Upon reading the content of RPi5 about 6.12 from this and this , I was under the impression that it's okay to upgrade the Armbian 24.11 based NextCloudPi to a 6.12 kernel.
Well, I was wrong and the RPi5 current stuck in the RPi Logo on a black page. Net address seems to be 0.0.0.0.
I could really use some advice on how to restore this, perhaps some `chroot` method from another Linux machine to get the right kernel package and intramfs.
Here are the steps that got me to the current situation. Maybe a hint on how to restore?
1. Mark `raspi-firmware`, like what was recommended in 1st post.
sudo apt-mark hold raspi-firmware
[sudo] password for pi:
raspi-firmware set on hold.
2.  Remove the old bsp for RPi5b specific package?
pi@nextcloudpi:~$ sudo dpkg --remove --force-all libraspberrypi0 armbian-bsp-cli-rpi5b-current
dpkg: warning: ignoring request to remove libraspberrypi0 which isn't installed
(Reading database ... 50983 files and directories currently installed.)
Removing armbian-bsp-cli-rpi5b-current (24.11.1) ...
Armbian 'armbian-bsp-cli-rpi5b-current' for '1-PC980a-V32ae-H032a-B6e44-R7697': 'postrm' starting.
Armbian 'armbian-bsp-cli-rpi5b-current' for '1-PC980a-V32ae-H032a-B6e44-R7697': 'postrm' finishing.
Processing triggers for initramfs-tools (0.142+deb12u3) ...
update-initramfs: Generating /boot/initrd.img-6.6.63-current-bcm2712
W: Possible missing firmware /lib/firmware/rtl_nic/rtl8156b-2.fw for built-in driver r8152
W: Possible missing firmware /lib/firmware/rtl_nic/rtl8156a-2.fw for built-in driver r8152
W: Possible missing firmware /lib/firmware/rtl_nic/rtl8153c-1.fw for built-in driver r8152
W: Possible missing firmware /lib/firmware/rtl_nic/rtl8153b-2.fw for built-in driver r8152
W: Possible missing firmware /lib/firmware/rtl_nic/rtl8153a-4.fw for built-in driver r8152
W: Possible missing firmware /lib/firmware/rtl_nic/rtl8153a-3.fw for built-in driver r8152
W: Possible missing firmware /lib/firmware/rtl_nic/rtl8153a-2.fw for built-in driver r8152
3. Install the newer RPI4b bsp package, which guessing from the 2nd post, including everything from 3b to 5b.
pi@nextcloudpi:~$ sudo apt install armbian-bsp-cli-rpi4b-current
Reading package lists... Done
Building dependency tree... Done
The following NEW packages will be installed:
0 upgraded, 1 newly installed, 0 to remove and 0 not upgraded.
Need to get 1,515 kB of archives.
After this operation, 5,411 kB of additional disk space will be used.
Get:1 https://mirrors.ustc.edu.cn/armbian bookworm/main arm64 armbian-bsp-cli-rpi4b-current arm64 25.8.1 [1,515 kB]
Fetched 1,515 kB in 2s (1,008 kB/s)
Selecting previously unselected package armbian-bsp-cli-rpi4b-current.
(Reading database ... 50867 files and directories currently installed.)
Preparing to unpack .../armbian-bsp-cli-rpi4b-current_25.8.1_arm64.deb ...
Armbian 'armbian-bsp-cli-rpi4b-current' for '1-PCee86-Ved8e-H468e-B1e5d-Rf36a': 'preinst' starting.
Armbian 'armbian-bsp-cli-rpi4b-current' for '1-PCee86-Ved8e-H468e-B1e5d-Rf36a': 'preinst' finishing.
Unpacking armbian-bsp-cli-rpi4b-current (25.8.1) ...
Setting up armbian-bsp-cli-rpi4b-current (25.8.1) ...
Armbian 'armbian-bsp-cli-rpi4b-current' for '1-PCee86-Ved8e-H468e-B1e5d-Rf36a': 'postinst' starting.
Armbian 'armbian-bsp-cli-rpi4b-current' for '1-PCee86-Ved8e-H468e-B1e5d-Rf36a': 'postinst' finishing.
4. I notice the initrd was still generated for the old kernel image, which is understandable based what is currently installed
pi@nextcloudpi:~$ uname -a
Linux nextcloudpi 6.6.63-current-bcm2712 #2 SMP PREEMPT Wed Nov 27 10:28:46 UTC 2024 aarch64 GNU/Linux
pi@nextcloudpi:~$ dpkg -l | grep linux-image
ii  linux-image-current-bcm2712    24.11.1                                     arm64        Armbian Linux current kernel image 6.6.63-current-bcm2712
5. Therefore, I went ahead to install the new 6.12 kernel package
pi@nextcloudpi:~$ sudo apt install linux-image-current-bcm2711
Need to get 34.5 MB of archives.
After this operation, 212 MB of additional disk space will be used.
Get:1 https://mirrors.ustc.edu.cn/armbian bookworm/main arm64 linux-image-current-bcm2711 arm64 25.8.1 [34.5 MB]
Fetched 34.5 MB in 5s (7,198 kB/s)
Selecting previously unselected package linux-image-current-bcm2711.
(Reading database ... 51028 files and directories currently installed.)
Preparing to unpack .../linux-image-current-bcm2711_25.8.1_arm64.deb ...
