I am trying to install box86 and possibly box64 on my Orange pi zero 2w. I tried using armbian-gaming as well as following the instructions found here, and attempting to build box86 with both resulted in a gcc error
unrecognized command line option '-marm'
Upon attempting to build box64 with the instructions, I get a make error 2, and the topmost error is a ccl error
unknown value 'loongarch64' for '-march'
This seems to be cross-compilation errors, but IDK what steps to take to fix it.
Thanks in advance!
QuowLord
Apparently I'm an idiot and did not fully read the instructions linked. I had not previously copied the files as per the instructions. Doing so allowed box64 to compile most of the way, and I then ran into the issue described here. I tried deleting the file as described and that did not help. I am unsure if my rpi zero 2w will work to compile it, but I shall post an update once I test that, then try copying the file over.
Copying the file over from my rpi zero 2w didn't work. I may try compiling on a different OS on the opi tomorrow to see if that will compile fully.
