Ducdanh Nguyen Posted August 10 Posted August 10 (sorry for bad english) i'm looking to boot in an armbian bookworm by sicxnull on my mxq pro 4k 5g, i checked the aida64, it showed the allwinner h313, i tried the toothpick method to the recovery menu (which have a boot option?) i'm novice to android 😕 by the way here are the images of the tv box pcb: 0 Quote
ccs1664 Posted August 10 Posted August 10 (edited) Hi I think that a boot on this TV box it should be not so hard, I never tested an Allwiner. Please, start reading some advices from this post from 2023: once that h313, probably follows at the same procedure of the H61X ... I hope to help you ccs Edited August 10 by ccs1664 1 Quote
Ducdanh Nguyen Posted August 11 Author Posted August 11 @ccs1664 thanks for the information, but i already have a image that works on my mxq pro 4k 5g allwinner h313, but im struggling how to boot in the sd card, and i cant enter recovery mode too (it showed an update screen but nithing updated) im glad you replied to my situation. 0 Quote
Nick A Posted August 11 Posted August 11 @Ducdanh Nguyen @ccs1664 is correct.. there’s a lot of information on that thread and the x96q threads to get your box running. I have to post the same advice over and over again. The last thread you posted in. I gave instructions to get your dram settings and dts. Have you extracted them? it could be possible that you have secure boot. 1 Quote
Ducdanh Nguyen Posted August 12 Author Posted August 12 (edited) 6 hours ago, Nick A said: @Ducdanh Nguyen @ccs1664 is correct.. there’s a lot of information on that thread and the x96q threads to get your box running. I have to post the same advice over and over again. The last thread you posted in. I gave instructions to get your dram settings and dts. Have you extracted them? it could be possible that you have secure boot. Thanks for noticing me!!! I will check the last thread ive been in and the dram settings and dts, i havent checked also i cant edit/change dram and dts, i use windows but i will use a virtual machine to get the armbian doing its job. and from the secure boot, it could be because when i do the “toothpick method”, it showed the updating screen but nothing updated thanks you for replying to me edit: is the text too blurry? I could take more 😃 Edited August 12 by Ducdanh Nguyen 0 Quote
Ducdanh Nguyen Posted August 12 Author Posted August 12 @Nick A sorrry but i didn't found where you replied to me could you repost it to mine trhead?😁 0 Quote
Ducdanh Nguyen Posted August 12 Author Posted August 12 (edited) . Edited August 12 by Ducdanh Nguyen 0 Quote
Ducdanh Nguyen Posted August 14 Author Posted August 14 (edited) @Nick Aok, im working on it Edited August 14 by Ducdanh Nguyen 0 Quote
Ducdanh Nguyen Posted August 14 Author Posted August 14 @Nick AMay i ask you a question? If yes , why wont my boxtry and boot on that amrbian image? I plugged in and it should detetct and boot to the sd card right? 0 Quote
Nick A Posted August 14 Posted August 14 @Ducdanh Nguyen hard to tell. I don’t see any markings for uart. It’s not going to be easy to debug your board. 0 Quote
Ducdanh Nguyen Posted August 15 Author Posted August 15 @Nick A To be honest i don't really think about debug my box, but i sure will do more research after getting all settings done. 0 Quote
Ducdanh Nguyen Posted August 15 Author Posted August 15 @Nick A could you help me get the dram settings??? My box don't have root access, on aida64, it says my box has root, but the tv info (https://play.google.com/store/apps/details?id=com.saksham.developer.tvinfo&hl=en&pli=1) says it is not rooted? 0 Quote
Ducdanh Nguyen Posted August 16 Author Posted August 16 hey @Nick A i have problem when connecting to the box throught adb connect, i have installed every dependencies before (i won't show ouput bc too long but it succesed) here is what i tried: Quote passisdanhdanhdanh123@vmlmdanh:~/Android_boot_image_editor$ sudo adb connect 192.168.1.17:5555 * daemon not running; starting now at tcp:5037 * daemon started successfully failed to connect to '192.168.1.17:5555': Connection refused passisdanhdanhdanh123@vmlmdanh:~/Android_boot_image_editor$ sudo adb connect 192.168.1.17:5555 failed to connect to '192.168.1.17:5555': Connection refused passisdanhdanhdanh123@vmlmdanh:~/Android_boot_image_editor$ sudo adb connect 192.168.1.17:8888 failed to connect to '192.168.1.17:8888': Connection refused passisdanhdanhdanh123@vmlmdanh:~/Android_boot_image_editor$ i am using a virtual machine to do this work my uncle tried reset the prop on the tv box(mxq pro 4k 5g) (he's an android expert): Quote setprop service.adb.tcp.port 5555 stop adbd stop : must be root 0 Quote
