Johhny Blue Posted November 8, 2017 Posted November 8, 2017 Hi. I am hoping to connect this type of IR receiver to my NanoPi Neo. https://www.jaycar.com.au/arduino-compatible-infrared-receiver-module/p/XC4427 I am hoping that all I need to do is connect 5v, ground and signal to the IR receiver pin to pin 6 on the header. Can anyone help me with the software and what I need to do to install lirc so the IR receiver is recognised? TIA V.
nopnop2002 Posted November 9, 2017 Posted November 9, 2017 Pin assignment of this module is probably below. The left :Signal ->IR receiver pin.pin #6 on the 12 pin header Medium :Gnd The right :3.3v An IR receiver power supply has to be 3.3V. Don't use 5V. Check this. https://www.marinostore.com/sensores/87-receptor-infravermelho-tl1838-vs1838-vs1838b.html Installation is same as OPI-PC.
