with the power supply but not with the old Ubuntu images it works and even with the game emulators of the lakka-tv image, so I came to the conclusion that the hardware is in good condition, therefore check what the fault could be because the computer usually turns off. I leave the link of the video it is in Spanish, sorry . HARDWARE: Banana Pi M1 Edited Saturday at 12:10 AM by Danubio Rodriguez 0 Quote
Ryzer Posted 3 hours ago Posted 3 hours ago What SD card are you using? I don't believe the A20 is up to the task of running a modern desktop. It could still be a power issue if indeed no LEDs are on at all. Does the device turn off happen randomly or when the Banana Pi M1 power down when under high load? I'd advise getting a USB to Serial adapter to get a better idea of what is happening on the board. Best of luck Ryzer 0 Quote
