thewiseguyshivam Posted May 30 Posted May 30 Hi! I have an old Allwinner A10 based tablet that runs on Android. I want to install some other OS on it. I tried the instructions on linux-sunxi.org and created a page for the tablet: https://linux-sunxi.org/Softwinners_crane I extracted the FEX file from an image I got from the manufacturers a long time ago: http://github.com/linux-sunxi/sunxi-boards/pull/72/files The linux-sunxi mailing list pointed out that my tablet is similar to Topwise A721, so I used that dts file to compile u-boot and the kernel, and tried to boot it through an SD card. Trying to boot that, u-boot starts, and then gets stuck at "Starting kernel..." Then I found this: After following this and building armbian, I realised that there is no script.bin to replace anymore (I'm guessing because now we use device trees?), so unable to boot this as well. What should I do to make this work with armbian? My guess is that I need to create a new dts or correct the Topwise A721 dts (https://github.com/torvalds/linux/blob/master/arch/arm/boot/dts/allwinner/sun4i-a10-topwise-a721.dts) and then try again. The only problem is that I have no experience with device trees. Would really appreciate help on getting this to work, thanks! :) 0 Quote
Ryzer Posted May 30 Posted May 30 HI, I dont believe it is necessary to recreate the Topwise A721 dts as it should already be included in the kernel sources used. What most likely needs to be done as a minimum is config file so that the Armbian build system recognizes the board and knows how to handle it. Admittedly I have never added a board so I can only speculate. A problem you may face is that the internal LCD may no longer work with the latest kernels. best of luck Ryzer 0 Quote
thewiseguyshivam Posted May 30 Author Posted May 30 Hi! Great, that's a good starting point. So where could I find a reference file I can edit and align with my tablet? And where should I place this file? How would this file (possibly) connect to some dts? (This is just for my curiosity) Thank you! 0 Quote
Ryzer Posted May 30 Posted May 30 All Armbian board configurations files live in build/config/board/ Besides the Pcduino2 Cubieboard and OlinuXino-lime board, I don't know what other A10 boards still have some level of support. After that the next step would probably be to confirm that it works with uboot. Here you have another config file and dts. For any tweaks to uboot you will need to pass uboot-patch when running compile.sh. Note that when you do this you will need to open a new tab and navigate to cache/sources/u-boot-worktree/ Similiarly for the kernel you would navigate to cache/sources/kernel/ currently 6.12 is "current" while 6.14 is "edge" Hope this helps Ryzer 0 Quote
thewiseguyshivam Posted June 1 Author Posted June 1 Great, so I used the config file provided in the previous post that I quoted, with a small change: I replaced "LINUXFAMILY" with "BOARDFAMILY". Am I to place patches to the kernel and u-boot inside userpatches? When in the build process should I do that? U-boot does work currently, and the original problem when I try to boot is that after "Starting Kernel..." I have nothing visible over HDMI or on the on board display (Or no way to check that I know of if anything is working). What I understand currently is that since U-boot works, I need to first provide a dts file that makes the display work, and then configure armbian build script to use that dts file, is that the way to go? On linux-sunxi mailing list I was told that the display on this works with the simple panel driver using the "starry kr070pe2t" entry. At this point I am not sure what the immediate next step should be. Thank you! 0 Quote
Ryzer Posted June 1 Posted June 1 Right to clarify what I described earlier was the patch creation process, where you would modify an existing file or if the file does not exist you would create in the relevant. After running for a bit the build process will pause. At this point you would need to open a new tab and navigate to cache/sources/linux-kernel-worktree/6.12__sunxi__armhf/arch/arm/boot/dts/allwinner. Here you would need to amend the sun4i-a10-topwise-a721.dts. According to the dts it already has the panel node so the on board display should at least work unless the driver is broken or device tree bindings have changed. Unfortunately I havent worked with panels so cannot provide much further assistance for other than confirming that an entry exist in the simple panel driver. sudo modinfo panel-simple | grep starry [sudo] password for ryan: alias: of:N*T*Cstarry,kr070pe2tC* alias: