maxsub Posted 3 hours ago Posted 3 hours ago Is this specific patch that reverts the busy looping thread? https://github.com/armbian/build/commit/99ad08839eed42d647e716a3ed090ea318d01d2e 0 Quote
sven-ola Posted 2 hours ago Author Posted 2 hours ago @maxsub yes and no. That 900*.patch never was meant to be in the Armbian repo, I wounder how this made it in the Armbian repo. Some black git magic... Patch experimentally rolls back an upstream change (...that removes the kthread under discussion and by this prevents the main CPU from communicating to the remote CPU). Upstream (the Fedora folks that emitted the SpacemiT code drops) has removed the kthread to prevent high CPU load b/c they use RV2 for their RISCV compile farm or so. The 900*.patch was an experiment by me to understand the impact on HDMI audio / ADMA). Long blabla. This proposed and committed change solves the issue for my pull RQ on the topic: https://github.com/armbian/build/pull/9299/changes/613737fab5aadc2d0a288a10a98aa0a433db4e76 0 Quote
maxsub Posted 1 hour ago Posted 1 hour ago I patched that, am rebuilding and will post the R2S temps after that patch. 0 Quote
maxsub Posted 1 hour ago Posted 1 hour ago The patch brought the idle load average drastically down on the R2S from 2.0 to 0.18. However the temp remains at 57-58 deg C. orangepi@orangepir2s:~$ cat /sys/class/thermal/thermal_zone1/temp 56000 orangepi@orangepir2s:~$ htop orangepi@orangepir2s:~$ cat /sys/class/thermal/thermal_zone1/temp 57000 0 Quote
c0rnelius Posted 45 minutes ago Posted 45 minutes ago 14 minutes ago, maxsub said: The patch brought the idle load average drastically down on the R2S from 2.0 to 0.18. However the temp remains at 57-58 deg C. That's not bad honestly. The K1 series runs hot in general. If you add heavy lifting to thee equation it would require a fan. I have the MusePi Pro and BPI-F3 and both run hot. 0 Quote
maxsub Posted 15 minutes ago Posted 15 minutes ago Thank you. Looking forward to all these contributions hitting the main branch so I can depend on the standard edge and current builds! 0 Quote
