Guest Posted October 7, 2017 Posted October 7, 2017 Hi all, I am writing because i took the AMLogic Project to get deeper in Linux. First of all @balbes150 and to every Armbian Developer : GREAT F()/"§! WORK! I used the " ARMBIAN 5.32 user-built Ubuntu 16.04.3 LTS 4.14.0-rc2-next-20170929-amlogics905x" So let's get to the point. $dmesg | grep brcm .. [ 10.139138] brcmfmac: F1 signature read @0x18000000=0x16044330 [ 10.140995] brcmfmac: brcmf_fw_map_chip_to_name: using brcm/brcmfmac4330-sdio.bin for chip 0x004330(17200) rev 0x000004 .. SO actually this is telling me there is a special wifi driver mapped. I was not able to find the mapping. Even not in the decompiled dtb . There it is mapping to 4329 (?!) [Extract from DTB "meson-gxbb-vegas-95-telos.dtb" (decompiled to dts)] wifi@1 { reg = <0x1>; compatible = "brcm,bcm4329-fmac"; }; I need to map it to "fw_bcm40183b2.bin" which is in the /lib/firmware/brcm folder. I took the "nvram.txt" from the original Android Remix OS 2.0 and renamed it to "fw_bcm40183b2.txt" The only thing i gotta do is to remap the driver and I have no clue where to find it. Sorry for beeing stupid. With a trick I just overwrote the drivers which are mapped with renamed files -> "fw_bcm40183b2.bin" is now "brcmfmac4330-sdio.bin" -> "fw_bcm40183b2.txt" is now "brcmfmac4330-sdio.txt" That worked 100% for testing! (After /etc/wpa_supplicant/wpa-supplicant.conf AND etc/network/interfaces were adjusted) wlan0 Link encap:Ethernet HWaddr 44:2c:05:00:df:3a inet addr:192.168.178.106 Bcast:192.168.178.255 Mask:255.255.255.0 inet6 addr: fe80::462c:5ff:fe00:df3a/64 Scope:Link UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1 RX packets:25617 errors:0 dropped:0 overruns:0 frame:0 TX packets:27158 errors:0 dropped:0 overruns:0 carrier:0 collisions:0 txqueuelen:1000 RX bytes:9415173 (9.4 MB) TX bytes:19477541 (19.4 MB) But now I wanna map the right driver. Thanks for any help PS: And after that there is a bunch more of S905 TV boxes, which will run properly with <3 Armbian <3
Guest Posted October 21, 2017 Posted October 21, 2017 Hello Bruce, sorry I do not have a solution but only some questions: As I use the same box (Orbsmart RX-01) I tried to install Armian on it ... without success, the box allways starts Remix. No errors, as if there is no sd-card inserted. First question: where did you find "ARMBIAN 5.32 user-built Ubuntu 16.04.3 LTS 4.14.0-rc2-next-20170929-amlogics905x" ? Second question: Did you format the sdcard before installing the iso with etcher? Which parameters did you use? Would be nice if you could help me, Greeting from Germany Ralph
Guest Posted October 22, 2017 Posted October 22, 2017 Found the answer: Boot-Mode must be changed - Download update-tool from here: http://update-backup.apk.black/ and then install aml_autoscript.zip (which is on the sd-card) I had to start the console (press pin trough the av opening and boot) ... and suddenly it works. Hope this helps others Regards Ralph
Guest Posted October 22, 2017 Posted October 22, 2017 9 hours ago, ralphmkk61 said: Found the answer: Boot-Mode must be changed - Download update-tool from here: http://update-backup.apk.black/ and then install aml_autoscript.zip (which is on the sd-card) I had to start the console (press pin trough the av opening and boot) ... and suddenly it works. Hope this helps others Regards Ralph Ah thanks - that's exactly what I wrote you on you youtube ? ! Or are you another Ralph ? -
Guest Posted October 28, 2017 Posted October 28, 2017 Hello Bruce, yes, that's me at Youtube Hope it's ok that I posted the solution here I found with your assistance. PS I am still fighting the wlan-problem.
