Linlunson Posted December 28, 2025 Posted December 28, 2025 Hello Nick A, Thank you so much, I have a radxa a7z, I successed to use your 0.4 img to boot the soc cli and with desktop. So far I still can not figure out the kvm fuction, even I can get the same result with your command: grep CONFIG_KVM /boot/config-$(uname -r) I can not start the kvm related docker container like this one: https://github.com/dockur/windows-arm , which I successed to run this windows arm container on raspberry pi 5. Would you help to have a look about this issue, thank you! 0 Quote
wolfyportal Posted December 28, 2025 Posted December 28, 2025 I've also been dealing with KVM issues these past couple of days and try to ask AI too it said Nick is build the right kernel, like the command you check but the problem seems is cpu can enter to EL2 mode(which has virtualization support) and that's the problem on bootloader so we need to wait Allwinner and radxa to fix together and also since Nick quoted the offical response on "A7A: Harware Virtualization" so I check the offical image too and have the same issue, the system also don't supported virtualization too I think this also confirms to some extent for EL2 mode switch support btw Nick also discussing this issue with others in the Discord channel seems to have yielded no results because I know very little about ARM SBC I'm unable to participate in this discussion(can only watch and test) but I think maybe this issue should be reported to official so they will know only hardware supported it but the bootloader stuck(if AI's conclusions right) 0 Quote
Linlunson Posted December 28, 2025 Posted December 28, 2025 3 hours ago, wolfyportal said: I've also been dealing with KVM issues these past couple of days and try to ask AI too it said Nick is build the right kernel, like the command you check but the problem seems is cpu can enter to EL2 mode(which has virtualization support) and that's the problem on bootloader so we need to wait Allwinner and radxa to fix together and also since Nick quoted the offical response on "A7A: Harware Virtualization" so I check the offical image too and have the same issue, the system also don't supported virtualization too I think this also confirms to some extent for EL2 mode switch support btw Nick also discussing this issue with others in the Discord channel seems to have yielded no results because I know very little about ARM SBC I'm unable to participate in this discussion(can only watch and test) but I think maybe this issue should be reported to official so they will know only hardware supported it but the bootloader stuck(if AI's conclusions right) Thank you Wolfypotal for the update, The recent days I was also test the official image, Nick A's 0.4, but no good luck for the kvm, which actrally the big reason I purchase this cute small soc. I even upgrade the broad to have 8GB ram and 256 UFS, to use the kvm qemu... 1 Quote
wolfyportal Posted December 28, 2025 Posted December 28, 2025 @Linlunson same, I want to run pxvirt on it but now I can only play some container with docker without virtualization funny thing even old raspberry pi can use kvm feature but this "new" allwinner chip can't this out-of-the-box support this besic feature I think I was also deceived by radxa's staff in some way https://forum.radxa.com/t/a7a-harware-virtualization/29745 anyway I also test on Nick's image, but mean the offical image from radxa https://github.com/radxa-build/radxa-a733/releases and it also not work(still stuck on EL1) so I think maybe Nick is do everything he can do issue might on bootloader I asked about the cpu exception levels on discord channel sometime radxa's staff will answer in there too or maybe someone knows about this we just needs standby... 0 Quote
