regulatory.db failing to load
Go to solution Solved by MichaIng,
On the ROCK 5B+, I am getting the following error at boot
[   12.361648] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[   12.389297] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[   12.390688] cfg80211: Loaded X.509 cert 'wens: 61c038651aabdcf94bd0ac7ff06c7248db18c600'
[   12.392699] cfg80211: loaded regulatory.db is malformed or signature is missing/invalid
I believe this is the cause of being unable to set the regulatory region for WiFi.
Running
sudo iw reg get
returns
global
country 00: DFS-UNSET
even after running
sudo iw reg set GB
  • Solution
CRDA is deprecated, not needed since Linux 4.15, hence the package removed with Debian Bookworm. Problem is the default regulatory database on Debian works with Debian kernel only, not with Armbian kernel. But wireless-regdb provides the upstream database as well, so you only need to switch:
sudo update-alternatives --set regulatory.db /lib/firmware/regulatory.db-upstream
