I am unable to get any RTC installed on a C2 with current Armbian.  i2cdetect sees the device ID but no joy getting anything to talk to it.   Yes, I know these are very old but they were donated to a non-profit and I am trying to help set them up for a project.  Current Armbian runs great and perfect for our need.  I need an RTC.  I have tried both the Odroid PCF8563 (0x51 seen) and DS3231.  I have tried all the online blog posts, rebuilt the Device Tree, etc. but can't seem to get things to work.  Any pointers would be much appreciate.
LInux odroidc2 6.12.56-current-meson64 #1 SMP PREEMPT Wed. Oct 29 13:09:02 UTC 2025
Thanks,
Scott
Hi @Scott Ksander,
`i2cdetect` will just detect stuff on the I2C bus, you would not need a DT overlay for the device for that to work. For the kernel to detect the device and load the appropriate kernel module for it, you do have to make sure the device is known in the DT.
I'm not sure about your board, but for a PCF8523 (different RTC) my Nanopi Neo3 I had to add or adjust an existing user overlay to make the PFC known to the kernel.
/dts-v1/;
/plugin/;
  compatible = "rockchip,rk3328";
  fragment@1 {
    target = <&i2c0>;
    __overlay__ {
        #address-cells = <1>;
        #size-cells = <0>;
        pcf8523@68 {
            compatible = "nxp,pcf8523";
            reg = <0x68>;
            status = "okay";
&rk805 {
  rk808-rtc {
    status = "disabled";
For a DS3231 I also had to add a user overlay that would tell the kernel that it can use the DS3232 driver for a DS3231 device. You most likely already found all the information on this already on the interwebs.
You will have to adjust the compatible entry to your board, you might even try without that line completely.
Add the file to `/boot/overlay-user/` and then compile and add to `armbianEnv.txt` using `armbian-add-overlay`.
Groetjes,
