binkerd Posted November 5, 2025 Posted November 5, 2025 Armbianmonitor: https://paste.armbian.com/wisasakara Error trying to run apt upgrade. Here is the error I receive: The following packages have unmet dependencies: armbian-bsp-cli-rpi4b-current : Depends: base-files (>= 25.8.2) but 25.8.1-12.4+deb12u11-bookworm is to be installed E: Unable to correct problems, you have held broken packages. I am not sure how to resolve this. Help will be greatly appreciated. 0 Quote
callegar Posted November 8, 2025 Posted November 8, 2025 See There is an issue with the build framework that prevents base-files from being built for the arm64 target. At present time the issue is unresolved, and the root cause might be still unknown. 0 Quote
