mm2189 Posted Saturday at 06:51 PM Posted Saturday at 06:51 PM (edited) Hello! Is there a possibility to change the default LED0 behaviour of the RTL8201F PHY? Here is the Datasheet: https://file.elecfans.com/web1/M00/99/0F/o4YBAF0VytaAI7ezABH66fmIRIg854.pdf?filename=RTL8201F-VB-CG.pdf And this is the relevant register: It states, that "11" is the default - but I think it is changed to "00" during driver initialization - is that possible? I would like to change it to "01" - is this somehow possible without recompiling the driver? Thank you! Best regards, Manuel Edited Saturday at 06:51 PM by mm2189 0 Quote
brentr Posted Saturday at 07:10 PM Posted Saturday at 07:10 PM I'm sure it is possible. I'd be happy to test your patch and submit it so it becomes part of the standard Armbian distro image. - brent 0 Quote
mm2189 Posted Saturday at 07:17 PM Author Posted Saturday at 07:17 PM Hello brent, have you got a hint, on how it could be done? Best regards Manuel 0 Quote
