mm2189 Posted August 16, 2025 Posted August 16, 2025 (edited) Hello! Is there a possibility to change the default LED0 behaviour of the RTL8201F PHY? Here is the Datasheet: https://file.elecfans.com/web1/M00/99/0F/o4YBAF0VytaAI7ezABH66fmIRIg854.pdf?filename=RTL8201F-VB-CG.pdf And this is the relevant register: It states, that "11" is the default - but I think it is changed to "00" during driver initialization - is that possible? I would like to change it to "01" - is this somehow possible without recompiling the driver? Thank you! Best regards, Manuel Edited August 16, 2025 by mm2189 0 Quote
brentr Posted August 16, 2025 Posted August 16, 2025 I'm sure it is possible. I'd be happy to test your patch and submit it so it becomes part of the standard Armbian distro image. - brent 0 Quote
mm2189 Posted August 16, 2025 Author Posted August 16, 2025 Hello brent, have you got a hint, on how it could be done? Best regards Manuel 0 Quote
