James Kingdon Posted September 13, 2017 Posted September 13, 2017 Hi, I'm trying to iterate quickly to test out some ideas on the mmc driver, so I was wondering if it is possible to prevent re-downloading the sources every time. It looked like IGNORE_UPDATES=yes might be what I want, but when I tried that I got a failure during compile_atf: [ o.k. ] Installing [ rkbin-tools ] [ o.k. ] Cleaning output/debs for [ pinebook-a64 default ] [ o.k. ] Cleaning [ o.k. ] Compiling ATF [ o.k. ] Compiler version [ aarch64-linux-gnu-gcc 6.4.1 ] [ o.k. ] Started patching process for [ atf pine64-pinebook-a64-default ] [ o.k. ] Looking for user patches in [ userpatches/atf/atf-pine64 ] make: *** No rule to make target 'bl31'. Stop. [ error ] ERROR in function compile_atf [ compilation.sh:65 ] [ error ] ATF compilation failed [ o.k. ] Process terminated I'm using docker so my command line was $ ./compile.sh docker IGNORE_UPDATES=yes
zador.blood.stained Posted September 14, 2017 Posted September 14, 2017 23 hours ago, James Kingdon said: Hi, I'm trying to iterate quickly to test out some ideas on the mmc driver, so I was wondering if it is possible to prevent re-downloading the sources every time. Which sources? Kernel and u-boot? With Docker they should be cached in a named volume "armbian-cache" together with some other things. On 13.09.2017 at 10:19 PM, James Kingdon said: $ ./compile.sh docker IGNORE_UPDATES=yes IGNORE_UPDATES is for internal use, it wasn't tested with any build scenarios apart from BUILD_ALL.
James Kingdon Posted September 14, 2017 Author Posted September 14, 2017 Hi Zador, thanks for replying. Yes, kernel and u-boot sources. They are indeed in the cache which is why I can get away with not downloading them on each build. For reasons I haven't been able to fathom, in this particular location the environment inside docker can't resolve github.com, so every attempt to contact it results in a long timeout which was slowing the builds down a lot. No worries on IGNORE_UPDATES. I made some quick changes to the scripts to skip the downloads and only compile u-boot while I was working on that part and it did what I needed it to do. I understand that I'm not using the tools the way they were intended, so it's not surprising that things aren't quite straight forward
