Faheem328 Posted October 2, 2025 Posted October 2, 2025 The wifi and ethernet both are not working for my transpeed 8k tv device. it has a rk3528 chipset. 1. I tried resetting it from its android factory setting. it did not work. 2. I found its image which i flashed via RKdevtool. Still the both wifi and lan did not work. 3. i tried external usb wifi dongle but it did not detect it. 4. I tried to install debian OS i found somewhere on internet designed for rk3528 on it as alternative but rkdevtool did not identified the image Any suggestions would be welcome. Thanks in advance, 0 Quote
laibsch Posted October 2, 2025 Posted October 2, 2025 We support Armbian software but not random software from the internet. RKdevtool is as far as I know a tool from Radxa, not Armbian, either. CPU boxes are cheap and cheap for a reason. Nobody really supports them. We give some very limited community support here. With your current random software this is not the right spot for you. Best of luck to you. 0 Quote
Hqnicolas Posted October 2, 2025 Posted October 2, 2025 @Faheem328 Do you have free time? how much free time do you have exactly? we are looking for someone like you with a RK3528 box we are depending on him finding a weekend to dedicate to the community https://github.com/ilyakurdyukov/rk3528-tvbox he will help us by taking this repository and including it in armbian with a wonderful pull request let's talk? 0 Quote
johlnx Posted October 31, 2025 Posted October 31, 2025 I am in the process of installing Armbian on the X88pro13 TV box, which has the RK3528 CPU. https://github.com/joilg/x88pro wifi and ethernet are working 0 Quote