Armbian 'linux-image-current-bcm2711' for '6.12.44-current-bcm2711': 'preinst' starting.
Armbian 'linux-image-current-bcm2711' for '6.12.44-current-bcm2711': 'preinst' finishing.
Unpacking linux-image-current-bcm2711 (25.8.1) ...
Setting up linux-image-current-bcm2711 (25.8.1) ...
Armbian 'linux-image-current-bcm2711' for '6.12.44-current-bcm2711': 'postinst' starting.
update-initramfs: Generating /boot/initrd.img-6.12.44-current-bcm2711
Armbian: update last-installed kernel symlink to 'Image'...
'/boot/Image' -> 'vmlinuz-6.12.44-current-bcm2711'
Armbian: Debian compat: linux-update-symlinks install 6.12.44-current-bcm2711 boot/vmlinuz-6.12.44-current-bcm2711
I: /vmlinuz is now a symlink to boot/vmlinuz-6.12.44-current-bcm2711
I: /initrd.img is now a symlink to boot/initrd.img-6.12.44-current-bcm2711
Armbian 'linux-image-current-bcm2711' for '6.12.44-current-bcm2711': 'postinst' finishing.
6. Everything looked right to me as there are no errors like before got reported during update-initramfs:
pi@nextcloudpi:~$ sudo apt remove linux-image-current-bcm2712
The following packages will be REMOVED:
0 upgraded, 0 newly installed, 1 to remove and 0 not upgraded.
After this operation, 155 MB disk space will be freed.
Do you want to continue? [Y/n] y
(Reading database ... 54440 files and directories currently installed.)
Removing linux-image-current-bcm2712 (24.11.1) ...
Armbian 'linux-image-current-bcm2712' for '6.6.63-current-bcm2712': 'prerm' starting.
Armbian 'linux-image-current-bcm2712' for '6.6.63-current-bcm2712': 'prerm' finishing.
Armbian 'linux-image-current-bcm2712' for '6.6.63-current-bcm2712': 'postrm' starting.
update-initramfs: Deleting /boot/initrd.img-6.6.63-current-bcm2712
Armbian 'linux-image-current-bcm2712' for '6.6.63-current-bcm2712': 'postrm' finishing.
7. As a final check, I ran the upgrade script again
pi@nextcloudpi:~$ sudo armbian-upgrade
Hit:1 https://mirrors.ustc.edu.cn/debian bookworm InRelease
Hit:2 https://mirrors.ustc.edu.cn/debian bookworm-updates InRelease
Hit:3 https://mirrors.ustc.edu.cn/debian bookworm-backports InRelease
Hit:4 https://mirrors.ustc.edu.cn/debian-security bookworm-security InRelease
Hit:5 https://mirrors.ustc.edu.cn/armbian bookworm InRelease
Hit:6 https://github.armbian.com/configng stable InRelease
Hit:7 https://packages.sury.org/php bookworm InRelease
All packages are up to date.
Calculating upgrade... Done
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
8. That's it. After rebooting, I was greeted with a RPi logo on a black page, with some messaging scrolling (trying to attach a photo but failed). It never got to the point to boot the kernel image or systemd booting sequence.
Posted (edited)
I don't see anything above about your boot-loader being updated. i.e. u-boot or grub.
If you're using u-boot, was your uInitrd in your /boot directory updated? The initrd-image needs to be converted to its u-boot format of uinitrd. Instructions for how to do that are located at the bottom of your boot.cmd file (using the mkimage command from the u-boot-tools package). Though that may be a generic example that you'll have to update for your system. Also if you have an armbianEnv.txt (or an equivalent) in your /boot directory, be sure it's up to date for your current kernel's devicetree file location and name.
If that doesn't solve it read on....
I keep seeing everywhere that kernel 6.12 is broken. Not sure if that applies to all systems. I use the edge kernel (6.16) in my OrangePI-5-Plus. I've found that to work much better than Vendor (6.1).
To chroot in from an another identical system. This works on Debian Trixie. I'm not sure about other OS's.
Note: I don't know much about this, I recently found this from searching and used it myself. I found it works great to install new packages and also to run update-initramfs.
mount -t proc proc /mnt/proc
mount -t sysfs sysfs /mnt/sys
mount -t devtmpfs devtmpfs /mnt/dev
mount --bind /dev/pts /mnt/dev/pts
#  If you need for the chrooted system to be able to access the internet, the link at its: (/etc/resolv.conf) must be valid, so add this as well:
mount --bind /run/systemd /mnt/run/systemd
Then chroot in (I'm not sure if the /bin/bash) is necessary - or if you're using something else than bash, put that there instead?)
chroot /mnt /bin/bash
[Do what you need to do in there]
i.e. install a different kernel, and be sure update-initramfs has been run or run it yourself, and the u-boot (or grub) is updated.
Whenever you're installing a new kernel, it's a good idea to leave the old one there.  Once you get it working, it might then be a good idea to remove any non-functioning kernels (like that 6.12), and leave any functioning kernels in.
Then to back get out of chroot and return undo the above mounts:
# Exit chroot
exit
# This line is only necessary if you mounted it to use the internet while chrooted:
umount /mnt/run/systemd
# Unmount the rest
umount /mnt/dev/pts
umount /mnt/dev
umount /mnt/sys
umount /mnt/proc
umount /mnt
Edited by The Tall Man