eselarm Posted December 28, 2025 Posted December 28, 2025 28 minutes ago, wolfyportal said: I think I was also deceived by radxa's staff in some way https://forum.radxa.com/t/a7a-harware-virtualization/29745 anyway I also test on Nick's image, but mean the offical image from radxa https://github.com/radxa-build/radxa-a733/releases and it also not work(still stuck on EL1) Radxa staff actually does not answer the original question w.r.t. Allwinner A733 HW virtualization, it is just that kernel config has it. But I see from releases 'bullseye', that does not look good at all. In theory, that means 5.10 kernel, and oldoldstable libvirtd/KVM/QEMU etc. As this SoC is bigLITTLE, (Cortex-A76 Cortex-A55), starting a qemu-system-aarch64 process will pick some of those cores randomly, assuming you have more than 1 vCore (smp option > 1) . Kernel older than 6.8 or so does not support moving between an A76 and an A55. That is the same for Rockchips (RK3588). It took me quite a while before I discovered that this is known behavior. So on for example on vendor rk35xx 6.1.115, I pin vCPUs, can be done in virt-manager GUI xml config or cmdline via taskset. As easy test, use -smp 1, then it should work. mainline kernel CPU numbers are such that simplest/lowest CPU's get lowest number. That might be the other way around on 6.1 or older downstream/vendor/BSP kernels. On an RK3588, a 2-core VM with 2x A76 and 512MiB is done by: taskset --cpu-list 6-7 qemu-system-aarch64 -M virt -cpu host -enable-kvm -m 512 -smp 2 \ -bios u-boot.bin \ -drive if=none,file=armbian.img,format=raw,id=hd0 \ -device virtio-blk-device,drive=hd0 \ -netdev bridge,id=hn1 -device virtio-net,netdev=hn1 \ -nographic Same should work on A733 1 Quote
wolfyportal Posted December 28, 2025 Posted December 28, 2025 32 minutes ago, eselarm said: Kernel older than 6.8 or so does not support moving between an A76 and an A55 thank you for adding information about big.LITTLE seems that will be the next issue when we need to work virtualization on A7A/A7Z but for now, we seems facing the problem during the boot process CPU in the wrong exception levels(model) so the virtualization is not support in any situation(my guess) also Nick thought it's about u-boot issue and used the official binary image so we might need to wait for official update or we need to work by ourself 0 Quote
eselarm Posted December 29, 2025 Posted December 29, 2025 (edited) On 12/28/2025 at 9:29 AM, wolfyportal said: but the problem seems is cpu can enter to EL2 mode(which has virtualization support) 21 hours ago, wolfyportal said: and it also not work(still stuck on EL1) I now actually see after some more reading and checking other SoC's that the CPU's in the A733 must start the kernel at EL2. See also ARM reference doc: 102412_0103_01_en So also 5.x kernel should work if EL2 I think If the A733 has not implemented EL2 and EL3 as could be the case as suggested in ARM reference doc, no KVM. See chapter6: Quote What Exception levels are implemented in Armv8-A? EL0 and EL1 are mandatory. EL2 and EL3 are optional but implemented by most designs. As it is Allwinner, I won't be surprised, but wait and see what Radxa will come up with. Edited December 29, 2025 by eselarm 1 Quote
伍翠波 Posted January 3 Posted January 3 (edited) How to compile a UFS image that can be written using sudo dd? Edited January 3 by 伍翠波 0 Quote
Nick A Posted January 4 Author Posted January 4 (edited) I haven't tested ufs yet. I think you have to add this extension in build/config/boards/radxa-cubie-a7a.csc enable_extension "ufs" https://github.com/NickAlilovic/build/blob/a733/config/boards/radxa-cubie-a7a.csc @chainsx is working on his own build. He just updated his build with a ufs fix. https://github.com/chainsx/build/tree/a733 You might need to add this to boot his images. Not sure if it's fix. NAME_INITRD="initrd.img-5.15.147-legacy-sun60iw2" or NAME_INITRD="initrd.img-6.6.98-vendor-sun60iw2" Edited January 4 by Nick A 0 Quote
chris178 Posted January 5 Posted January 5 Thank you Nick, great work - best overall image so far for the A7Z a733 board. I'm experimenting with 13M imx214 radxa camera - how to get correct device tree for your image? I see that imx214 module is compiled, but CSI interface configuration seems to be missing. 0 Quote
Nick A Posted January 7 Author Posted January 7 @chris178 I am currently working on a solution. Radxa typically uses rsetup and extlinux.conf to load overlays during boot; however, Armbian uses armbian-config along with boot.cmd and boot.scr. I have decided to use armbian-config to load the overlays instead. 0 Quote
