Meestor_X Posted Sunday at 05:09 PM Posted Sunday at 05:09 PM (edited) Is there a github repo for armbian-install? On the RockPi-S with both eMMC and SD cards installed, it's showing the devices backwards or un-named in the menu. I'd like to open an issue report to see if it can be fixed. Edited Sunday at 05:09 PM by Meestor_X 0 Quote
Meestor_X Posted Monday at 12:32 AM Author Posted Monday at 12:32 AM Can someone explain these lines? # find real mmcblk device numbered 0, 1, 2 for eMMC, SD for ret in $(find /dev -name 'mmcblk[0-2]' -and -type b) do if [ -b ${ret}boot0 ];then emmc_dev=$ret else sd_dev=$ret fi done On the RockPi-S, $ret would equal mmcblk0 and mmcblk1 which are the eMMC and SD card, respectively. There's no device called "mmcblk0boot0" or "mmcblk1boot0". 0 Quote
Meestor_X Posted Monday at 03:44 AM Author Posted Monday at 03:44 AM Oh! I guess I reported this same issue a while ago - never got an answer. Is there a github repo to report issues with this program? 0 Quote
going Posted Monday at 11:49 AM Posted Monday at 11:49 AM 16 часов назад, Meestor_X сказал: Is there a github repo for armbian-install? On the RockPi-S with both eMMC and SD cards installed, it's showing the devices backwards or un-named in the menu. I'd like to open an issue report to see if it can be fixed. Please post the output of the df -h and lsblk commands here. Which image are you using and which version of u-boot is running on your board? (this can be seen in the UART console) 0 Quote
Meestor_X Posted Monday at 04:31 PM Author Posted Monday at 04:31 PM df -h Filesystem Size Used Avail Use% Mounted on udev 159M 0 159M 0% /dev tmpfs 47M 4.8M 42M 11% /run /dev/mmcblk1p1 58G 3.4G 53G 7% / tmpfs 234M 76K 233M 1% /dev/shm tmpfs 5.0M 0 5.0M 0% /run/lock tmpfs 234M 4.0K 234M 1% /tmp /dev/zram1 47M 2.4M 42M 6% /var/log /dev/mmcblk0p1 3.4G 2.0G 1.3G 62% /media/emmc tmpfs 47M 0 47M 0% /run/user/0 lsblk NAME MAJ:MIN RM SIZE RO TYPE MOUNTPOINTS mmcblk1 179:0 0 59.6G 0 disk └─mmcblk1p1 179:1 0 59G 0 part /var/log.hdd / mmcblk0 179:32 0 3.6G 0 disk └─mmcblk0p1 179:33 0 3.5G 0 part /media/emmc zram0 252:0 0 233.1M 0 disk [SWAP] zram1 252:1 0 50M 0 disk /var/log zram2 252:2 0 0B 0 disk lsb_release -a No LSB modules are available. Distributor ID: Debian Description: Armbian 25.8.1 bookworm Release: 12 Codename: bookworm uname -r 6.12.44-current-rockchip64 I don't have an easy way to do the serial terminal thing to check U-Boot. I have updated it to the "latest" using armbian-install, however... 0 Quote
going Posted Monday at 07:04 PM Posted Monday at 07:04 PM 1 час назад, Meestor_X сказал: mmcblk1 179:0 0 59.6G 0 disk └─mmcblk1p1 179:1 0 59G 0 part /var/log.hdd Is this your SD card? 1 час назад, Meestor_X сказал: mmcblk0 179:32 0 3.6G 0 disk └─mmcblk0p1 179:33 0 3.5G 0 part /media/emmc This is your eMMC just 3.6G in size. This is the first time I have met this variant. We need to think about whether it is possible to add an exception for this case. 0 Quote
Meestor_X Posted Monday at 07:11 PM Author Posted Monday at 07:11 PM Correct. Many Radxa SBC’s work this way. RockPi-S, RockPi-S0, RockPi-E, E20c, e25c, e52c, rock-pi-zero, etc. 0 Quote
Meestor_X Posted Monday at 09:56 PM Author Posted Monday at 09:56 PM If I understood a bit better what the script is doing, i.e. this part: Then maybe I could help with updating it to work with the Radxa products. 0 Quote
going Posted yesterday at 04:25 PM Posted yesterday at 04:25 PM 18 часов назад, Meestor_X сказал: If I understood a bit better what the script is doing, i.e. this part: Then maybe I could help with updating it to work with the Radxa products. On 99% of the devices I know, eMMC is initialized in the OS as /dev/mmcblk0, but there are cases when this is not the case. # find real mmcblk device numbered 0, 1, 2 for eMMC, SD for ret in $(find /dev -name 'mmcblk[0-2]' -and -type b) do if [ -b ${ret}boot0 ];then emmc_dev=$ret else sd_dev=$ret fi done This part of the code was implemented due to the fact that on some eMCC platforms there can be both /dev/mmsblk0 and /dev/mmcblk1(2) This works for chips that provide boot0\boot1 partitions to write the bootloader. I think we can add more sophisticated logic to handle this exception for these chips. You can add here the name of the chip on your device. The translation may not be accurate. Please specify if something is not clear. 0 Quote