of:N*T*Cstarry,kr070pe2t ryan@pcduino2-1:~$ Normally to get hdmi to work you simply have to enable the hdmi nodes plus create a hdmi connector node. I have attached the patch that I use on my pcduino2, applying the same alterations to the dts of the topwise's dts should work. I have had issues with hdmi display in 6.12 which I found a work around for but not perfect as we have to modify the hdmi driver. From What I can tell the problem is related to atomic check function: https://patchwork.kernel.org/project/linux-arm-kernel/patch/20241130-hdmi-mode-valid-v5-10-742644ec3b1f@linaro.org/ It may be fixed in kernel 6.14 but I havent tested it yet. save the changes in your text editor and exit. Return to the tab running the build script, hit enter and it will generate a preview of the changes and ask if you are happy with the changes or not. type 'y' to accept. Luckily the build process will helpfully walk you through these steps. Once the build process has finished go to output/patch/. and rename the newly generated patch something useful so that you remember its purpose. Then move it into patches or userpatches. Which is up to you but personally, I prefer to have my patches in userpatches unless it is something I plan to merge in future. whenever you run git pull to fetch the latest version of armbian build, the patch directory is likely to be updated whereas userpatches is not affected. A caveat with userpatches is that full directory structure is not pre-existing so you have to manually create it, mirroring the patches directory. Also note that userpatches are applied after patches in the patch directory. Did you clone Armbian build directly or are you work off your own fork? Now what i tend to do is rerun the build process to check that the patch was applied successful. So rerun ./compile.sh BOARD=topwise-A721 (Replace with the name used in your config file) BRANCH=current RELEASE=bookworm kernel-patch. if successful it should appear in the list of patches and if applied under usepatches it will helpful be the last entry on the list. Unless you have any further patches to apply you can then go on to running a full build. I am suprised no one has yet done a video on the patching process yet Have you attempted disassembling the tablet to check for any solder pads present which could be the serial console? If there is then it may be possible to hook up a usb to serial converter. This could at least be a solid indicator to confirm that the device is at least booting. best of luck Ryzer pcduino2-hdmi-enable.patch 0 Quote
thewiseguyshivam Posted June 7 Author Posted June 7 Thank you so much for the detailed description of the patching process. I got back to this after a week and finally decided to solder a serial connection to the tablet main board and check whether the device boots up at all. After wiring the UART terminals, I used a Raspberry Pi Pico as a USB to serial converter (https://github.com/Noltari/pico-uart-bridge) and used PuTTY on Windows to get the serial console. To my pleasant surprise, armbian does boot! Couple of things that I see during the boot: BUG: Bad page state in process (ate-utmp) pfn:7a7b5 BUG: Bad page state in process dpkg-query pfn:79dc7 BUG: Bad page state in process armbian-hardwar pfn:78727 BUG: Bad page state in process NetworkManager pte:7842718f pmd:7f90e831 addr:b576a000 vm_flags:00000075 anon_vma:00000000 mapping:c22eb7c0 index:a file: libgvfsdbus.so fault:filemap_fault mmap:ext4_file_mmap [ext4] read_folio:ext4_read_folio [ext4] And then it boots to the terminal. On entering root as username and 1234 as password, it tells me my credentials are not correct. Next step for me is to try your kernel patch and check if I can get the display to work, and then try to see what I can do to log into the system. Really appreciate the help and will keep this topic updated, Shivam 0 Quote
Ryzer Posted June 8 Posted June 8 Ok that is a promising start at least. Are the 'BUG: bad page state messages' every boot or occasionally? The route cause will probably be difficult to find, possibly a deep route kernel or hardware issue. I tend to find that sometimes I will get the bad page state messages and then on another occassion get no kind of faults. You shouldnt need to enter any credientials on first boot, that only applies to setup over network connection. Once you have been able to login and if wireless works then you can install memtester to see if that picks up an errors. not a problem, looking forward to hearing your progress Ryzer 0 Quote
