Posted (edited)
Hi, I'am Patrick from France, it is my first post on the forum.
I am porting the Zortrax m200 plus 3D printer to Armbian and my last important step would be to have the LCD screen working.
I cross compiled my module but I have this message when installing it:
# insmod panel-himax-hx8394.ko
[ 1760.189919] BPF: [120533] Invalid name_offset:2238391
[ 1760.195183] failed to validate module [panel_himax_hx8394] BTF: -22
insmod: ERROR: could not insert module panel-himax-hx8394.ko: Invalid parameters
Then I added the module source code to the sources, but calling ./compile.sh seems to update the repo and revert my changes such as I do not see my module in there.
The next possibility would be to create an image with the kernel headers included. I will try to compile the driver on the system.
And is there another way?
Edited by Patrick 42
You dont need to cross-compile. You need to select the in-kernel-source option: https://www.kernelconfig.io/config_drm_panel_himax_hx8394 within the armbian build process.
Then you need to create a DTS like: https://forum.armbian.com/topic/47971-driving-the-ili9488-lcd-40-inch-cheap-chinese-clone/
And also dig through the experience in this thread: https://forum.armbian.com/topic/50963-dsi-display-does-not-work-on-raspberry-pi-5/#comment-216030
Send photo of the a33 and LCD
Posted (edited)
I have managed to compile the driver on the target with a brand new image compiled using "./compile.sh INSTALL_HEADERS=yes". Yet I would like to cross compile it. If you know how, I will greatly appreciate if you give the method.
I am strugling withthe AXP223 gpio LDO configuration to initialise properly, otherwise the i2C lines to the touchscreen controller are unpowered. Therefore I will add traces in the axP223 rsb (reduced signal bus) driver code.
And I try to not be annoying here, but I am a bit lost. What is the common method for driver debugging/development in armbian?
I mean how to recompile the kernel without rebuilding all the image?
For now I changed the kernel configuration for the rsb driver to module. And I will compile it on the target to add my traces.
In case someone has the solution to my problem,  my dts looks like this:
&axp_gpio {
	gpio1_ldo_pin: gpio1-ldo-pin {
		pins = "GPIO1";
		function = "ldo";
&reg_ldo_io1 {
	pinctrl-names = "default";
	pinctrl-0 = <&gpio1_ldo_pin>;
	regulator-always-on;
	regulator-min-microvolt = <3000000>;
	regulator-max-microvolt = <3000000>;
	regulator-name = "i2C0-iovcc";
 	status = "okay";
And while the regulator initialises for the AXP223 GPIO1/LDO, I have nothing but GND on the pin.
[    1.223696] i2C0-iovcc: Bringing 3800000uV into 3000000-3000000uV
Because the driver configures the pin in the regulators, it seems like the axp_gpio and pinctrl definitions are useless.
Posted (edited)
I fixed my i2c gpio ldo regulator issue by disabling the axp_gpio in the device tree.
&axp_gpio {
	status = "disabled";
The separate driver must have been rewriting the registers configured by the regulators driver.
Now back to the LCD
Rebuilding all the image doesn't represent much more time than the time to recompile the kernel.
I can't advise to download the linux source to the armbian SBC, because you would also need the armbian patches.
One thing I use for debugging of DTS (and maybe linux kernel modules) taking control of GPIO is:
sudo cat /sys/kernel/debug/gpio
I think you are looking for the "kernel" build command.  Have a look at some of the others as well like kernel-config or dts-check.
