Patrick 42 Posted Thursday at 03:01 PM Posted Thursday at 03:01 PM (edited) Hi, I'am Patrick from France, it is my first post on the forum. I am porting the Zortrax m200 plus 3D printer to Armbian and my last important step would be to have the LCD screen working. I cross compiled my module but I have this message when installing it: # insmod panel-himax-hx8394.ko [ 1760.189919] BPF: [120533] Invalid name_offset:2238391 [ 1760.195183] failed to validate module [panel_himax_hx8394] BTF: -22 insmod: ERROR: could not insert module panel-himax-hx8394.ko: Invalid parameters Then I added the module source code to the sources, but calling ./compile.sh seems to update the repo and revert my changes such as I do not see my module in there. The next possibility would be to create an image with the kernel headers included. I will try to compile the driver on the system. And is there another way? Edited Thursday at 03:42 PM by Patrick 42 0 Quote
robertoj Posted Thursday at 05:24 PM Posted Thursday at 05:24 PM You dont need to cross-compile. You need to select the in-kernel-source option: https://www.kernelconfig.io/config_drm_panel_himax_hx8394 within the armbian build process. Then you need to create a DTS like: https://forum.armbian.com/topic/47971-driving-the-ili9488-lcd-40-inch-cheap-chinese-clone/ And also dig through the experience in this thread: https://forum.armbian.com/topic/50963-dsi-display-does-not-work-on-raspberry-pi-5/#comment-216030 Send photo of the a33 and LCD 0 Quote
Patrick 42 Posted Thursday at 06:11 PM Author Posted Thursday at 06:11 PM (edited) I have managed to compile the driver on the target with a brand new image compiled using "./compile.sh INSTALL_HEADERS=yes". Yet I would like to cross compile it. If you know how, I will greatly appreciate if you give the method. Edited Thursday at 06:12 PM by Patrick 42 0 Quote
Patrick 42 Posted Friday at 02:49 PM Author Posted Friday at 02:49 PM Thanks Robertoj All the documentation for the board is here https://github.com/zharijs/zmxxxp-re But the LCD is not an himax-hx8394. The screen is a "MTF0397SWI-06" using the chip OTM8019A. It just that I am starting from this driver to port the sunxi driver: sl698ph_720p. I will now look at your links. 0 Quote
Patrick 42 Posted Saturday at 11:03 AM Author Posted Saturday at 11:03 AM I am strugling withthe AXP223 gpio LDO configuration to initialise properly, otherwise the i2C lines to the touchscreen controller are unpowered. Therefore I will add traces in the axP223 rsb (reduced signal bus) driver code. And I try to not be annoying here, but I am a bit lost. What is the common method for driver debugging/development in armbian? I mean how to recompile the kernel without rebuilding all the image? For now I changed the kernel configuration for the rsb driver to module. And I will compile it on the target to add my traces. In case someone has the solution to my problem, my dts looks like this: &axp_gpio { gpio1_ldo_pin: gpio1-ldo-pin { pins = "GPIO1"; function = "ldo"; }; }; ®_ldo_io1 { pinctrl-names = "default"; pinctrl-0 = <&gpio1_ldo_pin>; regulator-always-on; regulator-min-microvolt = <3000000>; regulator-max-microvolt = <3000000>; regulator-name = "i2C0-iovcc"; status = "okay"; }; And while the regulator initialises for the AXP223 GPIO1/LDO, I have nothing but GND on the pin. [ 1.223696] i2C0-iovcc: Bringing 3800000uV into 3000000-3000000uV Because the driver configures the pin in the regulators, it seems like the axp_gpio and pinctrl definitions are useless. 0 Quote
Patrick 42 Posted yesterday at 10:32 AM Author Posted yesterday at 10:32 AM (edited) I fixed my i2c gpio ldo regulator issue by disabling the axp_gpio in the device tree. &axp_gpio { status = "disabled"; }; The separate driver must have been rewriting the registers configured by the regulators driver. Now back to the LCD Edited yesterday at 10:34 AM by Patrick 42 0 Quote
robertoj Posted 1 hour ago Posted 1 hour ago On 12/6/2025 at 3:03 AM, Patrick 42 said: And I try to not be annoying here, but I am a bit lost. What is the common method for driver debugging/development in armbian? I mean how to recompile the kernel without rebuilding all the image? Rebuilding all the image doesn't represent much more time than the time to recompile the kernel. I can't advise to download the linux source to the armbian SBC, because you would also need the armbian patches. One thing I use for debugging of DTS (and maybe linux kernel modules) taking control of GPIO is: sudo cat /sys/kernel/debug/gpio 0 Quote