thewiseguyshivam Posted June 10 Author Posted June 10 I see this bug increasingly, and now even a lot of kernel panic and shutdowns, but I was able to get the login screen two or three more times. At the login I faced the same error: using root and 1234 I was told 'login incorrect'. I tried to check whether this is an SD card related issue, and I used h2testw to test my Class 10 SD card, and got no errors there. Then I tried to recompile armbian but repeatedly got this error: https://paste.armbian.eu/daxamubowe So I am unable to build now, but the next thing I am going to try is the Cubieboard pre-built image and see what happens. Thanks, Shivam 0 Quote
Ryzer Posted June 10 Posted June 10 That is worrying, I wonder if there could potentially be issues with the RAM, which could either be faulty or clocked higher than a level it is stable at. Reffering back to the fex you provide earlier it suggest a dram value of 384, so you may have to the def_config file to include the line CONFIG_DRAM_CLK=384. Is the card just class 10 rated or is it an A1 SD card? https://docs.armbian.com/User-Guide_Getting-Started/ Strange it should auto login on first boot. What it should be request is to set a new root password then confirming that password. Could you please provide a screen shot of the login screen you are greeted with. Alternatively it may be possible to set the root password external to get around this issue. Please see: https://docs.armbian.com/User-Guide_Autoconfig/ Strange never encoutered that before, have you tried pulling the latest version of armbian build to see if it fixes it? Unfortunately I have not had a lot of luck in trying to get WSL2 to work so I have stuck with virtual box. Worth a shot with the pre-built images, but I dont believe the Cubieboard is in a much better state. best of luck Ryzer 0 Quote
thewiseguyshivam Posted June 12 Author Posted June 12 (edited) Here is the login prompt that failed: And about my SD Card, it is just a class 10 SanDisk Ultra card but does not say A1 anywhere. So next I tried the pre-built image for Cubieboard and it booted too! This is more stable than before, but as soon as I try to do downloads or file operations, I start seeing similar page state or mmc errors. I think this might be related to RAM frequencies as you mentioned. Is there a way I can change DRAM clock on a system after it boots? Adding to that, is there a way I can enable the display on this after it boots, or install drivers using an overlay? That would be great to test things out. I am trying to build again but it keeps failing at the same stage as last time, even after pulling the latest version. I think I should try either docker or a VM to build this, because it does not seem to be working on WSL. EDIT(13/6/25): Similar errors related to apt sources in stage 2 of rootfs build process even when using Ubuntu 24.04 on VirtualBox. So I'm not able to build at all at this point. Thanks, Shivam Edited June 13 by thewiseguyshivam Added another failed scenario 0 Quote
Ryzer Posted June 13 Posted June 13 (edited) In that case I would strongly recommend purchasing an A1 rated SD card before trying anything else. If you are getting MMC related errors these are definitely related to the SD card rather than RAM. Once you have done this then we can look into DRAM config if need be. Trying to enable the display post build is kinda tricky. If it was just a matter of adding the HDMI display nodes, then yes that is normally possible however the display driver needs a slight patch in order to work. Now if you had kernel headers installed you could try to build the driver however another current problem means that custom loaded modules seem to not load/unload properly. Seeming as you are using the pre-built Cubieboard images, it already has the display nodes in place but not the recent patches to sun4i-drm. Looking again at the build log you provided earlier it looks like something is blocking the download of bookworm distro which is why it is failing. what happens if you trying ping apt.armbian.com? Given that this issue happens with bookworm, I wonder if it will also happen if trying build with Ubuntu Noble instead. I am currently working on formally including the display patches on my latest development branch so please bear with me. Best of luck Ryzer Edited June 13 by Ryzer 0 Quote
