dev001 Posted November 14, 2025 Posted November 14, 2025 Using odroidxu4. flashed Armbian_25.8.1_Odroidxu4_noble_current_6.6.102 to eMMC After odroidxu4 started, followed instruction to create accounts etc. Installed xfce4 package reboot. odroidxu4 booted to console prompt Installed xfce4-goodies package reboot. odroidxu4 booted to console prompt Installed lightdm reboot. The system becomes stuck at plymouth-quit-wait.service/start Not much I could do after this as I could not look at log messages or use $ sudo systemctl status lightdm.service Any insight greatly appreciated Thanks 0 Quote
Solution dev001 Posted November 16, 2025 Author Solution Posted November 16, 2025 Made some progress. after installing Armbian_25.8.1_Odroidxu4_noble_current_6.6.102 to eMMC ran armbian-upgrade Installed xubuntu-desktop or xubuntu-desktop-minimal package reboot now i'm getting the greeter screen. after login, I entered xfce desktop. functions ok could only install firefox via snap. installed firefox via snap ran firefox to view a video on youtube. audio is not working. install pulseaudio reboot system audio still not working when viewing a youtube video any suggestions? 0 Quote
dev001 Posted November 22, 2025 Author Posted November 22, 2025 Thanks. I got pulseaudio working 0 Quote
laibsch Posted November 22, 2025 Posted November 22, 2025 please DO share what steps you took to get it working for the benefit of the next guy. 0 Quote
eselarm Posted November 22, 2025 Posted November 22, 2025 (edited) For SBCs without own audio I use networked pulseaudio. I never got it to work in newly installed Jammy and Bookworm, also not in Bookworm upgraded in-place to Trixie. It worked in Buster, BuIlseye and allways worked in Opensuse Tumbleweed. I already had all pipewire user sockets and services disabled and pulseaudio enabled, also de-installed pipewire-pulse as that one is the problem I believe (but is more than a year ago I looked at it). Now it turns out that doing 'pactl load-module module-zeroconf-discover' did add remote audio sinks. GUI based paprefs in Ubuntu/Debian should do it, but that is all grey since years, cannot be selected nor changed. So NanoPi-R6C with Armbian Trixie edge kernel now also plays audio via Armbian Trixie NanoPi-NEO SPDIF enabled with long simple wiring to an amplifier that takes coaxial SPDIF as input. I also had it working analog, but way too much issues with noise etc. 'the long simple wiring' is 1 lead of a low-quality twin analog audio cable, shielding=GND, core=signal. Edited November 22, 2025 by eselarm 0 Quote
dev001 Posted November 24, 2025 Author Posted November 24, 2025 i use a usb to 3.5mm headphone adapter. 0 Quote
