lutzlapalma Posted November 14 Posted November 14 Armbianmonitor: https://paste.armbian.com/kagotukado I am an Linux Beginner and I only can use Terminal for copy/paste issues. For many months my Raspberry Pi 5 runs perfectly with Armbian. But when I try to update the system in the Discover App, I get the following error message: The following packages have unmet dependencies: kpim6-akonadi: Kollidiert mit: knotes but 4:24.05.2+p24.04+vstable+git20240705.1500-0 is to be installed Kollidiert mit: kpim6-akonadi-notes but 4:24.08.3+p24.04+vstable+git20241129.1417-0 is to be installed Can someone please help me to get my system up-to-date? Thanks in advance! 0 Quote
CryBaby Posted November 15 Posted November 15 It looks like knotes has been replaced with Marknotes. Remove knotes and, if you like, install marknotes. It is supposed to import your old knotes data. 0 Quote
lutzlapalma Posted November 18 Author Posted November 18 As I mentioned before, I am a Newby and I am able to use the Terminal. But I don’t know, what to do to remove knotes. 0 Quote
lutzlapalma Posted November 18 Author Posted November 18 Now I did exactly this and after rebooting the Pi, I just get a black screen with a movable mouse cursor. Nothing more, it doesn’t matter how long I wait. What problem is this now? 0 Quote
laibsch Posted November 19 Posted November 19 most likely a bunch of packages that shouldn't have been removed were removed alongside, the joys of GUI package management 1) don't be afraid of the command line 2) see if /var/log/dpkg.log gives any hints what is missing What desktop system were you using before? Try to get it back installed. PS: In your current situation, you can reach a log-in console and command line with Ctrl-Alt-F1 PPS: Reinstalling from scratch might be faster. 0 Quote
CryBaby Posted November 19 Posted November 19 Did you do Update All after removing knotes? If you were running wayland you will probably need to use Ctrl-Alt-F3 as wayland uses F1 and there is an (unusable) X server on F2 for xwayland. Then, after logging in sudo apt update sudo apt full-upgrade If that's not enough try sudo apt install task-kde-desktop 0 Quote