thewiseguyshivam Posted June 13 Author Posted June 13 So I kept trying to build inside VirtualBox and on my 3rd try I was able to get an image built (along with the patch that you shared). I tried that on the Class 10 card and got some "Bad Page Map in process xxx" errors, although it did boot and I was able to set it up. On running any command I keep getting these errors and most commands fail. Then I got an A2 card and tried the same image on that, with the same results. Towards the end it tries to turn HDMI on but fails because of said errors. I am attaching the terminal output from the A2 card run here: https://pastebin.com/7H70dUNN What do you think the errors are related to? The RAM? I want to mention that since I have the original Android image on the NAND, I can confirm that it runs okay. Thanks,' Shivam 0 Quote
Ryzer Posted June 13 Posted June 13 Right, I was thinking what if you try forcing a different mirror via DOWNLOAD_MIRROR: https://docs.armbian.com/Developer-Guide_Build-Switches/#hidden-options-for-advanced-users-default-values-are-marked-bold I cant guarantee this will work though. While A2 cards offer better performance, they are not as well supported. That is still the case to the best of my knowledge. Right one of the caveats I did find with getting HDMI working was the likelihood of increased taints so I think this patch is also required: https://git.kernel.org/pub/scm/linux/kernel/git/stable/linux.git/commit/drivers/gpu/drm/sun4i/sun4i_hdmi_enc.c?h=v6.14.11&id=ae048fc4f96d716a2ef326bd6e894694057c078c It is a possibility that either the RAM could be faulty or just unstable and need fine tuning. The problem is that really old system images tend to be less picky about RAM issues and will still try to boot. Normally I would say try installing memtester but that seems to detect failures in the most recent kernel yet my 6.6 build found no memory issues. Besides the originally Android image, have you tested with one of the archived images? More importantly what exactly are the RAM chips used on the board? Can you confirm the actual RAM capacity? From my experience, my second pcduino2 board with the Skhynix RAM had these sorts of problems. Sorry I cant be of more help Ryzer 0 Quote
thewiseguyshivam Posted June 14 Author Posted June 14 Okay I will try that patch and the build switch that you mentioned. About the RAM: It is SKHynix 966.3MB(989480kB) https://linux-sunxi.org/File:A088_Board_Front_3.jpg I then tried an archived image for the cubieboard and so far no errors and runs quite stable: https://armbian.atomonetworks.com/archive/cubieboard/archive/ Is this a kernel issue then? Maybe I should compile with an older kernel. The stable one is 6.1.63 Thanks a lot for your continued support, Shivam 0 Quote
Ryzer Posted June 15 Posted June 15 (edited) Right so 1GB - display framebuffer allocation. Can you confirm HDMI works as it been a while since I built an system image with 6.1 kernel. I dont recall display issues, just problems relating to SPI at the time. Anyway kernel 6.1 is no longer supported, even as a legacy kernel. The earliest kernel you can now build with is 6.6. I am suprised that the mirrror archives I have looked at so far do not feature any 6.6 kernel builds for the Cubieboard. Thats not to say it would be impossible to compile with an older kernel but could prove more trouble than what it is worth. I am interest to see what if encounter any stability issues when booting an edge kernel. Interesting, that is the exact same RAM chips used on the pcDuino2 but the additional text enscribed is different. Just to be safe can you run memtester to see if it picks up an errors. For example: sudo memtester 64MB 2. Even without re-compiling the entire system, what we can do is replace the targeted board dts. This should be doable given you already have a serial link, but you will need to catch uboot early on to hault to boot process to get a uboot prompt. Then running setenv ftdfile sun4i-a10-topwise-a721.dts to see if the onboard display works. *update* - upon checking kernel sources the previously mentioned sun4i-drm patches are no longer necessary as the changes appear to have been included in the latest sub revision of kernel 6.12.30 All the best Ryzer Edited June 15 by Ryzer 0 Quote
thewiseguyshivam Posted June 16 Author Posted June 16 So yes, HDMI does work on the archived image. Interestingly, USB does not work. I tried to connect a keyboard and a mouse but that did not work. So, on the HDMI terminal I successfully reach the login screen but can't go past that. But through ssh/serial I can work on the system. I tried memtester and it does show some issues with the memory, but overall, this archived image has worked without issues. I was able to use octoprint_deploy to install Octoprint, but again since USB does not work couldn't connect the printer itself. To replace the dts file easily I need input devices to work, I will try and see if I can do that over serial. And the next thing to try is to compile using an edge kernel and report back. Thanks, Shivam 0 Quote