Meestor_X Posted yesterday at 06:06 PM Author Posted yesterday at 06:06 PM Thank you. What do you suggest I do? I'm not sure that the "update bootloader" choices are showing the correct devices either. 0 Quote
going Posted yesterday at 07:25 PM Posted yesterday at 07:25 PM 1 час назад, Meestor_X сказал: What do you suggest I do? I'm not sure that the "update bootloader" choices are showing the correct devices either. Please show screenshots of the selection menu step by step when you are trying to install the OS on eMMC. Show me what you see that I cannot see. 0 Quote
Meestor_X Posted 23 hours ago Author Posted 23 hours ago Screenshot is in the original post, it still looks the same now. 0 Quote
going Posted 7 hours ago Posted 7 hours ago 06.10.2025 в 03:32, Meestor_X сказал: Can someone explain these lines? # find real mmcblk device numbered 0, 1, 2 for eMMC, SD for ret in $(find /dev -name 'mmcblk[0-2]' -and -type b) do if [ -b ${ret}boot0 ];then emmc_dev=$ret else sd_dev=$ret fi done On the RockPi-S, $ret would equal mmcblk0 and mmcblk1 which are the eMMC and SD card, respectively. There's no device called "mmcblk0boot0" or "mmcblk1boot0". Copy armbian-install to bin home directory Цитата cd $HOME mkdir -p bin cp /usr/bin/armbian-install $HOME/bin/ nano ./bin/armbian-install Please replace line 839 as indicated here: Цитата @@ -836,7 +836,7 @@ main() # find real mmcblk device numbered 0, 1, 2 for eMMC, SD for ret in $(find /dev -name 'mmcblk[0-2]' -and -type b) do - if [ -b ${ret}boot0 ];then + if [ -b ${ret}boot0 ] || [ "${emmccheck}" == "$ret" ]; then emmc_dev=$ret else sd_dev=$ret Run the corrected version of the script. Цитата sudo ./bin/armbian-install If everything works correctly for you, confirm it here. I will add a correction to the next pull request. 0 Quote
Meestor_X Posted 5 hours ago Author Posted 5 hours ago That seems to work! Let me ask you this, though. Can you clarify what selection #2 means? Selection #1 will copy the eMMC image to the SD card. Selection #3 will copy the SD card to the eMMC (shouldn't the text read "Boot from eMMC - system on SD Card, SATA, USB or NVMe") What is selection #2 for? 0 Quote
going Posted 4 hours ago Posted 4 hours ago 19 минут назад, Meestor_X сказал: What is selection #2 for? see: /usr/bin/armbian-install The create_armbian function takes different arguments depending on the selection number. 49 минут назад, Meestor_X сказал: That seems to work! Everything looks right on this selection screen. But it seems to me that we see an excessive selection offer in the next selection step and this is misleading. But on other platforms where loading is possible only from a soldered chip, which is defined by the kernel as /dev/mtd, the selection screen will look logical. Try installing the OS on an eMMC or on an SSD connected to the device via a USB-SATA adapter using various options. Experiment. If you find illogical options, then feel free to write your opinion here. 0 Quote
Meestor_X Posted 4 hours ago Author Posted 4 hours ago Ok, I only use this utility on Radxa products ATM, and AFAIK they can't boot from USB without a bootloader on the eMMC or SD card. If I had an image on a USB flash drive attached to the SBC, where would armbian-install expect to find it mounted? And then, would choice #1 or #3 use the SD card or the USB image? Also, should option #2 not show? I don't know how it would copy from the eMMC to the eMMC... The operation of the script works well, but the menu could be much clearer for the Radxa products. 0 Quote
going Posted 1 hour ago Posted 1 hour ago 2 часа назад, Meestor_X сказал: If I had an image on a USB flash drive attached to the SBC Sorry, I don't have this device. Try inserting a USB flash drive into the USB connector and installing the OS from the SD card on it. Try the available options. And choose focusing on your own real logic. Of particular interest and attention if you install the OS on eMMC. Then boot from the eMMC without an SD card connected. And then insert the card into the SD connector and run $HOME/bin/armbian-install. What do you see in the selection window? 0 Quote
