Anybody running a 100% wayland system?
Go to solution Solved by robertoj,
Has anyone here configured armbian with a Wayland desktop, and completely free of X11?
How did you do it?
I have compiled labwc and it works great with my orange pi zero 3, with bookworm or trixie... but I can't figure out how to configure a wayland greeter.
I need to do this because my LCD driver can't work with X11 (panel-mipi-dbi-spi).
  • Solution
I got my issue resolved with labwc+greetd+nwg-hello
See this link https://github.com/nwg-piotr/nwg-hello/issues/43
Please check it and post any corrections if needed
Getting rpi-greeter (no python) and wf-panel-pi (combines panel and launcher in compact form) would be ideal, but not resolved yet.
If anyone is interested in getting rpi-greeter working, this is my partial progress, and I still cannot make it start under lightdm, without any X11:
sudo apt install lightdm accountsservice polkitd
sudo apt install libgtk-layer-shell-dev librsvg2-common
sudo apt install gnome-common gobject-introspection gir1.2-gtk-3.0
These might be needed. I installed them the day after I installed greetd and ngw-hello. Note: I am working from a minimal debian trixie image
appmenu-gtk-module-common libaccountsservice-dev gir1.2-accountsservice-1.0 liblightdm-gobject-dev liblightdm-gobject-1-0 libgtk-3-dev gnome-common nasm
~$ mkdir rpi-greeter ; cd rpi-greeter
wget https://github.com/raspberrypi-ui/pi-greeter/archive/refs/heads/master.zip
unzip master.zip ; cd rpi-greeter-master
autogen.sh
./configure
make
sudo make install
Change /etc/lightdm/lightdm.conf with:
greeter-session=pi-greeter-labwc
Test with:
$ sudo lightdm --test-mode --debug
or
$ sudo systemctl start lightdm
$ journalctl -b -u lightdm.service
The error is:
Oct 13 22:01:49 orangepizero3 lightdm[845]: Error updating user /org/freedesktop/Accounts/User1000: GDBus.Error:org.freedesktop.Accounts.Error.PermissionDenied: Not authorized: GDBus.Error:org.freedesktop.DBus.Error.ServiceUnknown: The name org.freedesktop.PolicyKit1 was not provided by any .service files
DEBUG: Could not run plymouth --ping: Failed to execute child process ?plymouth? (No such file or directory)
I think I am very close to getting rpi-greeter working. What could be missing?
I see that in a raspberry pi, the folder /etc/xdg/labwc-greeter/ exists, with 3 files inside, but in armbian, it doesn't exist. Should it be created by sudo make install?
sudo nano /var/log/lightdm/lightdm.log:
Nothing weird. Only:
[+0.07s] DEBUG: Session pid=6392: Running command /usr/bin/labwc -C /etc/xdg/labwc-greeter/ (and this folder /etc/xdg/labwc-greeter/ does not exist)
In raspberry: /etc/xdg/labwc-greeter/ contains autostart, rc.xml and environment
sudo nano /var/log/lightdm/seat0-greeter.log:
** (process:6392): WARNING **: 00:23:07.745: Failed to open CK session: GDBus.Error:org.freedesktop.DBus.E>
00:00:00.000 [ERROR] [../src/main.c:202] XDG_RUNTIME_DIR is unset
The etc/xdg/labwc-greeter/autostart, etc files come from a package named raspberrypi-ui-mods
(raspberry$ dpkg -S /etc/xdg/labwc-greeter/autostart)
What part of https://github.com/raspberrypi-ui/raspberrypi-ui-mods would get my lightdm+labwc+rpigreeter working?
Copying the /etc/xdg/labwc-greeter/ folder with the 3 files, with the same permissions, allow the pi-greeter to display (it is very plain), but after entering the password, the text mode display shows for 2 seconds, then the labwc black background and cursor shows for 1/4 second, then returns to the login screen.
Found this error in the log:
/etc/xdg/labwc-greeter//autostart: 2: /usr/bin/kanshi: not found
Final part of solution:
lightdm should contain:
user-session=LXDE-pi-labwc
Create file /usr/share/wayland-sessions/ LXDE-pi-labwc.desktop:
[Desktop Entry]
Type=Application
Name=Labwc Desktop on Wayland
Exec=/usr/bin/labwc
rpi-greeter does not allow selection of other sessions: only labwc
Edited by robertoj