Ducdanh Nguyen Posted August 17 Author Posted August 17 (edited) hello @Nick A i did install everything including adb on my VM, but it has occured an error Here is the whole ouput: Quote passisdanhdanhdanh123@vmlmdanh:~$ cd Android_boot_image_editor passisdanhdanhdanh123@vmlmdanh:~/Android_boot_image_editor$ sudo apt install git device-tree-compiler lz4 xz-utils zlib1g-dev openjdk-17-jdk gcc g++ python3 python-is-python3 p7zip-full android-sdk-libsparse-utils erofs-utils [sudo] password for passisdanhdanhdanh123: Reading package lists... Done Building dependency tree... Done Reading state information... Done git is already the newest version (1:2.43.0-1ubuntu7.3). device-tree-compiler is already the newest version (1.7.0-2build1). lz4 is already the newest version (1.9.4-1build1.1). xz-utils is already the newest version (5.6.1+really5.4.5-1ubuntu0.2). zlib1g-dev is already the newest version (1:1.3.dfsg-3.1ubuntu2.1). openjdk-17-jdk is already the newest version (17.0.16+8~us1-0ubuntu1~24.04.1). gcc is already the newest version (4:13.2.0-7ubuntu1). g++ is already the newest version (4:13.2.0-7ubuntu1). python3 is already the newest version (3.12.3-0ubuntu2). python-is-python3 is already the newest version (3.11.4-1). p7zip-full is already the newest version (16.02+transitional.1). android-sdk-libsparse-utils is already the newest version (1:34.0.4-1build3). erofs-utils is already the newest version (1.7.1-1build2). 0 upgraded, 0 newly installed, 0 to remove and 430 not upgraded. passisdanhdanhdanh123@vmlmdanh:~/Android_boot_image_editor$ sudo adb connect 192.168.1.17:8888 * daemon not running; starting now at tcp:5037 * daemon started successfully ^C passisdanhdanhdanh123@vmlmdanh:~/Android_boot_image_editor$ sudo adb connect 192.168.1.15:8888 failed to connect to '192.168.1.15:8888': Connection refused passisdanhdanhdanh123@vmlmdanh:~/Android_boot_image_editor$ sudo adb connect 192.168.1.15:5555 failed to connect to '192.168.1.15:5555': Connection refused passisdanhdanhdanh123@vmlmdanh:~/Android_boot_image_editor$ any advice? thank you. Edited August 17 by Ducdanh Nguyen trying more commands 0 Quote
Ducdanh Nguyen Posted Thursday at 02:18 AM Author Posted Thursday at 02:18 AM (edited) Hello @Nick A, i'm on my linux virtual machine doing the following command, but i got some problem on it (i have installed every package needed): Quote passisdanhdanhdanh123@vmlmdanh:~$ cd Android_boot_image_editor passisdanhdanhdanh123@vmlmdanh:~/Android_boot_image_editor$ sudo adb connect 192.168.1.13:5555 [sudo] password for passisdanhdanhdanh123: * daemon not running; starting now at tcp:5037 * daemon started successfully failed to connect to '192.168.1.13:5555': Connection refused passisdanhdanhdanh123@vmlmdanh:~/Android_boot_image_editor$ sudo adb connect 192.168.1.13:8000 failed to connect to '192.168.1.13:8000': Connection refused passisdanhdanhdanh123@vmlmdanh:~/Android_boot_image_editor$ sudo adb connect 192.168.1.13:8888 failed to connect to '192.168.1.13:8888': Connection refused passisdanhdanhdanh123@vmlmdanh:~/Android_boot_image_editor$ yes, i got the ip from the ifconfig command on termux 32bit if you are wondering glad you helped me Edited Thursday at 02:21 AM by Ducdanh Nguyen the host arch is x86 64 bit if you are wondering 0 Quote
Ducdanh Nguyen Posted Thursday at 02:58 AM Author Posted Thursday at 02:58 AM (edited) here is the ouput : @Nick A Quote passisdanhdanhdanh123@vmlmdanh:~$ cd Android_boot_image_editor passisdanhdanhdanh123@vmlmdanh:~/Android_boot_image_editor$ sudo adb connect 192.168.1.13:5037 [sudo] password for passisdanhdanhdanh123: * daemon not running; starting now at tcp:5037 * daemon started successfully failed to connect to '192.168.1.13:5037': Connection refused passisdanhdanhdanh123@vmlmdanh:~/Android_boot_image_editor$ Edited Thursday at 05:00 AM by Ducdanh Nguyen 0 Quote
Ducdanh Nguyen Posted 16 hours ago Author Posted 16 hours ago (edited) hello @Nick A, have you read the last post i posted? When i was messing around on my box, i saw that the box only have 1200mhz freqency (note that this is allwinner h313) while h313 max freq is 1350mhz, and mine is 1200mhz, is the h313 nerfed by the firmware? Or anything else? edit: full cpu formation here Edited 16 hours ago by Ducdanh Nguyen 0 Quote
Nick A Posted 3 hours ago Posted 3 hours ago (edited) @Ducdanh Nguyen I don’t write the mainline linux kernel or patches. You should ask the sunxi developers or Piotr Oniszczuk aka warpme. Allwinner does not support open source mainline Linux. Most of the work is reversed engineered by a very few smart people that give their free time to Linux community. Android uses a very old modified Linux kernel so it takes a lot of work to update drivers. Sometimes these drivers have no source code or documentation. tv boxes are a whole different beast. Components are cheap. If you buy the same model tv box they might have different wifi, memory, emmc chips and sometimes the cpu is not allwinner at all. if you want to have a perfect running tv box you’ll need to learn how to tweak the dts and edit the Linux kernel source code. https://oftc.catirclogs.org/linux-sunxi/2025-08-24 https://github.com/warpme Edited 2 hours ago by Nick A 1 Quote
Ducdanh Nguyen Posted 32 minutes ago Author Posted 32 minutes ago @Nick A thank you for your advice 0 Quote
