gene1934 Posted August 15, 2025 Posted August 15, 2025 close investigation it seems to use grub, not bootp, card written does not show any activity of green led even after 10 minutes from powerup. Do you have some of the magic twanger needed to boot a pi? Thank you, gene1934 0 Quote
gene1934 Posted August 17, 2025 Author Posted August 17, 2025 I dropped back to Armbian_24.5.1_Bananapim5_bookworm_current_6.6.31_xfce_desktop.img and while it working, the boot find order of the drives is still random, no two boots is a row report the same lsblk order of disk vs sd* assigbnents. Only by using LABELS have I succeeded in getting them (7 drives) mounted in /etx./fstab. After that dated install an apt upgrade spent about an hour updating 270 some pkgs Just tried to get some of the other partitions mounted and usable, using LABEL= to ID them, got 2 of the 3 on a 1T toshiba drive, but found swapoff -a works, but swapon -a does not, won't even restore whats found at boot. This is from fdisk, also a reboot changed /dev/sdd into /dev/sdb Command (m for help): p Disk /dev/sdb: 931.51 GiB, 1000204886016 bytes, 1953525168 sectors Disk model: MQ01ABD100V Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 4096 bytes I/O size (minimum/optimal): 4096 bytes / 4096 bytes Disklabel type: dos Disk identifier: 0x481e1363 Device Boot Start End Sectors Size Id Type /dev/sdb1 2048 102402047 102400000 48.8G 83 Linux /dev/sdb2 102402048 1748725759 1646323712 785G 83 Linux /dev/sdb3 1748725760 1953523711 204797952 97.7G 82 Linux swap / Solaris but its not swapon-able, note the dos disklable, it s/b gpt, it was done with gparted. ?????? Is there a conversion utility to make gpt or should I wait on working keyboard/mouse kit and let gparted blow it away? So I did, changed 3 parts to 2 and refornatted both and found that swapon should use label's but fails and the reboot to do that moved the toshiba drive from /dev/sdb to /dev/sdd. Howinhell can I stabilize tiis????? 0 Quote
