robertoj Posted August 9, 2025 Posted August 9, 2025 (edited) Hello, I am trying to have a graphical login screen for my orange pi zero 3 with ili9488 LCD screen. A problem I have is that X11 can't start with the LCD driver... so I need to stay 100% wayland. I was able to compile and run labwc with these instructions: https://forum.armbian.com/topic/53797-labwc-wayland-crashes-on-exit/#findComment-223267 Labwc runs well on a HDMI screen and in the small ili9488 screen Next, I found this graphical login, which is made to install on top of lightdm: https://github.com/raspberrypi-ui/pi-greeter/tree/master Compilation rerequisites: sudo apt install gobject-introspection libgtk-3-dev liblightdm-gobject-dev libgtk-layer-shell-dev Lightdm requirement: sudo apt install accountsservice Compile it: $ autogen.sh $ ./configure $ make $ sudo make install There are some hints to post-install in the debian package postint: $ update-alternatives --install /usr/share/xgreeters/lightdm-greeter.desktop lightdm-greeter /usr/share/xgreeters/pi-greeter.desktop 70 In lightdm.conf: greeter-session=pi-greeter I check the lightdm configuration: $ update-alternatives --display lightdm-greeter lightdm-greeter - auto mode link best version is /usr/local/share/xgreeters/pi-greeter.desktop link currently points to /usr/local/share/xgreeters/pi-greeter.desktop link lightdm-greeter is /usr/share/xgreeters/lightdm-greeter.desktop /usr/local/share/xgreeters/pi-greeter.desktop - priority 70 /usr/share/xgreeters/lightdm-gtk-greeter.desktop - priority 60 Then I erase the link to lightdm-gtk: sudo rm /usr/share/xgreeters/lightdm-gtk-greeter.desktop When I try to start lightdm with sudo systemctl start lightdm, fails with: Job for lightdm.service failed because the control process exited with error code. In journalctl logs, $ journalctl -xeu lightdm.service I see Aug 09 09:18:19 orangepizero3 systemd[1]: lightdm.service: Main process exited, code=exited, status=1/FAILURE ░░ Subject: Unit process exited ░░ Defined-By: systemd ░░ Support: https://www.debian.org/support ░░ ░░ An ExecStart= process belonging to unit lightdm.service has exited. ░░ ░░ The process' exit code is 'exited' and its exit status is 1. Aug 09 09:18:19 orangepizero3 systemd[1]: lightdm.service: Failed with result 'exit-code'. ░░ Subject: Unit failed ░░ Defined-By: systemd ░░ Support: https://www.debian.org/support ░░ ░░ The unit lightdm.service has entered the 'failed' state with result 'exit-code'. Aug 09 09:18:19 orangepizero3 systemd[1]: Failed to start lightdm.service - Light Display Manager. ░░ Subject: A start job for unit lightdm.service has failed ░░ Defined-By: systemd ░░ Support: https://www.debian.org/support ░░ ░░ A start job for unit lightdm.service has finished with a failure. ░░ ░░ The job identifier is 6519 and the job result is failed. Does anybody have experience in installing pi-greet, or another greeter that would work in wayland? I need it to be efficient THANK YOU! Edited August 9, 2025 by robertoj 0 Quote
robertoj Posted August 10, 2025 Author Posted August 10, 2025 (edited) I get this warning because I removed lightdm-gtk-greeter.desktop... what should I do to not expect the file? roberto@orangepizero3:~$ update-alternatives --display lightdm-greeter update-alternatives: warning: alternative /usr/share/xgreeters/lightdm-gtk-greeter.desktop (part of link group lightdm-greeter) doesn't exist; removing from list of alternatives lightdm-greeter - auto mode link best version is /usr/local/share/xgreeters/pi-greeter.desktop link currently points to /usr/local/share/xgreeters/pi-greeter.desktop link lightdm-greeter is /usr/share/xgreeters/lightdm-greeter.desktop /usr/local/share/xgreeters/pi-greeter.desktop - priority 70 After some research of greeters, I see that the default greeter is compatible with wayland https://github.com/Xubuntu/lightdm-gtk-greeter I have been working as if lightdm requires X11 (which I need to avoid), and so I wanted to used pi-greeter Does anybody have lightdm+gtkgreeter in a pure wayland setup? No X11 Edited August 10, 2025 by robertoj 0 Quote
