Go to solution Solved by sven-ola,
Posted (edited)
Hi @sivert! The downloadable Ubuntu noble image has a bcmdhd module for Wifi, so basically Wifi is working. While checking, I discovered that the bcmdhd kernel module is removed and not rebuilt during kernel update. You need to re-add it manually until I know whats wrong with that:
dpkg-reconfigure bcmdhd-spacemit-sdio-dkms
The bcmdhd automatic rebuild seems to work with the Debian Trixie image. Also, that "edge" Image is meant for devel. No UART, no devel so to speak 😉
HTH // Sven-Ola
Edited by sven-ola
Note on Ubuntu, replaced dkms rebuild with dpkg-reconfigure
Hi @sven-ola, thanks for the reply.
Before you edited it, I have seen different set of commands to build the module.
I'm not using ubuntu, I tried a debian trixie without desktop. I build the image few days ago and I have no exact command but it seems to be something like:
./compile.sh BOARD=orangepirv2 BRANCH=current RELEASE=trixie KERNEL_CONFIGURE=no BUILD_MINIMAL=no BUILD_DESKTOP=no
and there is no (apt) package with bcmdhd in the name, I suppose that the older version of your post was helpful, because it was about compiling from the source.
I just started a new build using:
./compile.sh BOARD=orangepirv2 BRANCH=current RELEASE=trixie KERNEL_CONFIGURE=yes KERNEL_GIT=shallow BUILD_MINIMAL=no SKIP_ARMBIAN_REPO=yes KERNEL_BTF=no INSTALL_HEADERS=yes
I'll report the status later.
Hey @sivert. The Ubuntu "dkms" package is borked somehow. It removes the dkms config from the file system during kernel update. The Debian "dkms" package works as expected, it removes the modules and rebuilds them on kernel update. The bcmdhd driver is of -ähh- questionable code quality and will never made it in the official kernel. For that reason, I have added an internal package named bcmdhd-spacemit-sdio-dkms that contains driver source in /usr/src and a dkms.conf which is build and installed during Armbian compile.sh. Internal means: that package is installed during build but is not installable via Armbian package repo.
Using "dpkg-reconfigure bcmdhd-spacemit-sdio-dkms" is a shorter command than the previously posted "dkms add, dkms build, dkms install" sequence. If your build does not include the bcmdhd-spacemit-sdio-dkms package and therefore does not have /usr/src/bcmdhd-spacemit-sdio-101.10.591.84.37-4/ directory, then something else is wrong here.
HTH // Sven-Ola
As an addon to @sivert: Ubuntu has dkms "3.0.11-1ubuntu13" while Debian has the newer "3.2.2-1~deb13u1". There is a difference in /etc/kernel/prerm.d/dkms: Ubuntu starts "dkms remove..." and Debian starts "dkms kernel_prerm". Both should work normally, because if you update the kernel there are two kernels: the old one and the incoming one. If you happen to have only one kernel, and thus only one compiled dkms module version, the Ubuntu "remove" completely removes anything dkms-module related. Now Armbian is offering a kernel update to the absolute same kernel version number, thus simply overwriting linux-image.
Also, a "dpkg-reconfigure linux-image-current-spacemit" (with only one Ubuntu kernel version installed) will also remove the Wifi module. I am not sure how to fix this...
Posted (edited)
I have wifi :) and it worked without building or installing anything. During the first boot I was asked if I would like to use wifi, I saw the list of SSIDs, but I was unable to connect. I used nmcli and I'm connected now.
dkms status outputs:
bcmdhd-spacemit-sdio/101.10.591.84.37-4, 6.18.36-current-spacemit, riscv64: installed
Update:
It boots from eMMC :)
Edited by sivert
just wanted to ask, is there any way to recompile the included drivers in the kernel after a kernel update?
for instance i built the intel xe and radeon drivers into my kernel when building this image, but the kernel updates from mainline apt seem to overwrite it and the drivers go away. even when dkms installed.
Hi @cal5582, your options are (rising difficulty)
  1. Do not install updates
  2. Set linux-kernel packages on hold (apt-mark hold...)
  3. Make a dkms config for your extra drivers (see above, "b2c2-flexcop-usb")
  4. Make your own Debian repo for updates and change /etc/apt sources in userpatches/customize_image.sh
  5. Start contributing to Armbian and convince devs to include your changes to kernel cfg
HTH // Sven-Ola
On 6/27/2026 at 10:57 PM, cal5582 said:
how do i do that? i just apt-hold marked the packages for the time being.
I'm not gonna explain all that. :)
If you know the exact additions you need in the defconfig, post them here and I'll add them when I do my next PR. Which will probs be sometime this week.
I'm back. I have UART converter.
My plan is to test the peripherals - I2C at this moment.
Since the armbian-config does not allow to configure device tree overlays I figured it out how to do it manually.
I edit the file: `/boot/extlinux/extlinux.conf` to add additional line:
fdtoverlays /boot/dtb/spacemit/overlay/k1-i2c4.dtbo
It seems that U-Boot is ok with this:
[   9.909] Retrieving file: /boot/dtb/spacemit/k1-orangepi-rv2.dtb
[   9.935] Retrieving file: /boot/dtb/spacemit/overlay/k1-i2c4.dtbo
[   9.964]    Uncompressing Kernel Image
[  10.316] Moving Image from 0x10000000 to 0x200000, end=27c4000
[  10.337] ## Loading init Ramdisk from Legacy Image at 21000000 ...
[  10.340]    Image Name:   uInitrd
[  10.343]    Image Type:   RISC-V Linux RAMDisk Image (gzip compressed)
[  10.349]    Data Size:    21020117 Bytes = 20 MiB
[  10.354]    Load Address: 00000000
[  10.357]    Entry Point:  00000000
   Verifying Checksum ... OK
[  10.458] ## Flattened Device Tree blob at 31000000
[  10.459]    Booting using the fdt blob at 0x31000000
[  10.565]    Loading Ramdisk to 7c974000, end 7dd7fdd5 ... OK
[  10.584]    Loading Device Tree to 000000007c952000, end 000000007c973fff ... OK
Starting kernel ...
And I'm able to see additional `i2c-4` device:
$ sudo i2cdetect -l
i2c-0	i2c       	spacemit-i2c-adapter            	I2C adapter
i2c-1	i2c       	spacemit-i2c-adapter            	I2C adapter
i2c-2	i2c       	spacemit-i2c-adapter            	I2C adapter
i2c-4	i2c       	spacemit-i2c-adapter            	I2C adapter
i2c-8	i2c       	spacemit-i2c-adapter            	I2C adapter
I'll test some sensors now...
The kernel 6.18 has the driver i2c-k1x, which is not present in 7.x. There is also i2c-k1, present in both releases.
I'm using 6.18 with i2c-k1x, it seems that 10-bit addressing is not supported `i2cdetect -F 4` shows:
10-bit addressing                no
It seems that the bus is working with 400 kHz frequency, but I don't know why. I was reading driver source and for me if spacemit,i2c-fast-mode or //spacemit,i2c-high-mode is not present, then it shall be 100 kHz.
I have no idea how to verify or change the baudrate.
I have two sensors, first requires 100 kHz and it is not working, and the second is up to 400 kHz and it seems to be working (I can read some registers, but nothing special).
Therefore I assume that bus is operating at 400 kHz.