Ryzer Posted June 16 Posted June 16 Most likely USB OTG unless there are any USB related errors in the kernel log. In the case of OTG, there should be auto detection via the ID pin which sets the device role but I have never known this to work. Fortunately it is possible to set the mode manually to host in the device tree. I tend to use the following device tree overlay: /dts-v1/; /plugin/; /{ compatible = "allwinner,sun4i-a10", "allwinner,sun7i-a20"; fragment@0{ target = <&usb_otg>; __overlay__{ dr_mode = "host"; }; }; }; just connect via serial or ssh, once logged in use nano and paste in the text above. Save it as something like sun4i-usb-host.dts. Then run armbian-add-overlay sun4i-usb-host.dts. This automatically compiles the overlay and places it /boot/dtb/overlay-user/ The RAM may just need fine tuning slightly. As far as I know it is not possible to adjust the RAM frequency in uboot once compiled, only check clock rate via sudo cat /sys/kernel/debug/clk/pll-ddr/clk_rate. I might have to try that on my pcDuino2, I didn't think the A10 would be powerful enough to run Octoprint. All the best Ryzer 0 Quote
thewiseguyshivam Posted June 18 Author Posted June 18 Hi! So, I tried this overlay, and the device still did not detect USB. Although when I tried switching the dts file to the topwise a721, the HDMI stopped working but USB devices were correctly detected. On top of that, no the display still does not work even with the topwise device tree. I checked the RAM clock speed with the command you mentioned and it said 432000000, which is much higher than what I found from the boot file from original Android (384000000). Is there a way I can rebuild just u-boot and install it in this working image? 0 Quote
Ryzer Posted Friday at 08:10 PM Posted Friday at 08:10 PM Hi, Then the only other difference would be that your device has a pin tied to usb0-vbus. The topwise dts does not have the display nodes included in the cubieboard. Now as you are currently kernel 6.1, it is possible to enable the display via overlays or compile a version of the topwise dts that includes the display nodes. So the internal display does not work under 6.1? Are there any kind of errors or does it not appear to intialise at all? Cubieboard nodes (*Note - Nodes other than hdmi and usb related have been removed): /dts-v1/; #include "sun4i-a10.dtsi" #include "sunxi-common-regulators.dtsi" #include <dt-bindings/gpio/gpio.h> / { model = "Cubietech Cubieboard"; compatible = "cubietech,a10-cubieboard", "allwinner,sun4i-a10"; hdmi-connector { compatible = "hdmi-connector"; type = "a"; port { hdmi_con_in: endpoint { remote-endpoint = <&hdmi_out_con>; }; }; }; }; &de { status = "okay"; }; &hdmi { status = "okay"; }; &hdmi_out { hdmi_out_con: endpoint { remote-endpoint = <&hdmi_con_in>; }; }; ®_usb1_vbus { status = "okay"; }; ®_usb2_vbus { status = "okay"; }; &usb_otg { dr_mode = "otg"; status = "okay"; }; &usbphy { usb0_id_det-gpios = <&pio 7 4 (GPIO_ACTIVE_HIGH | GPIO_PULL_UP)>; /* PH4 */ usb1_vbus-supply = <®_usb1_vbus>; usb2_vbus-supply = <®_usb2_vbus>; status = "okay"; }; Topwise a721: /dts-v1/; #include "sun4i-a10.dtsi" #include "sunxi-common-regulators.dtsi" #include <dt-bindings/gpio/gpio.h> #include <dt-bindings/input/input.h> #include <dt-bindings/interrupt-controller/irq.h> #include <dt-bindings/pwm/pwm.h> / { model = "Topwise A721"; compatible = "topwise,a721", "allwinner,sun4i-a10"; panel { compatible = "starry,kr070pe2t"; backlight = <&backlight>; power-supply = <®_lcd_power>; port { panel_input: endpoint { remote-endpoint = <&tcon0_out_panel>; }; }; }; reg_lcd_power: reg-lcd-power { compatible = "regulator-fixed"; regulator-name = "reg-lcd-power"; gpio = <&pio 7 8 GPIO_ACTIVE_HIGH>; /* PH8 */ enable-active-high; }; }; &de { status = "okay"; }; ®_usb0_vbus { status = "okay"; }; ®_usb1_vbus { status = "okay"; }; ®_usb2_vbus { status = "okay"; }; &tcon0_out { tcon0_out_panel: endpoint@0 { reg = <0>; remote-endpoint = <&panel_input>; }; }; &usb_otg { dr_mode = "otg"; status = "okay"; }; &usb_power_supply { status = "okay"; }; &usbphy { usb0_id_det-gpios = <&pio 7 4 GPIO_ACTIVE_HIGH>; /* PH4 */ usb0_vbus_det-gpios = <&pio 7 5 GPIO_ACTIVE_HIGH>; /* PH5 */ usb0_vbus-supply = <®_usb0_vbus>; usb1_vbus-supply = <®_usb1_vbus>; usb2_vbus-supply = <®_usb2_vbus>; status = "okay"; }; It is possible to build just uboot using the BUILD_ONLY=uboot option. Again here you could face potential issues as newer uboot might not work well with an old kernel. All the best Ryzer 0 Quote
