armbianmonitor logs: https://paste.armbian.com/rolisaboru
I’m running Armbian 25.2 on a Banana Pi BPI-M4-Zero (Allwinner sun50i-h618). EMAC1 (ethernet@5030000) with its internal PHY never comes up:
sunxi-gmac 5030000.ethernet end0: renamed from eth0
… No PHY found! … phy init again… No PHY found! … phy init failed
So far I have tried:
1. Directly patching full.dts
Enabled /soc/ethernet@5030000 (status = “okay”)
Added phy-mode = "rmii", pinctrl-0 = <&rmii_pins>, phy-handle, phy-supply etc.
Defined a simple ethernet-phy@0 under MDIO.
Recompiled to sun50i-h618-bananapi-m4-zero.dtb and rebooted.
2. User overlay (.dts → .dtbo)
Created fragments to:
Turn on /soc/ethernet@5030000/mdio
Inject an ethernet-phy@0 node
Enable EMAC1, assign RMII pins, MDIO and PHY handle
Compiled with dtc -@ and loaded via user_overlays=bpi-m4z-eth in armbianEnv.txt.
3. Following Armbian build PR #6617
Tried the patch for H618’s internal AC300 PHY from https://github.com/armbian/build/pull/6617
No change: PHY still not detected, no power-up.
4. Troubleshooting notes
Overlay apply errors: FDT_ERR_NOTFOUND
dtc compile errors on duplicate or missing phandle references
Verified pinctrl entries (rmii-pins) and alias names match base DTS
I’ve collected a full hardware/software report via armbianmonitor—see the logs here: https://paste.armbian.com/rolisaboru
What I’m looking for
A known-good snippet of device-tree (base DTS or overlay) that brings up the internal EMAC1 PHY on sun50i-h618
Advice on any missing power-or-clock settings or MFD nodes required for the AC300 PHY
Confirmation whether additional kernel/config patches are needed
Thanks in advance for any pointers!
3 часа назад, GeEg сказал:
> sunxi-gmac 5030000.ethernet end0: No PHY found!
The first question. What brand of chip is used in your case?
The second question. Is this an external device?
[  341.101053] usb 2-1: new high-speed USB device number 2 using ehci-platform
[  341.257994] usb 2-1: New USB device found, idVendor=0b95, idProduct=772b, bcdDevice= 0.01
[  341.258024] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[  341.258033] usb 2-1: Product: AX88772B
[  341.258039] usb 2-1: Manufacturer: ASIX Elec. Corp.
[  341.258045] usb 2-1: SerialNumber: E5A1DD
[  341.902647] asix 2-1:1.0 (unnamed net_device) (uninitialized): PHY [usb-002:002:10] driver [Asix Electronics AX88772C] (irq=POLL)
[  341.905987] Asix Electronics AX88772C usb-002:002:10: attached PHY driver (mii_bus:phy_addr=usb-002:002:10, irq=POLL)
In order for the ethernet-phy to work, it is necessary to turn on the PWM on the internal pin of the processor.
As example see: arch/arm64/boot/dts/allwinner/sun50i-h618-orangepi-zero2w.dts
and arch/arm64/boot/dts/allwinner/sun50i-h618-orangepi-zero2w.dts#L521-L539
Quote
It is Allwinner H618, Quad-core ARM Cortex™-A53 processor.
Quote
[ 341.101053] usb 2-1: new high-speed USB device number 2 using ehci-platform [ 341.257994] usb 2-1: New USB device found, idVendor=0b95, idProduct=772b, bcdDevice= 0.01 [ 341.258024] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3 [ 341.258033] usb 2-1: Product: AX88772B [ 341.258039] usb 2-1: Manufacturer: ASIX Elec. Corp. [ 341.258045] usb 2-1: SerialNumber: E5A1DD [ 341.902647] asix 2-1:1.0 (unnamed net_device) (uninitialized): PHY [usb-002:002:10] driver [Asix Electronics AX88772C] (irq=POLL) [ 341.905987] Asix Electronics AX88772C usb-002:002:10: attached PHY driver (mii_bus:phy_addr=usb-002:002:10, irq=POLL)
Yes it is external USB network card,  which I used just to be able to send logs made via armbianmonitor to the internet.
The state You see in the logs is just latest stage of many different attempts: with custom overlays and/or fixes on the sun50i-h618-bananapi-m4-zero.dtb (decompile, fix, compile, boot). In addition have tried some patches using H616 files.
I also found problem is due to, PHY isn't properly powered on, based on topic: https://github.com/armbian/build/pull/6617 but after plenty of tries didnt manage to make it work ;(
13 часов назад, GeEg сказал:
I meant which Eth chip is used in your case
Bananapi-m4-berry:
h618 ==> Eth chip rtl8211f ==> connecting socket
Bananapi-m4-zero:
h618 ==> Eth chip ????  ==> connecting socket
As far as I understand, this is some kind of expansion card for the 26 pin connector.
Can you post a diagram of this expansion board here.
The brand of the Ethernet chip matters.
Quote
Bananapi-m4-berry:
Bananapi-m4-zero:
Ach, OK. On Banana Pi M4 Zero (H618), the Ethernet PHY is integrated into the SoC, specifically within the AC200 block. There is no external Ethernet PHY chip like RTL8211F — the EMAC1 interface uses RMII and talks directly to the internal PHY.
The issue I’m facing is likely due to incompatibility with kernel 6.x.x. I haven’t been able to get any overlay to work properly. However, with a kernel from the 5.4.x series, Ethernet works out-of-the-box on the same hardware.
Any insights on proper overlay structure or required patches for AC200 support in newer kernels would be highly appreciated. Thanks for your help!