chris178 Posted January 9 Posted January 9 (edited) Thanks Nick. In the meanwhile, would dtbo overlay, setting up CSI taken from radxa's github a733, work with kernel/u-boot of your image? Is there a way I can manually alter boot files to get this dtbo loaded? This is of course for the experiment - radxa's a733 image seems to still have a problem with ISP processor (or dtbo file affecting data formatting), as the resulting picture from the camera seems to be in a wrong color space (by the look, but I'm not an expert). I've reported the issue at https://forum.radxa.com/t/radxa-cubie-a7a-radxa-13m-214-camera/29717/7 for anyone interested. Edited January 9 by chris178 0 Quote
Platinum_78 Posted January 10 Posted January 10 Realy cool, but is gpio supposed? I can't get it to work do I need to download some drivers? 0 Quote
Nick A Posted January 10 Author Posted January 10 @chris178 SmartSolution on discord says his camera works. SmartSolution Hi, i had problem with camera and isp color quality After check and test download radxa-a733 t2 rsdk , image file and upload on mmc and after load system all camera works good 0 Quote
Bones558 Posted January 22 Posted January 22 I'm having an issue getting my A7z to boot using your Armbian build tree. I created an image using Nobel and kernel 6. Wrote it to the SD card using Armbian imager. The status light on my A7z always stays solid-on. Any ideas? Armbian-unofficial_26.02.0-trunk_Radxa-cubie-a7z_noble_vendor_6.6.98.img.xz 0 Quote
Nick A Posted January 22 Author Posted January 22 (edited) @Bones558 I don't have a a7z to test with right now. I should be getting one soon and I'll look into it. I'm pretty sure a USB to UART serial device works. Edited January 22 by Nick A 0 Quote
Bones558 Posted January 22 Posted January 22 (edited) @Nick A Since both the A7a and A7z have the same CPU family, I made a build using the exact same options, but selecting the A7a instead in the compile menu. This build did start to boot, I saw the Radxa logo, then some Linux console boot messages (but it was scrambled on the screen a bit), and lastly I saw the Armbian logo and the spinning circle. Eventually that all went away and the screen was just empty. No response from key presses, etc., but my HDMI screen was still getting signal, it was just blank. I also tested different distros and versions available to see if that made any difference (ex. debian vs ubuntu, nodel vs plucky vs bookworm; etc...), non of that had any effect. So it appears, at a first start, to be a A7a vs A7z build difference to at least get an attempt at boot. Then the next issue is that it never fully reaches a usable OS console. Thanks! Edited January 22 by Bones558 additional info 0 Quote
zmxyz Posted January 23 Posted January 23 (edited) @Bones558 I think the LED is always on by default and doesn't blink. You can try kernel 5.15, I'm using Armbian-unofficial_25.11.0-trunk_Radxa-cubie-a7z_jammy_legacy_5.15.147.img Since I don't have any TTL modules or display adapters, I directly followed the instructions at https://docs.armbian.com/User-Guide_Autoconfig/ to set up the wireless network. After powering it on and waiting for a while, I could directly access SSH. Hope this helps. Edited January 23 by zmxyz 0 Quote
Nick A Posted January 30 Author Posted January 30 (edited) @Bones558 I guess you are using a USB-C to HDMI adapter? I bought one and it doesn't work on kernel 6.6. I think it's because the DRM heap driver hasn't been updated yet. I got a Micro HDMI to HDMI cable, and that works. Edited January 30 by Nick A 0 Quote
alexc Posted February 1 Posted February 1 @Nick A @Bones558 Hi there, I am not sure if that's definitely due to DRM heap. But I fixed that driver and it could be built now. I didn't know if USB C DP works or not before but it is working now (on a USB C monitor, maybe needs a few re-plug). I opened a PR on Radxa allwinner-bsp github (https://github.com/radxa/allwinner-bsp/pull/11), you can also test it out. 0 Quote
