Patrick 42 Posted December 4, 2025 Posted December 4, 2025 (edited) Hi, I'am Patrick from France, it is my first post on the forum. I am porting the Zortrax m200 plus 3D printer to Armbian and my last important step would be to have the LCD screen working. I cross compiled my module but I have this message when installing it: # insmod panel-himax-hx8394.ko [ 1760.189919] BPF: [120533] Invalid name_offset:2238391 [ 1760.195183] failed to validate module [panel_himax_hx8394] BTF: -22 insmod: ERROR: could not insert module panel-himax-hx8394.ko: Invalid parameters Then I added the module source code to the sources, but calling ./compile.sh seems to update the repo and revert my changes such as I do not see my module in there. The next possibility would be to create an image with the kernel headers included. I will try to compile the driver on the system. And is there another way? Edited December 4, 2025 by Patrick 42 0 Quote
robertoj Posted December 4, 2025 Posted December 4, 2025 You dont need to cross-compile. You need to select the in-kernel-source option: https://www.kernelconfig.io/config_drm_panel_himax_hx8394 within the armbian build process. Then you need to create a DTS like: https://forum.armbian.com/topic/47971-driving-the-ili9488-lcd-40-inch-cheap-chinese-clone/ And also dig through the experience in this thread: https://forum.armbian.com/topic/50963-dsi-display-does-not-work-on-raspberry-pi-5/#comment-216030 Send photo of the a33 and LCD 0 Quote
Patrick 42 Posted December 4, 2025 Author Posted December 4, 2025 (edited) I have managed to compile the driver on the target with a brand new image compiled using "./compile.sh INSTALL_HEADERS=yes". Yet I would like to cross compile it. If you know how, I will greatly appreciate if you give the method. Edited December 4, 2025 by Patrick 42 0 Quote
Patrick 42 Posted December 5, 2025 Author Posted December 5, 2025 Thanks Robertoj All the documentation for the board is here https://github.com/zharijs/zmxxxp-re But the LCD is not an himax-hx8394. The screen is a "MTF0397SWI-06" using the chip OTM8019A. It just that I am starting from this driver to port the sunxi driver: sl698ph_720p. I will now look at your links. 0 Quote
Patrick 42 Posted December 6, 2025 Author Posted December 6, 2025 I am strugling withthe AXP223 gpio LDO configuration to initialise properly, otherwise the i2C lines to the touchscreen controller are unpowered. Therefore I will add traces in the axP223 rsb (reduced signal bus) driver code. And I try to not be annoying here, but I am a bit lost. What is the common method for driver debugging/development in armbian? I mean how to recompile the kernel without rebuilding all the image? For now I changed the kernel configuration for the rsb driver to module. And I will compile it on the target to add my traces. In case someone has the solution to my problem, my dts looks like this: &axp_gpio { gpio1_ldo_pin: gpio1-ldo-pin { pins = "GPIO1"; function = "ldo"; }; }; ®_ldo_io1 { pinctrl-names = "default"; pinctrl-0 = <&gpio1_ldo_pin>; regulator-always-on; regulator-min-microvolt = <3000000>; regulator-max-microvolt = <3000000>; regulator-name = "i2C0-iovcc"; status = "okay"; }; And while the regulator initialises for the AXP223 GPIO1/LDO, I have nothing but GND on the pin. [ 1.223696] i2C0-iovcc: Bringing 3800000uV into 3000000-3000000uV Because the driver configures the pin in the regulators, it seems like the axp_gpio and pinctrl definitions are useless. 0 Quote
Patrick 42 Posted December 7, 2025 Author Posted December 7, 2025 (edited) I fixed my i2c gpio ldo regulator issue by disabling the axp_gpio in the device tree. &axp_gpio { status = "disabled"; }; The separate driver must have been rewriting the registers configured by the regulators driver. Now back to the LCD Edited December 7, 2025 by Patrick 42 0 Quote
robertoj Posted December 8, 2025 Posted December 8, 2025 On 12/6/2025 at 3:03 AM, Patrick 42 said: And I try to not be annoying here, but I am a bit lost. What is the common method for driver debugging/development in armbian? I mean how to recompile the kernel without rebuilding all the image? Rebuilding all the image doesn't represent much more time than the time to recompile the kernel. I can't advise to download the linux source to the armbian SBC, because you would also need the armbian patches. One thing I use for debugging of DTS (and maybe linux kernel modules) taking control of GPIO is: sudo cat /sys/kernel/debug/gpio 0 Quote
laibsch Posted December 8, 2025 Posted December 8, 2025 On 12/6/2025 at 7:03 PM, Patrick 42 said: I mean how to recompile the kernel without rebuilding all the image? I think you are looking for the "kernel" build command. Have a look at some of the others as well like kernel-config or dts-check. 0 Quote
Patrick 42 Posted December 9, 2025 Author Posted December 9, 2025 Thanks. I am figuring thing up, like fixing a cycle dependency and adding traces to my lcd driver module. But I can compile this one on the target. So it is fine. The "fixing cycle(s) dependency" thing is annoying because I mostly find example boards using the lcd pins and not the dsi lanes. 0 Quote
Patrick 42 Posted December 11, 2025 Author Posted December 11, 2025 (edited) Armbian monitor https://paste.armbian.com/sakicoqowe I am nearly there with my panel driver, but I fried my dsi output. I plan to replace the A33 chip. As I can compile the driver and solved my device tree issues, we can close the topic. You can follow my progress here https://www.eevblog.com/forum/3d-printing/hack-zortrax-driver-board-port-klipper/50/ Thanks for the help. Edited December 12, 2025 by Patrick 42 0 Quote
Patrick 42 Posted December 13, 2025 Author Posted December 13, 2025 (edited) My solution is to compile the image like this: ./compile.sh INSTALL_HEADERS=yes Then scp the driver on the machine, and execute echo "obj-m += panel-mtf0397swi.o" > Makefile make -C /lib/modules/`uname -r`/build M=$PWD cp panel-mtf0397swi.ko /lib/modules/$(uname -r)/kernel/drivers/gpu/drm/panel/ depmod -a Edited December 13, 2025 by Patrick 42 0 Quote