Nick A Posted February 1 Author Posted February 1 (edited) @Bones558 @alexc I noticed that a few USB-C drivers are missing in the 6.6 kernel. While the Makefile and Kconfig files are present, they have changed. In the 5.15 BSP, the bsp/drivers/usb/typec/tcpm directory contains tcpci_et7304.c and tcpci_husb311.c, but in 6.6, this directory is empty. 6.6: bsp/drivers/usb/typec/tcpm$ ls Kconfig Makefile 5.15: bsp/drivers/usb/typec/tcpm$ ls Kconfig Makefile tcpci_et7304.c tcpci_husb311.c Edited February 1 by Nick A 0 Quote
alexc Posted February 1 Posted February 1 (edited) @Nick A Oh yeah, I did change a few things as well for type c. Maybe the drm heap changes are not needed after all. Looking at my changes. husb311 is now under drivers/power/typec, so just enable it. et7304 is not included in the original bsp, radxa team added them later so simply apply this same patch. https://github.com/radxa/allwinner-bsp/commit/156b6578cc173855b41ea311a229403ccbadb17c Edited February 1 by alexc 0 Quote
Nick A Posted Thursday at 04:35 PM Author Posted Thursday at 04:35 PM @Bones558 Try these images. No boot splash on a7z yet. I'll look into it when I have time. https://github.com/NickAlilovic/build/releases/tag/Radxa-a7a-a7z-v0.6 0 Quote
Robin Hoo Posted Saturday at 01:15 AM Posted Saturday at 01:15 AM @Nick A I am not sure whether you can help release some versions of image with ufs supported, as I tried to compile from source with @chainsx git, but not once successful. If you can release the relevant versions of ufs support image? Thanks 0 Quote
Nick A Posted Saturday at 02:21 PM Author Posted Saturday at 02:21 PM @Robin Hoo I don't have UFS so I can't test it. But I think if you add enable_extension "ufs" to https://raw.githubusercontent.com/NickAlilovic/build/refs/heads/Radxa-A7A/config/boards/radxa-cubie-a7a.csc it might work. git clone https://github.com/NickAlilovic/build.git --branch Radxa-A7A cd build echo 'enable_extension "ufs" ' >> config/boards/radxa-cubie-a7a.csc or echo 'enable_extension "ufs" ' >> config/boards/radxa-cubie-a7z.csc ./compile.sh 0 Quote
Nick A Posted Saturday at 06:54 PM Author Posted Saturday at 06:54 PM (edited) @Bones558 I made a custom U-Boot to fix the boot splash, but so far it only works on micro-HDMI. This patch fixed the U-Boot splash for HDMI on the A7A. It also fixes the splash on the A7Z via micro-HDMI. However, when using DisplayPort Alt Mode, there is a different disp0_hdmi0 node that I need to apply the fix to. I'll play around with it tomorrow. Edited Sunday at 01:38 AM by Nick A 0 Quote
Nick A Posted Sunday at 01:15 AM Author Posted Sunday at 01:15 AM (edited) @alexc Thanks for your patch and suggestions. It turns out the DRM heap isn't strictly required for DisplayPort Alt mode, but I'm sure it resolved other issues within the 6.6 kernel. I assumed it was the DRM heap because it was the only missing kernel configuration option. I suppose the kernel doesn't report missing source code drivers, or I simply didn't notice. It’s great to have your help getting this Armbian BSP build function. At least until a mainline version is released Edited Sunday at 01:40 AM by Nick A 0 Quote
alexc Posted Sunday at 05:12 AM Posted Sunday at 05:12 AM @Nick A No problem. Thanks for your Armbian build as well! I am also looking forward to mainline. Currently I still didn't find open source Mesa driver for Allwinner BSP, GLES is only available as pre-compiled binary for Debian (haven't tested it but it's in the Radxa images). There already are mainline Mesa/Linux IMG GPU supports so I hope things can be ported to mainline soon. Please let me know if anyone finds the source code for Mesa BSP. 0 Quote
Robin Hoo Posted 3 hours ago Posted 3 hours ago On 2/7/2026 at 10:21 PM, Nick A said: @Robin Hoo I don't have UFS so I can't test it. But I think if you add enable_extension "ufs" to https://raw.githubusercontent.com/NickAlilovic/build/refs/heads/Radxa-A7A/config/boards/radxa-cubie-a7a.csc it might work. git clone https://github.com/NickAlilovic/build.git --branch Radxa-A7A cd build echo 'enable_extension "ufs" ' >> config/boards/radxa-cubie-a7a.csc or echo 'enable_extension "ufs" ' >> config/boards/radxa-cubie-a7z.csc ./compile.sh Great! It's working now, sorry, I made it too complex previously. 0 Quote
